Logging tongs
/ Logging tongs #1
escavader
western maine
bx-23 ,
Hi,
Have a set on a hand winch I use to lift rounds up on my spliter.They work great if you have 2people one holds them on the round until it starts to lift.problem is by myself it doesn't work so good .i tap them in best I can but sometimes they come off until I get a tension on the cable.any one ever tried to attach a spring to keep them taught or does any one have another idea?
/ Logging tongs #2
You might have "skidder" tongs instead of "lifting tongs". Lifting tongs have the gripping points angled quite a bit to dig into the bark when the log's weight is applied. A round may not have enough weight to activate the points. I use a small two-pound drilling hammer to convince the points into the log if it becomes an issue. Also, every once in a while the points will be sharpened. It is amazing how much better they hold when sharp.
A photo of your tongs would help.
Also, rounds tend to be difficult to handle with tongs unless they are used vertically on the end of the log. Using them horizontally in the center seems to cause the round to spin off the tong every time.
/ Logging tongs #3
Hi,
Good idea, maybe a large rubber band?
/ Logging tongs #4
I just sharpened mine and it help a lot. I use mine hooked to a chain on my loader. Have no problems now.
/ Logging tongs #5
Somehow I have collected several of the tongs including one that has handles supposed used for railroad ties. With large rounds and using the biggest set I drive one side in the round with a pin hammer [sledge hammer with cut down handle] as log as one side is in the wood the other will catch when picking with the bucket and chain.
/ Logging tongs
Heres tonghts pics it actually worked good on maple it doesnt stay in ash well i never lost a round tonight ive also learned to hook low to ground so its constantly pulling .any more thoughts its a little time consuming to tap the hooks in but sure in heck saves on the back
/ Logging tongs #7
I think your tongs are about one size too small. Hooks point down a bit in the second photo.
Bruce
/ Logging tongs #8
Id modify them with a spring. I know the ones used to grub brush are spring loaded and have a pretty decent bite.
/ Logging tongs
How do you tell what size you have (measure)?its 16 inch wood what size to get?
/ Logging tongs #10
Bruce
I'd have to agree with Bruce. You can see the tips on your tongs would let the round slip out. The tips should point toward the pull so that they seat deeper into the wood, the more pressure that is applied.
/ Logging tongs #12
Those are definitely "skidding" tongs, not lifting tongs. At least, that is the design. Obviously, in a pinch, they will lift.
The other thing is that tongs are made to go around the circumference of the log rather than as they are used in the photos. But...whatever works is the farmer's creed.
Here is a set of spring loaded skidding tongs:
Timber Tuff Spring-Loaded Log Tongs — 22in. Jaw Opening, Model# TMW-22SSS | Log Skidding| Northern Tool + Equipment
Here are lifting tongs (note the price!!!!!!!!!!!!):
LITTLE MULE Lifting Tongs, Timber Type, 5000 Lb Max - G1575944 at Zoro
Here are skidding tongs much like yours:
Roughneck High Carbon Steel Swivel Skidding Tongs — 17 1/2in. Jaw Opening | Log Skidding| Northern Tool + Equipment
Perhaps you can see the difference in design.
/ Logging tongs #13
Still can't tell the difference between skidding and lifting tongs. They both seem to have tongs angle up to dig in. Other than the swivel, what differences am I missing?
/ Logging tongs #14
Timber Tuff Spring-Loaded Log Tongs 22in. Jaw Opening, Model# TMW-22SSS | Log Skidding| Northern Tool + Equipment
I have a set of these or very similar tongs. They work okay but not great. The sharp points on the tongs are replaceable but they are only held in place by a half moon key. Sometimes you need to set the points into the log and you need to hit them with a hammer. All this does is pops off the half moon key and the points will fall out, then you are done until you find the point and the key. My advise is to buy a better set without the replaceable tips and half moon keys.
/ Logging tongs #15
The lifting tongs have longer and thicker points at a greater angle. The points will remain an angle when the tongs are spread. That way the lifted log stays attached to the tongs. They are also constructed out of heavier material.
The skidding tongs have shorter, less angled points. When spread, the points are parallel to the ground, or the log's surface, rather than pointed up. It can be seen in the photo of the round being lifted.
The skidding tongs are also designed to slip off if, say, the log being skidded hangs up on a stump. The tongs and the tractor are spared damage.
/ Logging tongs
Would any one try to heat up tips and bend em ??i use chokers for skidding
/ Logging tongs #18
Do what DOZERNUT said and hit one side with a four pounder a couple of times. You don't have to hit both sides most of the time. Don't heat them. The size you have should work fine for firewood length.
Pan
2025 Wolverine MSG-11-44W 44in Grapple Mini Skid Steer Attachment (A61572)
2025 Wolverine...
2018 Ford Explorer AWD SUV (A61574)
2018 Ford Explorer...
1998 KENWORTH W900L 6X4 TANDEM AXLE SLEEPER TRUCK TRACTOR (A59912)
1998 KENWORTH...
CATERPILLAR DP40 STRAIGHT MAST FORKLIFT (A64279)
CATERPILLAR DP40...
20023 KAWASAKI BAYOU 300 ATV (A64281)
20023 KAWASAKI...
2014 Kawasaki 70Z7 Articulated Wheel Loader (A61572)
2014 Kawasaki 70Z7...
