boggen
Elite Member
- Joined
- Feb 22, 2011
- Messages
- 3,829
- Location
- Trivoli, IL
- Tractor
- SSTT (Sideways Snake Tain Tractor) and STB (sideways train box) tractor, dirt harvester
Using a simple manual ball shutoff valve on the TNT cylinders is a way to provide positive holding when needed but still allow float if desired. Another item that I find very useful is a remote position indicator showing the tilt cylinder position. This lets me see, at a glance, whether I'm running level or at a preset tilt angle. When running a back blade, for example, it lets me tilt slightly to gather more dirt on one side and then bring back to level to feather the dirt out all on the go.
manual shut off valve, now that is to easy! open it just a tad to slow things down. (acting like an orifice) to help make those fine tuning adjustments easier. open it up all the way for float like option through regular valve, and then shut it off for hold position. as long as the valve is rated for the PSI. ((normal stores menards, lowes, home depot, ace hardware,etc... do not normally sell valves rated for PSI that our tractors use, and will more likely exploded and fail quickly if they are used...needing to find a source online most likely to order a manual valve))
