New Kubota Temp issue
/ New Kubota Temp issue #1
ladder21
College Station, TX
2015 Kubota MX 5200 HST
I am new on this site and I recently traded my 2013 L3800 4wd HST for a 2015 mx 5200 4wd HST. This new tractor has the new emissions system on it. The problem Im having is that as I operate the tractor, and it gets up to operating temp, It begins to heat up the operators station alot!! I never had this problem with my L3800. I have put 10 hours (uncomfortable hours) on this new tractor and it operates in a normal engine temperature range, but it roasts my feet and legs. I was wondering if anybody else has had this issue. I believe that the problem stems from this new emissions system (super heating the exhaust). Any info would be appreciated.
/ New Kubota Temp issue #2
Actually many things done for emissions control reduce exhaust temp. High combustion temperatures result in higher NOX so they recirculate exhaust gas to keep the combustion temperature down. However most Tier 4 final engines have higher heat rejection so the cooling fan is blowing a lot more air to cool the engine and if not ducted properly, you can get more of that air blast. In addition you replaced a 38 HP tractor with a 52 HP tractor which alone adds to the heat rejection.
Complain to the dealer. If they get enough complaints, Kubota might do something about it.
/ New Kubota Temp issue #3
Think you're hot, look at arctic melt. Emission controls are necessary and overdue.
Crash helmet on and bible verse repellent applied....
islander
/ New Kubota Temp issue #4
We now return you to your regular tractor discussion.
/ New Kubota Temp issue #5
Neither of the last 2 posts have any info that is pertinent to the question asked by the poster.
If you are unable to do more than post comments that pertain to your own personal agenda and provide no useful info to a poster's question then you should find a more suitable site as it is unfair to those who have legitimate questions.
/ New Kubota Temp issue #6
Had an absolute p!ssy day and blew off steam. This was exactly my point, only I got diarrhea of the fingers. Mea culpa.
/ New Kubota Temp issue #7
The engine is in front of you. The transmission is under you. If your feet are getting hot I would start looking in the transaxle area for what is causing it to get so hot. Have you actually placed your hand on the transaxle when experiencing the high heat? I would find the cause of the problem before operating it much more. Have you felt of the transaxle coolant radiator to see how hot it is? Not the tractor radiator the other one, the small one.
/ New Kubota Temp issue #8
islander
Oh boy are you in trouble now. You have mentioned two no-no's in one post.
/ New Kubota Temp issue #9
Welcome to TBN. Ignore the useless posts; and since your tractor is new bring your concerns to your selling dealer. There maybe something amiss that they can remedy for you. Report back results.
/ New Kubota Temp issue #11
That sucks man, is it hot all the time or only when it regens?
/ New Kubota Temp issue #12
Welcome to TBN! I would get an infrared thermometer and check a bunch of different spots to see if it is operating at normal temps.
/ New Kubota Temp issue #13
What a great idea. That is what I did when I found my JD axle heating up. The dealer had me do some pre-diagnostic work to shorten time in the shop and it came out that a SCV remote lever was stuck just a little and was causing the problem. Not enough to cause squealing but enough to cause a problem.
/ New Kubota Temp issue #14
I know my hst gets hot on your feet makes it uncomfortable to run it with flip flops on.
/ New Kubota Temp issue #15
I know this post is a little old but I'm interested in an MX5200 and just got a quote on one with HST, so I'm wondering if you got a resolution to the problem or if it's still an issue. Thanks
New/Unused CFG Industrial QK16R Mini Excavator (A65583)
New/Unused CFG...
2015 John Deere 310SL 4x4 Extendahoe Loader Backhoe (A61572)
2015 John Deere...
2019 CATERPILLAR 259D SKID STEER (A64279)
2019 CATERPILLAR...
2007 Ford Taurus Sedan (A61574)
2007 Ford Taurus...
2000 Artic Cat ZR600 Limited Edition Snow Mobile (A62613)
2000 Artic Cat...
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
