Show What Tool You Made*
/ Show What Tool You Made* #362
Yeah, that would work or ....... find a piece of pipe the right size and press it over the wooden wheel to make a steel tire. PVC pipe would probably work too, but it's kinda hard to find PVC that large.
I think the way it's generally done is to roll a ring and weld it together slightly undersized. Then you heat it up, that expands it, them drop it over the wheel and it cools and shrinks and becomes very tight on the wheel.
Same way you install new starter teeth on a flywheel, they are not welded just a friction fit.
/ Show What Tool You Made* #363
Had a very hard to get to hydraulic hose to get to. A $5 Chinese wrench and a 1/2 drive spcket made an extended reach crowfoot.
/ Show What Tool You Made* #364
Added a collator off one of my reloading machines and added a" flipper" built the same way me seed dropper works on my gopher plow.
/ Show What Tool You Made* #365
Not really a tool per se ... but an accessory for one (or two) - MIG gun holder on the vise stand:
/ Show What Tool You Made* #366
anything that makes your life easier is a "tool"
if it makes your life worse or doesn't help ... it is a "useless tool"
/ Show What Tool You Made* #369
( PSSSTT , that was the real meaning behind the remark ):laughing:
/ Show What Tool You Made* #371
I would like to construct one similar to yours, have you any further photos, drawings etc.many thanks Ivan
Probably be a good idea to quote the post you're replying to, or at least mention the poster's screen name ... otherwise they may not know you are addressing them.
/ Show What Tool You Made* #374
rswyan, Kind words to a new poster. There should be more people in the world with your attitude.
ivan, Almost everybody on this site is extremely kind and helpful.
/ Show What Tool You Made* #376
Here's a quick and effective way to wash/peel new potatoes. It's an off-take from videos on Youtube that use a toilet bowl cleaner to do the same thing. Didn't want a toilet bowl cleaner in the kitchen drawer :laughing:
/ Show What Tool You Made* #377
How about a pressure washer,
you could use a higher pressure one if you wanted the peels off at the same time.:p
/ Show What Tool You Made* #379
I want to know how you have a garden with no weeds.... that's the real deal... NO WEEDS .... I want a garden like that....
/ Show What Tool You Made* #380
had a lot more than that to do once ... picked up an old washing machine at the side of the road ... took it home , tied the drain hose up to the power cord , filled with water , dropped the taters in , ran for 10 minutes for each batch ...
put it out at the end of the driveway when I was done and the scrap metal guys picked it up ...
John Deere 2 Row Planter (A65640)
John Deere 2 Row...
1997 International 3800 School Bus (A64194)
1997 International...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A65563)
IMPORTANT PLEASE...
Caterpillar 318BL Excavator (A65579)
Caterpillar 318BL...
2001 International 3800 School Bus (A64194)
2001 International...
John Deere 660 Hay Rake (A66408)
John Deere 660 Hay...
