Tires Caster wheel option for brush hog
/ Caster wheel option for brush hog #1
RegL
Northwestern CT
PT 1430
Don't know why it took me so long. Since I bought the PT1430 in 2003, I cursed every time I was field mowing with the brush mower because caster wheels were to small and the mower cut to short and used to much HP. The other day I happened to notice that my power rake, that I use once or twice a year and is stored out back in the weeds, has two nice taller and wider caster forks and wheels. And they just happen to fit the brush hog. I only mowed for about an hour with them but they worked great. PT should supply the brush hog with these wheels in stead of those crappy little ones.
/ Caster wheel option for brush hog #2
My brush hog only has one caster wheel.
But it is big and works good :thumbsup:.
/ Caster wheel option for brush hog #3
...PT should supply the brush hog with these wheels in stead of those crappy little ones.
Hmmm... I may have to make that request if/when I order a 1430 myself...!
Thanks for sharing,
My brush hog only has one caster wheel. <img src="http://www.tractorbynet.com/forums/files/power-trac/392738-caster-wheel-option-brush-hog-p4010055-jpg"/> <img src="http://www.tractorbynet.com/forums/files/power-trac/392739-caster-wheel-option-brush-hog-p4010076-jpg"/> <img src="http://www.tractorbynet.com/forums/files/power-trac/392740-caster-wheel-option-brush-hog-p4120025-jpg"/> <img src="http://www.tractorbynet.com/forums/files/power-trac/392741-caster-wheel-option-brush-hog-p8300017-jpg"/> But it is big and works good :thumbsup:.
Nice rig. I could like a cab like that. The PT brushhog oscillates side to side so it would be kind of floppy with one wheel 😊
/ Caster wheel option for brush hog #5
Those Tree Terminators look awesome. I love the blades.
All the best,
Peter
/ Caster wheel option for brush hog #6
Nice rig. I could like a cab like that. ------------------
Thanks. Yep, the air conditioning is great.
All the best,
Peter
The mower works as good as it looks, :thumbsup:.
/ Caster wheel option for brush hog #7
I think they do. I bought my brush hog last year, and my caster wheel looks just like yours.
Nope, they are different sizes. Yours is narrower. I rotated them so its easier to do a side by side... <img src="http://www.tractorbynet.com/forums/files/power-trac/392901-caster-wheel-option-brush-hog-z400-jpg"/><img src="http://www.tractorbynet.com/forums/files/power-trac/392902-caster-wheel-option-brush-hog-z1430-jpg"/>
Not only narrower. Also smaller diameter and forks are shorter. Raised the deck about 2or 3 inches with the power rake wheels.
/ Caster wheel option for brush hog #10
Can you set an old one next to the current ones and take a pic for comparrison?
/ Caster wheel option for brush hog #12
hmm, I guess those are bigger. What size numbers are imprinted on the tires of the larger ones?
13x6.50x6
Sent from my iPhone using TractorByNet
2008 KOMATSU PC200LC-8 HYDRAULIC EXCAVATOR (A64047)
2008 KOMATSU...
2013 Case 850L Dozer w/ Ripper (A64047)
2013 Case 850L...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A63118)
2023 Kubota...
2018 MACK PINNACLE (A63569)
2018 MACK PINNACLE...
2018 INTERNATIONAL LT625 DAY CAB W/ WETLINE (A62613)
2018 INTERNATIONAL...
ATS ME18 Mini Excavator (A64047)
ATS ME18 Mini...
