Engine trouble
/ Engine trouble #1
dheastings
Allison Park, PA
Kubota L-185
I was operating my 1972 Kubota L-185 diesel the other day when I got a whistling noise from the engine. It soon stopped. A few minutes later the whistling was more pronounced and continuous. I got the hood up and saw the belt continuing to turn the engine and generator, but not the fan blades. I turned off the engine and carefully turned the fan blades by hand. While stiff, they moved. I tried starting it up and it worked. I drove it a few minutes to get back to where I store it. My guess is that the fan blades are independent of the engine and spin with the help of ball bearings. Perhaps the bearings at times are preventing the blades from turning. Does this sound plausible? And if so, is there a fix for it short of replacing the fan blades?
Dave Heastings
West Deer Township, PA (just north of Pittsburgh).
/ Engine trouble #2
Dave Heastings
I'm not all familiar with your tractor, but on most the fan is attached to the water pump. It sounds like the bearings in the water pump are going bad and will require replacement of the pump.
/ Engine trouble #3
What amaxwell said sounds about right. If so, I would not run it until the pump is replaced because coolant will not be flowing to critical areas of the head/engine if the pump is starting to seize up.
/ Engine trouble #4
His tractor doen't have a pump. The fan is turned by the belt and the fan is mounted on a shaft with 2 bearings (6203UU)
/ Engine trouble #5
On my parents old B8200 there is a fitting on the radiator overflow that makes a whistle sound if it overheats.
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
2000 International 4900 Tandem Truck (A66285)
2000 International...
Kubota SVL 75-2 (A60462)
Kubota SVL 75-2...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A65563)
IMPORTANT PLEASE...
2020 Bobcat MT85 (A62177)
2020 Bobcat MT85...
2013 KUBOTA KX71-3 SUPER SERIES EXCAVATOR (A64279)
2013 KUBOTA KX71-3...
