AKfish
Super Member
- Joined
- Oct 1, 2004
- Messages
- 5,420
- Location
- Alaska
- Tractor
- JD 5115M; JD 110 TLB; JD 4720; Ford 9N; JD X300R
I just started feeding from the barn with about 350 small squares in it. When I baled it I had a few bales from the edge of the field that were 18 to 22 percent. Too wet but I had to get 'em off the field. The rest of the hay was averaging around 13 percent - I really like 10 - but I had to git 'er done!
Rained pretty steady the tail end of summer and darn near all fall. Ambient humidity was enough to rust yer shoes if you stood around a bit..
Those bales jumped to 20 percent the first week or so in the stack - uncovered in a 3-sided barn. They didn't heat bad; don't think I tested one that was above 75 degrees.
But, these first bales are just dustier than what you might have from stacked near a country road.
That's not an acceptable outcome for all the time and work we put into makin' hay!
I'm lookin' at a preservative setup for my square baler. I know next to nothin' about them but recall years ago rusty balers, etc. My question is for those that have used preservative and the pros and cons of that experience.
My thanks for any and all observations.
AKfish
AKfish
