Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #2,321
Switching implements sure would turn me off. Maybe it's just me......
Well, unless you only have one use for a tractor, that's the price of owning one...
   / Pictures of your snow weapons #2,322
Sure, but 2 changes for every snow blowing? I'd for sure use the bucket to drag or even drag with the snowblower first. Or go cross-ways to get closer.
Different strokes for different folks......
I have a front blower and a back blade. That works out nice for sure.
   / Pictures of your snow weapons #2,323
My main point was that switching implements with an imatch is very quick and easy.
The reason I switched was using the snow blower for the first time on a gravel base. I set the shoes to max height out of caution. Since I left a good 1 1/2 " behind I thought a quick scrape with the rear blade would clean it up. I agree why switch if it's not needed, and will certainly try dragging the loader bucket (to simple hadn't thought of it) to clean by the garage doors, nevertheless changing from my rear snow blower to the rear blade is maybe 4 minutes driveshaft included.
   / Pictures of your snow weapons #2,324
   / Pictures of your snow weapons #2,325
   / Pictures of your snow weapons #2,326
Fluid
What is the history of that tractor and blower? Looks in good shape.
   / Pictures of your snow weapons #2,327
I did some juggling with my snow weapons this year. I had a Cub Cadet zero turn blower with cab, but my wife has a bad back. Two surgeries, more degenerated discs, discs in her neck going.... She can sneeze and throw her back out. So even the zero turn was a struggle for her. Enter my mom and grandmother with an old Dynamark blower with solid axle that neither of them could rock onto one wheel to turn. Then there was me, wanting a tractor to till with, do a better job mowing than our Husky riding mower, and just to lift/carry/dig all the things I've been doing by myself due to her back. How to help everyone, and reduce my workload? hmmmmm :D I talked to my grandmother about taking her blower, and giving them mine. After some explaining she agreed. So I gave them an easier to maneuver zero turn, took their old blower, and traded it along with my riding mower for cash down on a MF GC2600.
It's a bit overkill for out 50 ft of driveway and sidewalk, but it sure is quicker and more fun now that I have the hang of it! I read about putting 2" PVC on the loader blade on here, so I tried that at first. Had the bucket angle wrong, hit a pot hole near the sidewalk, cracked the PVC, and knocked my light bar off. Re-attached the bar with hose clamps, flipped the PVC over, and finished up. Had zero traction for turning, and had this horrible sinking "what have I done, why did I get rid of the blower?!?" moment. Next day I realized the ballast box was probably shifting weight away from the front reducing my traction. Sure enough, once I took that off traction got better, but I could still drift it around corners, and 2wd was useless in 7" of snow. So now I'm prepping to load the tires this weekend before we get more snow. Maybe even flip them for the extra width (read that here too!).
With the 2" PVC cracked I decided to try 3". That actually works better. It snaps over the thicker cutting edge, and locks on so it doesn't slide off back dragging. Also lets me level the bucket and still have 1.5-2" of clearance under it so it doesn't dig in. I pushed my entire back yard into a pile for the kids without tearing up the grass. I'm glad I traded the blower again. :laughing: May get a back blade at some point for other uses as well, but for now it does what I need and more.
   / Pictures of your snow weapons #2,328
Last September I purchased a used SB1154 to run behind my JD 2520. Last week we received at least 12" of damp snow. I couldn't be happier at the way the blower handled the snow. I opted to buy the smaller 54" model since I have a short driveway, and need to drive inside a trellis to get to the front walkway to clear a path. The imatch setup works great allowing me to hook up the Frontier snow blower very quickly. With the imatch the only reason to get off of the tractor is to connect the drive shaft, and raise the parking stand. In my setup I decided to clear as much snow as possible with the blower then switch to a rear blade to pull the snow away from the garage doors, and switch back to the blower to clear that snow. I can't imagine not using the imatch. All my attachments are imatch compatible. Here is a short video of me using the blower for the first time this year. YouTube Link: [url]https://www.youtube.com/watch?v=QF90sXpAUKQ&feature=youtu.be 20141128 223818[/URL]
Ahhhh the memories. My back and neck sure don't miss the rear blower, but man could that thing move snow.
   / Pictures of your snow weapons #2,329
Fluid
The tractor is a 1986 Gravely 8179-G 17 HP Kohler series II, original factory paint, 1300 hours, hydro lift, front,mid PTO. The tractor weighs 1500+ lbs. I have lots of attachments for the tractor.
The blower I got from a member of this forum, its 44" with drift cutters for 50" path. The blower is a mid 80s shaft drive Gravely snow cannon that can blow snow 50'- 60' easy.003.jpg004.jpg250.jpg
   / Pictures of your snow weapons #2,330
piercedtiger.
Looks like someone got some seat time ;) one BIG area to keep clean during winter.
   / Pictures of your snow weapons #2,331
piercedtiger.
   / Pictures of your snow weapons #2,332
piercedtiger.
Yeah, I had fun for about an hour. Just because I could. ;) Most I've done before is snow blow a path out around the garden to walk the dogs around. I've been working through some issues too. First tractor. First diesel. Trying to get the process down to get it started each time, but the throttle cable keeps freezing up. So it's impossible to give it more throttle when starting unless I shut off while at a higher RPM before things cool down. During that last job it was around 24F out, and the tractor was running fine until I got the squealing tach issue, and now the needle is pegged passed red line even when off. So I need to figure out how to get that off sometime to look at. I find myself having to put a heater or heat gun under the engine to thaw it out enough for the cable to move, and for the engine to finally start. :confused: Not sure what the problem is, but I've been finding excuses to use it hoping to get the kinks ironed out before I *need* to use it.
Also realized carhart overalls were better than just jeans and jacket. :laughing: Body was warm, but my knees and legs were a bit cold with just the jeans.
   / Pictures of your snow weapons #2,333
My RTV X <img src="http://www.tractorbynet.com/forums/files/snow-removal/400662-pictures-your-snow-weapons-image-jpg"/>
Awesome! Post up a video of that thing in action some time.
   / Pictures of your snow weapons #2,335
The tractor is a 1986 Gravely 8179-G 17 HP Kohler series II, original factory paint, 1300 hours, hydro lift, front,mid PTO. The tractor weighs 1500+ lbs. I have lots of attachments for the tractor. The blower I got from a member of this forum, its 44" with drift cutters for 50" path. The blower is a mid 80s shaft drive Gravely snow cannon that can blow snow 50'- 60' easy.<img src="http://www.tractorbynet.com/forums/files/snow-removal/401203-pictures-your-snow-weapons-003-jpg"/><img src="http://www.tractorbynet.com/forums/files/snow-removal/401204-pictures-your-snow-weapons-004-jpg"/><img src="http://www.tractorbynet.com/forums/files/snow-removal/401205-pictures-your-snow-weapons-250-jpg"/>
I like that, a clean older machine.
   / Pictures of your snow weapons #2,336
Here is my baby. Upstate NY winters don't seem so bad since I got this going !! Erskine 54" blower on a Massey 1225 4WD
   / Pictures of your snow weapons #2,339
Here is my baby 2014 CK30 4x4 with Kioti 66 inch dual stage blower/hydraulic shute. Pictured with new soft cab by "Cover my tractor".
That's a whole lot of tractor and blower for the amount of snow I see in the pics. ;-)
2019 KOMATSU D61PXI-24 CRAWLER DOZER (A60429)
2019 KOMATSU...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
Deere 331G (A53317)
Deere 331G (A53317)
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
Massey Fergusson 4710 (A60462)
Massey Fergusson...
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A52709)
2024 CATERPILLAR...
