Kubota m6800 3 point hitch problem
   / Kubota m6800 3 point hitch problem #1
Macnut
Wailuku,hi
Kubota m6800
I have a m6800 that has lost some linkage to the arm from the valve. I bought the parts that I thought were missing but don't see how they could work. Does anyone have a picture that can show me what I'm missing?
It's the part from the hydraulic arm to a small valve lever a couple inches apart. The only way I can lift the arms is by pushing valve under the arm. And the parts are to long as far as I can tell.
Thanks
   / Kubota m6800 3 point hitch problem #2
Sounds like you have draft control need manual to show that
   / Kubota m6800 3 point hitch problem #3
The parts you need does that happen to be the feedback rod with swivel from 3 pt rockshaft to valve?
I need the parts from lever to arm
   / Kubota m6800 3 point hitch problem #5
Here you go it is a m5700 but it should be the same the missing link goes to the back of the tractor not the lift arm.
   / Kubota m6800 3 point hitch problem #7
In addition to looking up parts utilizing Messicks one can look up parts at Kubota Tractor Corporation parts site
Correct missing parts should be the following.
3A011-81393 rod
3A011-81380 rod
32350-28980 turnbuckle
02116-50100 nut
32350-28990 nut
Thanks for the pics and parts, it helped me a lot.
The feed back link was what was broken and the draft control link was missing
That's why I was confused
Thanks again
   / Kubota m6800 3 point hitch problem #9
What position is part#200 lever supposed to be in when 3 pt operating properly?
Bad Boy Outlaw XP61 Zero Turn Mower (A48082)
Bad Boy Outlaw...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
2019 CATERPILLAR 289D SKID STEER (A51242)
2019 CATERPILLAR...
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
2014 Dodge Ram 5500 4x4 Bucket Truck with Altec AT40M - 45FT Boom, Jib Winch and Utility Bed (A52128)
2014 Dodge Ram...
Woods 3180 Batwing Mower (A50514)
Woods 3180 Batwing...
