Kubota m6800 3 point hitch problem
   / Kubota m6800 3 point hitch problem #1
Macnut
Wailuku,hi
Kubota m6800
I have a m6800 that has lost some linkage to the arm from the valve. I bought the parts that I thought were missing but don't see how they could work. Does anyone have a picture that can show me what I'm missing?
It's the part from the hydraulic arm to a small valve lever a couple inches apart. The only way I can lift the arms is by pushing valve under the arm. And the parts are to long as far as I can tell.
Thanks
   / Kubota m6800 3 point hitch problem #2
Sounds like you have draft control need manual to show that
   / Kubota m6800 3 point hitch problem #3
The parts you need does that happen to be the feedback rod with swivel from 3 pt rockshaft to valve?
I need the parts from lever to arm
   / Kubota m6800 3 point hitch problem #5
Here you go it is a m5700 but it should be the same the missing link goes to the back of the tractor not the lift arm.
   / Kubota m6800 3 point hitch problem #7
In addition to looking up parts utilizing Messicks one can look up parts at Kubota Tractor Corporation parts site
Correct missing parts should be the following.
3A011-81393 rod
3A011-81380 rod
32350-28980 turnbuckle
02116-50100 nut
32350-28990 nut
Thanks for the pics and parts, it helped me a lot.
The feed back link was what was broken and the draft control link was missing
That's why I was confused
Thanks again
   / Kubota m6800 3 point hitch problem #9
What position is part#200 lever supposed to be in when 3 pt operating properly?
2015 Ford F-450 Service Truck, VIN # 1FDUF4GT7FEC15731 (A51572)
2015 Ford F-450...
2018 CATERPILLAR 279D SKID STEER (A51246)
2018 CATERPILLAR...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
2019 Yamaha Electric Golf Cart (A51573)
2019 Yamaha...
