Stihl low on power
   / Stihl low on power #1
TNhobbyfarmer
Middle Tennessee
Kubota L3430 Polaris Ranger 500
My 025 Stihl chainsaw seems to be low on power. I am having problems cutting logs that it used to zip through. I put a new chain on and it's still not cutting well so it's not just a dull chain. Even though it starts easily and sounds like it always has, the engine appears to be running hot. There is smoke coming from under the chain cowling. I am thinking about one of two options. Either take it too a service center and have it serviced or just get a new one. I am worried about a large repair bill and not being satisfied with the results and then going on and getting a new one anyway. What would you do?
   / Stihl low on power #3
Was it going fine when you first started to use it that day but just seemed to de-power after a little while?
   / Stihl low on power #4
The muffler is probably fouled with oil.
   / Stihl low on power #5
How fresh is the gas ?
   / Stihl low on power #7
Replace the fuel filter, air filter and the spark plug. Also as suggested check the muffler, you could also take the muffler off and check to see if the Pistons scored. But definitely put new fuel in it as you might have a bad batch. (Make another batch)
   / Stihl low on power #8
Chain brake hanging up?
   / Stihl low on power #9
Chain oiler is my guess. Bar gets hot and expands causing chain to become so tight that engine can't turn it.
   / Stihl low on power #10
Make sure you have 2 stroke oil in gas.
2007 Chevrolet Impala Sedan (A55853)
2007 Chevrolet...
(2) Safemack 18.4-38 Tires w/Rims (A56469)
(2) Safemack...
CFG Industrial MX15RX (A56469)
CFG Industrial...
2016 Ford Taurus Sedan (A55853)
2016 Ford Taurus...
CRATOS SHERPA 100 ECO ELECTRIC STAND ON SKID STEER (A57192)
CRATOS SHERPA 100...
Swict 78" Quick Attach Bucket (A56469)
Swict 78" Quick...
