Air Pad II
/ Air Pad II #1
thcri
Elite Member
Minnesota SE
New Holland TC29D, 2001
I just got the New iPad Air II. Downloaded the Tractorbynbet software. When I click on the Login tab it brings up the login screen but then the screen disappears just as fast as it comes up. I can't get logged in.
/ Air Pad II #2
Check all your settings to make sure there is no update. My iPhone did that not long ago so I hard rebooted it (Hold the center button and the on/off button for several seconds) then once i restarted I had an update to my OS pop up. Worked fine after that.
Good luck
/ Air Pad II
I have checked all possible settings. My IOS is up to date. I have uninstalled the program and re-installed it. I went back to my old iPad where it was working and logged out thinking it was conflicting with the new iPad. Now that I logged out of the old iPad I can't log back in as I now get the same error on the old iPad. So basically the iPad spots don't work fir me at all right now
/ Air Pad II #4
If it affects both iPads, then I'd suspect its a server side issue.
I browse TBN a lot on my iPad, but just use the safari browser (same as if I was on my computer). Never had an issue. Not sure why you'd need the app on an iPad, especially the new Air 2 that has the CPU horsepower of a computer. On a cell phone, maybe, but the iPad can pretty much do the full web experience in the browser.
/ Air Pad II #5
I also just use Safari on my IPad - the app is fine on the phone but I just prefer using the "full site" if I can.
/ Air Pad II
I like the App. I am always connected. I can check instantly if someone has replied to my posts.
/ Air Pad II #7
I like to open the app app but if I see something I want to reply to, I open safari and reply there. I've always had issues with the TBN app. Even more issues with everything on my iPad since I downloaded the latest iOS.
/ Air Pad II #8
I like the TBN app, both on my iPhone and iPad. Lately, it crashes when I hit Send when making a reply. Not all the time, but maybe half. Maybe an issue with IOS 8? Currently using 8.1.
post_lastposttime
/ Air Pad II #9
It does seem the new OS has added some little issues to several of my APPS and programs. Hopefully Apple will do a few more updates to get everything cleared up quickly.
/ Air Pad II
Well I did something just for the heck of it. Even though the screen wasn't there I typed in my ID, pressed Go and then typed in my password, then pressed Go and I am now in. I did this not knowing if anything was being typed in or not or where my curser was.
/ Air Pad II #11
I have an iPad Air and since the last iOS update I have had similar problems in Safari (especially in Google). The page jumps up or down so you cannot see the typing.
Very annoying!!
Weedpharma
/ Air Pad II #12
The problem still exist. The iPad both my ipad2 and my iPad Air are somewhat useless. But still can log in as usual using Safari. Not sure but Apple just released an update which might or might not be related.
The login template would appear briefly then disappear and that box or half the screen would go black.
/ Air Pad II
The problem still exist. The iPad both my ipad2 and my iPad Air are somewhat useless. But still can log in as usual using Safari. Not sure but Apple just released an update which might or might not be related. The login template would appear briefly then disappear and that box or half the screen would go black.
Do as I did in the App. A couple posts back.
When the login screen disappears just start typing in your ID, the click go on your keyboard then click the login tab. You will go in. It works all the time for me. You won't see nothing happening when typing but it must be in the back ground
/ Air Pad II #14
I logged in without seeing anything. It works that way but it's still broken. A work around new visitors may not be aware of and give up. Maybe they will have it fixed soon. Something always gets broken when they update the iOS. I love using the iPad because it's extremely fast over windows.
/ Air Pad II #15
Another bug I just found. Went to reply in the Word Asscociation game, the keyboard when blanks. They keys where still there but invisible. Anyone else experience this.
Running iOS 8.1.1 on an iPad Air I 128
/ Air Pad II #16
Still broken.
Crashes
Blank keys
Almost always adds jib bearish at end of post., yesterday it added a complete conversation from another member.
DTSDKName
/ Air Pad II #17
Still broken. Crashes Blank keys Almost always adds jib bearish at end of post., yesterday it added a complete conversation from another member. DTSDKName
Just on TBN or all apps?
It doesn't do it using safari on TBN, right?
/ Air Pad II #18
Just this app on TBN as far as I know.
application/x-www-form-urlencoded; charset=utf-8
/ Air Pad II #20
I would guess the issue is with iOS8, not the iPad Air II specifically, but maybe others can weigh in.
2003 Bombardier Evinrude 75 Outboard Boat Motor. (A66738)
2003 Bombardier...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2017 JAYCO WHITE HAWK CAMPER (A67714)
2017 JAYCO WHITE...
2016 John Deere WG48A (A64912)
2016 John Deere...
John Deere 7710 Frame (A64912)
John Deere 7710...
2015 KUBOTA F3990 MOWER (A66091)
2015 KUBOTA F3990...
