Do you touch up paint your tractor?
   / Do you touch up paint your tractor? #1
El Wood
Michigan
JD 3320
I've had my tractor now for a few years and there are some areas that need to be touched up. Do you touch up paint your tractor or implements? What steps do you use and what kind of paint?
Thanks!
   / Do you touch up paint your tractor? #2
Yes, and always JD paint.
   / Do you touch up paint your tractor? #3
Yes, I have been using the "new Kubota II" on my Kioti.. Small dings, I spray a little in the cap, and take a Q tip and dip it in the pool of paint, and carefully lay it in the ding or scratch.. Works well if you use care.
Thank you. For implements where some metal is exposed and a bit of rust, would you sand lightly and then paint?
   / Do you touch up paint your tractor? #5
Yes I would, and it the blemish was big enough, I would spray it with the can. Make sure the nozzle is working good (no sputtering) paint is well mixed (shake well) and distance at least a foot away from surface. Spray "lightly" while moving the can to lay down just a fine mist. Remember less is "more".. you can always lay several light coats, and it will look better than a heavy coat. Practice on some scrap if you don't have your technique down yet. I learned what little I know about painting with "rattle cans" from a boss I worked for about 40 years ago. He was an expert with a rattle can. We painted a lot of radio control heads (Motorola's mostly). and he could make them look like brand new.
   / Do you touch up paint your tractor? #6
I take them to the local sandblaster ... He's so reasonable .. Then I mix my paint 5:1 and spray them!!
   / Do you touch up paint your tractor? #7
Sand, Prime, then paint. For my implements I use rustoleum primer and paint with a HF spray gun. Tractor is still new. no dings or scrapes yet but I will touch them up when they happen.
   / Do you touch up paint your tractor? #8
I will touch up paint on the frame or a tiny scratch like others mentioned with a Q tip. I try not to do any major damage to need body work.
   / Do you touch up paint your tractor? #9
The tractor get JD green, the implements get Rustoleam...except for the RFM. That's a Frontier brand so I use JD Green on that too.
   / Do you touch up paint your tractor? #10
No painting on my JD2030, it's 40 years old and any painting would make it look like the whole thing needs painting.
I did do some touch up on the JD6415. The trucker wrapped chains on the front axle. I still have chain impressions in the paint. I used JD spray paint. I also repainted the PTO guard, straightened it first then painted. It looked like the top link had been dropped on it many times. The wheels need some touch up, but I figure they would be hard to make look good without painting the complete wheel. So the scratches remain.
2008 Ford F-450 Crew Cab Service Truck (A52377)
2008 Ford F-450...
Bomag BW 211D-3 (A47477)
Bomag BW 211D-3...
1999 CLEMENT END DUMP (A53843)
1999 CLEMENT END...
2013 Husqvarna YTH18542 42in Riding Mower (A51694)
2013 Husqvarna...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
