Etching welds.
/ Etching welds. #1
Shield Arc
Super Member
Port Orchard, WA.
John Deere, 4200
I have never done this before. When doing the testing of Roadhunter's new Everlast 120-volt Mig welder over on Welding Web. I was ask to do some etch testing. This was quite a learning experience for me:laughing:. I first tried naval jelly, then battery acid. The results were less than stellar!:thumbdown: So I ordered some phosphoric acid off ebay. It arrived yesterday. I cleaned up the fillet welds done by the Everlast 120-volt Mig run at max settings on 3/8-inch thick flatbar . And the one I did with my V350-Pro run at 29-volts, 224-amps.
First two pictures are the Everlast welds. First one is with the acid still on it. The second picture is with the acid wiped off. Not sure you can see it in this picture, the weld didn't even bite into the corner of the two plates:shocked:. Third picture is the weld made with the Lincoln V350-Pro,
/ Etching welds. #2
Can you explain how this sort of thing is read? Do you look at the color difference where the last picture looks like a pie shaped penetration?
BTW, welcome back to TBN.
/ Etching welds.
Yes that's how you read it. The V350-Pro really dug in:cool:. The Everlast 120-volt Mig didn't penetrate at all.:shocked:
Thank you!;)
/ Etching welds. #4
As the old race drivers will tell you.."there is no substitute for cubic inches"... Maybe there is no substitute for amps?:)
/ Etching welds. #5
That's cool as ****. I always wondered how well 120 welders actually did!
/ Etching welds. #6
Well done. Will you now do 1/4 and then 1/8 and see what the 115v units are good for? Acid test is very cool.
/ Etching welds.
I would love to, but Roadhunter demanded I ship his welder to him. As much as I tried to talk him into letting me keep it, he wouldn't hear of it!:confused: Kind of one way, don't you think? :laughing:
/ Etching welds.
I did the same test with 6010, and 7018. These were etched with battery acid.:thumbdown:
Fist picture is 1/8" 6010.
Second picture is 1/8" 7018.
/ Etching welds. #9
Looks like you glued them together with a bead of epoxy
/ Etching welds.
The 6010 weld is dug in pretty good. I ran that with my Everlast PowerArc 300.
/ Etching welds. #12
You Like that PA 300 don't ya :). I have the baby brother to it a PA 140. It runs 1/8" 6011, 7014 and 7018 nice. I've been wanting to try some 5/32 with it but never got around to it. Super good welders for the price.
/ Etching welds.
Oh yeah! She is a sweet machine:cool2:. I really like it with 6010. I think my Power Arc 200 has the edge with 7018 tho:confused:. Last picture is 7018 with the PA-300.
/ Etching welds.
I redid the fillet welds done with 6010, and 7018 this morning with the phosphoric acid.
First picture is the 6010 weld with the acid still on.
Second pictures is the 6010 weld with the acid wiped off.
Third pictures is the 7018 weld with the acid still on.
Forth picture is the 7018 weld with the acid wiped off.
/ Etching welds. #16
Very Interesting. Better than a bend test.
/ Etching welds. #17
I don't know if it is "better" but it certainly gives a different piece of information. I think both have value in evaluation of a weld.
/ Etching welds. #18
How are you cutting for these views? It almost looks like you cross cut them then put the flap wheel to it?
/ Etching welds.
Used a port-a-band to cut them. Then an 80-grit sanding pad, 120-grit flap wheel then a 180-grit flap wheel.
2007 WESTERN STAR 4900 SB CRANE TRUCK (A67714)
2007 WESTERN STAR...
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
2006 CHEVROLET EXPRESS 4X2 SERVICE BOX TRUCK (A69167)
2006 CHEVROLET...
FOUR PALLETS OF MISC ITEMS (A67714)
FOUR PALLETS OF...
CATERPILLAR H95-S HYD HAMMER (A65056)
CATERPILLAR H95-S...
2005 FRAC TANK 500BBL WHEELED (A68842)
2005 FRAC TANK...
