Do you touch up paint your tractor?
/ Do you touch up paint your tractor? #1
El Wood
Gold Member
Michigan
JD 3320
I've had my tractor now for a few years and there are some areas that need to be touched up. Do you touch up paint your tractor or implements? What steps do you use and what kind of paint?
Thanks!
/ Do you touch up paint your tractor? #2
Yes, and always JD paint.
/ Do you touch up paint your tractor? #3
Yes, I have been using the "new Kubota II" on my Kioti.. Small dings, I spray a little in the cap, and take a Q tip and dip it in the pool of paint, and carefully lay it in the ding or scratch.. Works well if you use care.
Thank you. For implements where some metal is exposed and a bit of rust, would you sand lightly and then paint?
/ Do you touch up paint your tractor? #5
Yes I would, and it the blemish was big enough, I would spray it with the can. Make sure the nozzle is working good (no sputtering) paint is well mixed (shake well) and distance at least a foot away from surface. Spray "lightly" while moving the can to lay down just a fine mist. Remember less is "more".. you can always lay several light coats, and it will look better than a heavy coat. Practice on some scrap if you don't have your technique down yet. I learned what little I know about painting with "rattle cans" from a boss I worked for about 40 years ago. He was an expert with a rattle can. We painted a lot of radio control heads (Motorola's mostly). and he could make them look like brand new.
/ Do you touch up paint your tractor? #6
I take them to the local sandblaster ... He's so reasonable .. Then I mix my paint 5:1 and spray them!!
/ Do you touch up paint your tractor? #7
Sand, Prime, then paint. For my implements I use rustoleum primer and paint with a HF spray gun. Tractor is still new. no dings or scrapes yet but I will touch them up when they happen.
/ Do you touch up paint your tractor? #8
I will touch up paint on the frame or a tiny scratch like others mentioned with a Q tip. I try not to do any major damage to need body work.
/ Do you touch up paint your tractor? #9
The tractor get JD green, the implements get Rustoleam...except for the RFM. That's a Frontier brand so I use JD Green on that too.
/ Do you touch up paint your tractor? #10
No painting on my JD2030, it's 40 years old and any painting would make it look like the whole thing needs painting.
I did do some touch up on the JD6415. The trucker wrapped chains on the front axle. I still have chain impressions in the paint. I used JD spray paint. I also repainted the PTO guard, straightened it first then painted. It looked like the top link had been dropped on it many times. The wheels need some touch up, but I figure they would be hard to make look good without painting the complete wheel. So the scratches remain.
/ Do you touch up paint your tractor? #11
Zebra, you can paint them wheels pretty quick.. Pressure wash, or bucket and rag with some detergent. I would steel wool/sand those scrapes and prime. When that is dry. Steel wool the whole wheel, then take a rag with some lacquer thinner on it to pick up the dust.. some masking tape on the edges of the tires then some newspapers taped on. Use short pieces of masking tape. Hit it with your rattle cans. The whole job should not take more than an hour. or so.
/ Do you touch up paint your tractor? #12
Grease the tire with a lite film and paint
/ Do you touch up paint your tractor? #13
I'm lucky, my Mitsu blue is Tremclad med blue which is available in qts and spray cans.
My rims are Tremclad aluminum color which I brush on. I like to keep it presentable but don't go as far as waxing but then hate rust.
/ Do you touch up paint your tractor? #15
Ok, maybe I'm odd here but I've never felt the need to touch up scratches in the paint on my tractors. If I did, I'd be painting more than working. My implements, well they usually make contact with the ground which removes any rust present. And any paint.
/ Do you touch up paint your tractor? #16
I guess I am one of those people that work my machine but will not abuse it. I have no problem sinking a plow in the ground and making it work or mowing grass over the hood. I try to avoid working in areas where my tractor will get scratched. Some people are picky about sports cars being nice and shinney and I'm that way about tractors.lol My tractors do get dirty and cannot help that but I just dont see a reason why they should get scratched. I stay out of the heavy brush or wooded areas.
/ Do you touch up paint your tractor? #17
Well we are talking about touching up dings and scratches on the hood and fenders, and parts that do not normally touch the ground.. Of course the bucket has rust and missing paint and is shiny steel by the end of the working day. I will spray the top of it maybe once a year to keep rust down, but I don't need rusty spots on the hood or fenders if it is easy to fix.
/ Do you touch up paint your tractor? #18
I honestly don't see that as much of an issue. Now mind you if it lived outside, I might want to keep the paint better but scratches or even chips in the paint are a fact of life if using the machine. It's not a car, it's a tool I use in less than friendly terrain. It generally goes where I point it, over and through things that might just scratch it. When mowing down invasives, I have to get close enough to trees that I'm pushing limbs out of my way. Doing the job effectively is more important to me than how pretty my tractor looks. Even a little surface rust won't keep the machine from running well.
2016 Toyota Tundra Pickup Truck (A61568)
2016 Toyota Tundra...
2018 CATERPILLAR 906M WHEEL LOADER (A62129)
2018 CATERPILLAR...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
FORD DIRT SCOOP (A62131)
FORD DIRT SCOOP...
2025 Hydraulic Trencher Skid Steer Attachment (A61567)
2025 Hydraulic...
2025 SKLP SK-PSJ220 Electric Jaw Crusher (A61567)
2025 SKLP...
