BX25 trouble......
/ BX25 trouble...... #1
JonCbx25guy
Kubota BX25
image-3258513997.jpg I was using the PTO today and heard a clicking noise.....five minutes later, BAM! This cannot be good......any idea what happened here guys?
/ BX25 trouble...... #2
I don't know, but that may be a trip to the dealer unless you get a shop manual and are good at wrenching...sorry about the broken tractor. What were you doing?
Btw, the moderator should move this thread under Kubota "owning/operating"
I didn't realize the group at the time......my bad. I did post the same thing on the owner and operating also......
/ BX25 trouble...... #4
Ouch! That looks expensive. Let us know how things work out.
/ BX25 trouble...... #6
Dunno either, but doesn't look good!:thumbdown:
/ BX25 trouble...... #7
What were you using on the PTO? Can you back off the picture a bit?
I was using a Woods tsg 50 stump grinder. Not covered under insurance.....
/ BX25 trouble...... #9
I take it there was no slip clutch between the tractor and stump grinder..? OUCH
not trying to be a smart Alec -
but- a good used 50+ hp 2 wheel drive utility tractor will probably be less expensive to get you up and stump grinding again- than the fix for that bx will cost???
that tsg grinder has some easily to be misunderstood specs Product Details
at the top it lists tractor hp range of 50- 100 hp
- under general lists tractor engine power between 15-50 hp
also the notation of being compatible with a cat 2 hitch
It looks like that size of Woods stump grinder is a recipe for the destruction of any bx pto
especially if there is no slip clutch.. jmo
Hopefully the bx can be fixed , without major expense- or you are mechanically inclined and or have a friend that is good at working on these new Kubotas.
Good Luck- and your tractor will be good as new once fixed
but after reading the Woods specs- can't recommend running a tsg 50 on any bx series
/ BX25 trouble...... #10
I agree, that is an awfully big implement to be running with a BX. I wouldn't even run that with a B series.
There was a slip clutch and I neglected to adjust. It is repaired and was 3050.00 with a 200 hour service performed. I will look at the specs and see if I missed something.....
The TSG50 appears to fit the specs of the BX25......if the slip clutch would have been adjusted, I think I would have been fine.
/ BX25 trouble...... #14
Oops- looks like the data site i posted actually combines specs for the tsg 50 and SG100 so actually the bx may be ok if the slip clutch is set a little on the loose side..
Glad to hear the tractor is up and running again. :thumbsup:
Being without a tractor is like a day without sunshine
Here is a picture for the incident.........enjoy,
/ BX25 trouble...... #16
Ouch!
I'm surprised it blew the gear(s) and the case. But if the grinder came to an immediate stop, I can see all that inertia needing to go somewhere.
I'm afraid of something like this happening on my B2920. I don't even run the my Walenstien BX42 chipper on it any more. I use the tractor that has the big gears in it, the M7040.
/ BX25 trouble...... #18
JonCbx25guy
No one has asked this yet: Did you finance your Bx25 through Kubota. Is it still insured through Kubota?
If so, your Kubota insurance will most likely take care of this accident.
/ BX25 trouble...... #19
JonCbx25guy
Actually I did ask it, but the OP didn't seem to think insurance would apply so im not sure he has it or not.
/ BX25 trouble...... #20
JonCbx25guy
Deleted. Double post
UNUSED WOLVERINE SB66-66" ROCK BKT (A64281)
UNUSED WOLVERINE...
(2) UNUSED 12-16.5 TIRES ONLY (A64280)
(2) UNUSED 12-16.5...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
NEW Rachet Tie Downs and Flatpack Tool Box (A62679)
NEW Rachet Tie...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
UNUSED WOLVERINE (A64281)
UNUSED WOLVERINE...
