XR4046
/ XR4046
XR4046H is to be delivered in the morning, I think I will take off a couple hours. Maybe go back to work...
I appreciate all the input, hope you guys steered me right. I think you have.
They are supposed to plumb the grapple first thing in the morning.
I did a lot of internet search and found almost no negatives. And I didn't know it but two friends already have ls tractors and like them.
/ XR4046 #42
Grapple buckets
Question for those of you using the grapple buckets, Is it possible to run the grapple bucket from one of the extra hydraulic ports on the rear of the tractor. One of the pros I see with the LS is the extra hydraulic valves that come on the back of the R and XR varieties. Looking at XR4040 to do clean up on an old neglected farm.
THX
/ XR4046 #43
Question for those of you using the grapple buckets, Is it possible to run the grapple bucket from one of the extra hydraulic ports on the rear of the tractor. One of the pros I see with the LS is the extra hydraulic valves that come on the back of the R and XR varieties. Looking at XR4040 to do clean up on an old neglected farm. THX
Yes, you just need around 13-15 feet of hose and couplings and you're all set.
/ XR4046 #44
How much would be considered a good price? Any advice will be appreciated.[/QUOTE said:
I just picked up a xr4046 Hydro, Loaded Rear Tires With Rim Guard, Added front one touch remotes for a grapple. $24,500
/ XR4046
My left front tire is rubbing the loader frame, like some others I read on here. I called the dealer and he sent me a picture from his phone, of the bolt to adjust.
But it looks like it is the bolt behind the axle he is telling me to adjust and mine is very short, the front bolt is much longer.
Also had a bad connector on the grapple, sprayed me real good, he is replacing that, as soon as I can get over there with it.
2020 Polaris Ranger XP 1000 UTV (A65579)
2020 Polaris...
2012 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2012 Caterpillar...
2250' of 5" Tile (A66408)
2250' of 5" Tile...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
8ft Rotary Cutter (A65579)
8ft Rotary Cutter...
2022 EZ-GO ELITE...
