gsganzer
Elite Member
- Joined
- Jun 11, 2003
- Messages
- 4,432
- Location
- Sunset, TX
- Tractor
- L3800 w/FEL and BH77, BX 2200 w/FEL and MMM
Where are the oil passages? Easily accessible?
Pull off the chain cover and remove the bar. Right where the bar interfaces with the saw body, usually above the bar holding threaded stud, you'll see an oil passageway. If you look at the bar, you'll see a small hole to one side of the bar stud groove. This hole takes a right angle turn and emerges in the chain track. This allows oil to emerge from the saw reservoir and be pumped into the upper chain groove on the bar. Wash this area with some of your saw gas and you will see the passageways.
