Custom hydraulic backhoe thumb
/ Custom hydraulic backhoe thumb #21
Very nice idea, and I am copying it, sort of, for my Kubota Excavator. I have all the major parts, and will build before I start a demolition job next month. Thanks for sharing the build. I'll document mine when I get started.
Bob
Thx, Bob
Many of those excavators already come plumbed for an AUX circuit at the
end of the dipper. You may even have more than 2500psi to work with.
You may get 7-8000 lbs of pulling force on the end of your dipper at the
thumb pivot....remember to build that weldment strong!
/ Custom hydraulic backhoe thumb #23
dfkrug
Excellent work on your projects! Nice 4 in 1 bucket also.
How did you size the solinoid valve on the hydraulic cylinder? I am redoing my thumb to a serrated jaw, so while I have it cut apart it would be nice to set up for hydraulics at the same time. Thank you
Slick
Thx for the pos feedback, Slick.
My tractor delivers a max implement flow rate of 8.3 GPM. I figured that
I needed a minimum flow rate for my valve of 4-5GPM. That is based on
the fact that I am rarely running at full engine speed and the valve is in
parallel with the curl cylinder so flow is shared. A dedicated AUX valve
should be sized to the tractor's max output or greater, generally. In my
case, small size was very desirable.
What tractor are you going to be using?
/ Custom hydraulic backhoe thumb #25
Hi dfkrug;
I have a kubota 3710 with a woods 9000 that runs off a woods pto pump which is rated @ 3.8 cubic inches. The manual says it requires 8-10 gpm @ 2400 psi. I guess about the same as yours.
Your tractor will do 7.8GPM at PTO speed, and your PTO pump puts out
8.9 at that speed (540). 8 GPM is likely to be faster than you want to
operate that hoe, so you are fine. Your design criteria should be similar
to mine if your solenoid valve is a 2-way valve for parallel operation. If
you go with a dual solenoid full diverter setup (4-way), I suggest you get
one to accommodate the 8+ GPM it might experience. BTW, there are a
bunch of those latter valves shown on various TBN grapple bucket
projects. Unfortunately they tend to be large valves and often require you
buy a manifold (base plate).
/ Custom hydraulic backhoe thumb #27
Hi dfkrug;
I will start looking for the same valve setup, I like the component performance that you describe, The fixed thumbs are tough because you have to be placed correctly to grab effectively. The excavator isn't so bad because it moves easier. Maybe down the road I'll have to replace the footvalve on the excavator from hammer stuff to thumb stuff. Thank you for your help!
Happy to help if I can. I used a rented excavator before and a right
foot valve controlled the thumb. It moved FAST. It also closed
when I pushed the pedal, and automatically opened when I let go. It
was slick, but it did not provide classical grapple action (parallel).
/ Custom hydraulic backhoe thumb #29
Not really a thumb but have any of you seen something like this
There was one at a banquet here last night and I was drawn to it like a moth to a flame. Sure could use it on all the stumps the last guy left me to deal with.
/ Custom hydraulic backhoe thumb #30
Hi Dave,
Sorry I didn't post sooner on your thread.
What a great idea and of course. a super build job you did.
The parallel action is fantastic. How is everything holding up? Are the function and use as designed working just as you thought? It has to be a pleasure to operate your new set up. I would be really excited about it with a lot of self satisfaction.
Great job Dave.
Rob-
/ Custom hydraulic backhoe thumb #31
Dave;
I called valve mfg direct, they had no problem shipping one to me. I emailed for a quote first, they are in Ct.
Direct from Hydraforce?! That's great news! They told me I had to go to
one of their distis. I would MUCH prefer to go manuf-direct. What did you
pay for this valve, assuming you used the same one I did?
It has worked so well that I used the same approach (and same valve) on
my 4-in-1 bucket. Notice that there are very few added hoses....I just
hate to snag hoses.
As for wear and breakdown....lets just say that I am glad I went to 1 inch
pins (I used 3/4" in my prototype). Many times I grab a rock and it breaks
in half, due to the pressure and the sharp hard "rock share" thumb tip I
used.
Thx, Rob!
/ Custom hydraulic backhoe thumb #34
I first emailed them for a price quote. They told me $45. +shipping and 3 weeks to get it. I called the guy tues 24th and he said they would make it from parts and send it much sooner. I'm in no rush anyways, thats 3 projects away.
/ Custom hydraulic backhoe thumb #35
Dave;
Pm'd you for 25 mm pin p/n's Thanks
/ Custom hydraulic backhoe thumb #36
This is an old thread, but I have a newer tractor, and one with a mechanical thumb on a BH77. Giving Dave credit, I shamelessly copied his idea on paralleling the curl cylinder. Works great! (thanks Dave). Here's some pictures and notes:
I used this 2 X 20 cylinder as it has adjustable port positions which I thought good in this app. http://www.baileynet.com/product/19560
Close up of Hydraforce solenoid valve. Had to special order from one of their distributors - they wouldn't sell direct. I had to use two fittings to attach it to cylinder as the SAE 8 to 6 90* was out of stock - When I get it, I'll remount and also install a bracket for the valve - it is probably sturdy enough if you don't bonk it.
