single acting
/ single acting #1
Young Ed
Member
Kent
Ford 4610
so to fit a rear remote valve to operate a hydraulic tipping trailer with only a single acting cylinder, do i need a special single acting spool valve? or do i just hook up a double acting valve differently? or do i modify a double acting valve somehow?
i'm guessing it isn't just as simple as fitting it out as a double acting remote and just plugging the trailer hose into one of the two rear remote sockets for that valve? if that even makes sense?
open center system if that makes a difference
Cheers Ed
/ single acting #2
Ed you need some way to bleed the oil off to let it down. So either a double acting valve that has the float function and put it in float mode to let it down or you need a single acting valve. You can tee into the line and have a separate hand controlled ball valve, to let the oil out, but that can get so that it is not very convenient. I would go with the float function valve if you are starting from scratch.;)
/ single acting #3
I think one doesn't have to have float on a double acting valve to lower a tilt trailer with a single acting cylinder. My 6700 ford lowers single acting cylinders on hay rake without float position.
/ single acting
well, a single acting valve would seem the logical and 'proper' way to do it in my mind but i am struggling to find any single acting valves in the UK so i will see if i can find a double acting valve with the float function
as a double acting valve has two outlet ports wouldn't this valve try to feed oil to the other outlet if i accidentally knocked it too far to the return setting, would this cause a problem as i would leave the second port disconnected?
Cheers Ed
/ single acting
is it a problem that you haven't got anything connected to the other outlet/inlet on the valve when using single acting cylinders? i'm guessing not?
Cheers Ed
/ single acting #6
position.
You are correct that you do not need a valve with float to operate SA cyls. To use a common
valve usually used with DA cyls, just run a hose from the B work port to the Tank return. You can Tee
into the existing return, or run a separate line. The A work port goes to the SA cyl port.
You can also just leave the B port capped off so that when you operate the lever to let the load
down, the implement pump just goes to relief. This brief time on relief will not hurt anything. I did
this with my SA cyl on my concrete mixer for a while, before I converted to a DA cyl.
/ single acting #7
So how does he do this with a single line properly? :confused: These other ways that have been mentioned may work, but are they right? :confused3:
/ single acting
considering this trailer only gets used half a dozen or so times a year and probably gets tipped less than 50 or so times a year i will probably just kit it out for double action and then i might T into the return line and run a line up next to the B out let for use when tipping the SA trailer
Cheers Ed
/ single acting #9
Cheers Ed[/QUOTE)
Run a return line with a male quick disconnect. You can plug it in when using single acting or unplug it when using double acting. The male tip will not leak when unplugged since it has minimal pressure being a return line.
/ single acting #10
Blow this picture up and you can see how I did mine. I use a 12v off and on valve, tee into the tank return line. Just flip a switch and it comes down and if you forget to switch it back it well not dump. I didn't like my relief valve sound off while the bed was comeing down and it was slow.
/ single acting
have a look at attached picture where i have done some very fine artwork as an overlay to your photo! :p
can you tell me what the red, green and blue pipe are?
I am guessing the green pipe is the supply to the trailer coming from the A port? the blue pipe would appear to be tapping off the green pipe with a T piece? is it at this T piece that your electronic valve is so that the oil heading back to the valve to be dumped goes straight to the dump line?
Cheers Ed
/ single acting
/ single acting #13
Cheers Ed
No problem not having a return oil hose plugged in the other side on my Ford or my Kubota with the disc cutter with a SA cylinder. In fact I can't see the advantage or need of this return hose they speak of. If there's a problem beecause of the larger capacity SA cylinder just stop engine when lowering tilt trailer
/ single acting #14
Cheers Ed
Green is to the dump cyl and the blue and red are the same hose. The valve you can just see the top, it where the red wires are right behind the coupler.
/ single acting #15
Jim is right about all you have to do is shut the engine off, mine worked by doing that. I just didn't want to do that all the time,so I did it the way I did.
/ single acting #16
a problem because of the larger capacity SA cylinder just stop engine when lowering tilt trailer
Yes, just turning off the engine will work fine. It will not make the bed come down any faster, but it will be a bit
quieter.
Another solution I really like and not hard at all is to convert the SA cyl to DA. I love the positive down
action, and it IS faster than gravity-dwon. Weld a fitting to the rod-side vent on the cyl and run another hose
to the DA valve.
/ single acting #17
Cheers Ed
Why not just use a DA valve and DA cyl to simply things.
If you just want to use a DA cyl as SA, the install a breather plug in the DA cyl. Then plug the valves B port or run the B port hose to tank.
I see no reason to use SA cyl when there are thousands of DA cyl available.
/ single acting
we already have trailer with a fine working SA ram, do you think it would really be worth jacking up the trailer bad and ripping out the old SA cylinder and replacing with DA of same specs?
in any case i think i might just do as in my above diagrams if someone can confirm this would work as in a few years time i am looking to probably get some hay making gear and a lot of that uses SA cylinders, this would give me 2 DA remotes and 1 SA remote. cost more to set up but the best setup in the long run i reckon
Cheers Ed
/ single acting #19
Maybe he has on old single acting hoist a on an old running gear with a grain box. I don't think those would be very easy to convert to a double acting cylinder or be worth the investment of a new cylinder. If the present cylinder works, why replace it? I think updating the tractor hydraulics would be money better spent. The updated tractor hydraulics would then be more usefull for other attachments. That's my thoughts, for what it's worth.
/ single acting
also i know various farmers about i help out and if i were to need to use their SA dump trailer or their SA hydraulic folding mower (i know farmers with both of these) then i would be slightly screwed
Cheers Ed
Unused Hustler DG LM200 SS 79in Hydraulic Dual Cylinder Grapple Loader Tractor Attachment (A66734)
Unused Hustler DG...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A66734)
2025 Kivel 48in...
2012 CATERPILLAR CP56 PADFOOT ROLLER (A65056)
2012 CATERPILLAR...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
