Snow Attachments Tire Chains for my tractor?
/ Tire Chains for my tractor? #1
RayJavu
Cloquet, MN
Bobcat CT335
Not really an attachment but I still hope you can help.
I'd like to put tire chains on my tractor because when I plow my road, I get some slipping going uphill. I thought I'd just try chains on the front to start with and if they solved my slipping problem I wouldn't have to spend the big money for rear chains. Any thoughts? Experiences?
Thanks,
Ray
/ Tire Chains for my tractor? #2
I would do the rear only. They will solve the slipping problem. Chains just on the front will have traction problems when pushing and stopping on ice could get very exciting (tractor will want to flip around). The rears are what you really want as that is where all the weight is. I think front only will be dissapointing.
/ Tire Chains for my tractor? #3
Yes, the rears are much better. I have a Kubota that has been leaking out of the front axle seals since new. I think front tire chains ruined it. The dealer has replaced the seals 3X and they still leak.
/ Tire Chains for my tractor? #4
HAve you replaced the front axles fluid with gear oil instead of hydraulic fluid? JD and Kubota put hydraulic fluid in the front axles and hubs. I had a dealer suggest to me to change it before it starts leaking.
I ran front chains on my L3400 for a couple years now for some snow plowing and I have had no problems. I do think that the traction will be much better chaining up the rears, just be prepared to use the split brakes to steer.
Ray, there are a ton of tire chain threads, I'd start browsing them to see what you think.
/ Tire Chains for my tractor? #5
I'd also suggest putting chains on the rear tires only. The drive axle and gearing is more robust then the front gear.
As far as keeping the tractor straight...use the split brakes (if your tractor has them). A tap on the left or right steering brake is about all you need.
/ Tire Chains for my tractor? #6
Sorry off topic but...I can try to find the part # they make a front axel vent that stops pressure in the from axel I installed one this summer and not one leak since!! Had been leaking both sides as well as drive shaft seal. You would think Kubota would let us in on these things part was $20.00 bucks from Kubota.
/ Tire Chains for my tractor? #7
RedNeckRacin, I think the owner's manual specs 80/90W gear oil. I will have to dig that out and check. And Ole Orange, I did not know there was a vent available. My drive shaft seal is dry, at least. The fluid level does not go down very fast. The front tires are always oily, more than anything.
/ Tire Chains for my tractor? #8
I know that my JD and Kubota manual both spec Hy-guard and UDT to be put in. I'm swapping them out when the temps allow free flowing again with gear oil.
/ Tire Chains for my tractor? #9
I have Norse ice chains on the rear of my L3240, and they provide excellent traction on my steep often icy road. The front, however, skitters around quite a bit, especially at the end of my driveway where I go from flat and level to a 28% downslope. I've been thinking of adding V-chains to the front just to help those R4s get a bit of a bite in those conditions.
/ Tire Chains for my tractor? #10
I run 4-link v-bars front and back with no issues other than a bumpy ride until I get a little base down on the driveway. My driveway and portion of the community road I take care of can get icy and the front end used to move around quite a bit until I chained it up. Most of my work is with a 3pt 68" Meteor snow blower but I do use the FEL from time to time.
/ Tire Chains for my tractor? #11
I will say, I have been on ice that stops regular chains. The V-bars really grip like a bear paw.
/ Tire Chains for my tractor? #12
maybe this should be a new Thread but here goes:
What weight , if any, do you have in the rear to help with traction? Do you hang any big weight off the Cat 1 hitch?
/ Tire Chains for my tractor? #13
I run Talons and they are a great chain....make sure you get studded ice chains that make contact around the entire perimeter or your tire and not a chain that leaves a large void between links
The pics aren't great but they'll give you an idea
These are the type of chains I would avoid....I bought this set the first time because they were recommended by the local tractor dealer and the price was much lower than an ice chain....for my tractor I think they were a bit over $350 and I was told the old International would be "unstoppable" with them ....they were fine until there was any hard pack...get on hard pack and they would start to slip in the void area and then would just slip and slide until I came to a stop again....the chains sucked for snow removal
On the Kubota BX 1860 I used a ICC diamond V-bar chain designed for an ATV/UTV and they work great....if you're dealing with a small tractor they are tough to beat and very inexpensive
/ Tire Chains for my tractor? #14
ICC, is that the company? I cannot find their website.
Security Chain Company, I think, makes the chains for many rebranded companies
/ Tire Chains for my tractor? #17
/ Tire Chains for my tractor? #20
DIXIEDOG, those chains you first had that were no good for you,,
is what was given to me with the purchase of my JCB, I haven't installed them yet and may not,
but I was thinking, what about if I added Vbar strips of chain in "the void" area, there's a link there that could take a strip of Vbar chain, what are your thoughts on this?
2014 FREIGHTLINER CASCADIA T/A SLEEPER TRUCK TRACTOR (A59914)
2014 FREIGHTLINER...
2014 UTILITY 53X102 DRY VAN TRAILER (A59914)
2014 UTILITY...
1143 (A63745)
1143 (A63745)
Brent 420 Grain Cart (A63688)
Brent 420 Grain...
2024 ANKONA 54" HANG-ON WHEEL LOADER FORKS (A62129)
2024 ANKONA 54"...
New 4400lb All Steel Adjustable Gantry Crane (A62679)
New 4400lb All...