Taken before wiring Solenoid.
I wanted the waterproof push button switch on the joystick. Switch from Amazon, aluminum bracket from my little machine shop.
Finished switch install, shrink wrap on joystick shaft to keep it clean.
I used a Powerlet jack and plug (also referred to as Bosch or BMW plugs - and may be still sold by JD dealers) to plug into the tractor's 12VDC. One neat "happy" was that Kubota, on the B50 series, supplies a wired plug end at the left rear of the tractor AND the plug is a match for the Powerlet waterproof outlet - - how cool is that?!
http://www.powerlet.com/shop-by-product/plugs-sockets-wire-more/PWRDIST
One little "oops" occurred at the rod end of the cylinder. I needed about .360 more width, so made two .180" spacers. However, once installed, the ram end didn't end up on the pin centered - - took both spacers on one side (shown) to fit up nicely - guess this is due to a slight misalignment on the dipper stick bracket from the factory.
There was probably enough slack between the 25mm pins and the 1 inch cylinder end holes so the ram would have centered, but I used .012" brass shim stock to make bushings which took most all the slop out.
Tested it picking up a big rock - works great! And no more having to get off the tractor to deploy or put away the thumb.
bumper
Nice pix, BUMP.
I don't know why a lot more folks don't do it this way. I posted primarily to show another way to do it, and for
people to copy at will.
Let's see what kind of protection you add to the valve. That is certainly a vulnerablity. Mine has never been
hit, fortunately.
/ Custom hydraulic backhoe thumb #38
The 2 X 20 cylinder I used, while having the correct stroke (10") for my app, is overall about 2" too short on the BH77, which has a welded on bracket for the manual thumb. i.e. with thumb fully retracted there's a couple of inches or rod still extended. And with ram extended fully, thumb is extended, certainly a usable amount, but not quite all the way (probably could go another 2". Works, but it could be better.
So, when I get the time, I plan to saw off the upper cylinder tube and weld in a spacer. It'll also give me the opportunity to correct the ram positioning issue (both spacers now on one side of ram as upper bracket is apparently not quite square with dipper). I'll weld the spacer to the cylinder first, then tack weld the spacer to its tube with cylinder mounted on the hoe - so I can get the alignment right.
bumper
/ Custom hydraulic backhoe thumb #39
bumper
Bumper-
I have a new BH77 and I am following your build here. Would you mind sharing the part number and supplier of that switch and valve? I will search amazon for the switch once you narrow it down for me and I'm not sure where you ended up getting the valve. Feel free to ping me directly if you would rather. I can't thank you and Dave enough for sharing this set up.
-MEA
/ Custom hydraulic backhoe thumb #40
MEA,
The valve is a Hydraforce SV08-24-6T-N-12DS
As mentioned earlier, I tried to order direct from Hydraforce, but no joy. They referred me to one of their dealers Hydraulic Controls in the S.F. Bay area 510-658-8300, who referred me to their branch in Yuba City, CA (closer to me). Called them and it wasn't in stock, 3 week wait and I flew over to Sutter County airport and they met me there with the parts!
Hydraulic Controls, I think, has outlets all over, so you might could find one close to you.
I used two 3/8 JIC female 1/4 inch hoses, one 24" and one 18" (stock lengths) from surpluscenter.com/Hydraulics/
I bought all the hydraulic fittings from Discount Hydraulic Hose
One particular part, the SAE 8 O-ring to SAE 6 O-ring 90 degree, I could only find at discount hydraulic hose:
O-Ring Boss (ORB) Union 90° Elbow part 6807-08-06
This goes from the cylinder (assuming you use the same one I am using, as it has SAE 8 O-ring flush ports) and the hydraforce valve has SAE6 ports. This fitting allows the valve to fit nice and snug (snugger than what I've shown in my pics - as this particular fitting was out of stock so I used two fittings to "get there"). I have the right one now and will install it when I lengthen my cylinder a little. (OCD . . . the cylinder works as is, I just can't leave good enough alone - it's a sickness :c).
BTW, you will be replacing the 3/8 JIC male to 1/4 NPT 90's on the BH77 cylinder with street T's 3/8 JIC 1/4 NPT
Plumbing is a piece of cake.
Oh, the switch I used is this'n: Amazon.com: Alpinetech 19mm 3/4" Waterproof Momentary Stainless Steel Metal Push Button Switch Screw Terminal Extended Button Normally Open 1NO: Automotive
bumper
2005 Freightliner M2 106 20ft. Reefer Box Truck (A61573)
2005 Freightliner...
JOHN DEERE HX14 - 14' ROTARY MOWER (A64276)
JOHN DEERE HX14 -...
John Deere 2155 Tractor W/ Loader (A62613)
John Deere 2155...
2018 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A65053)
2018 CATERPILLAR...
213063 (A64276)
213063 (A64276)
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
