Sodo
Elite Member
- Joined
- Apr 21, 2012
- Messages
- 3,321
- Location
- Cascade Mtns of WA state
- Tractor
- Kubota B-series & Mini Excavator
Some angle grinder attachments include "the nut" such as a wire brush cup. Others (like thin cutoff wheels) require the 5/8-11 fittings. So when you remove the fittings, and the 'nut' where do you set them?
I usually set 'em somewhere then knock them off the table. Because I'm grinding I don't hear them tinkle deep down into the scrap pile
I welded a 5/8-11 thread stub to a 5/16-18 bolt, to act as a holder for the fittings. It screws into the handle hole (I never use the handle on a 4 1/2" grinder). But anyway it's pretty easy to make with a MIG. And Mudd, it's not likely to cut parts loose on the freeway! Newbies could do this, and be successful (even if their welds never pass xray tests
). Some guys "could" do it with stick, and of course James would TIG it
This part could be molded out of plastic and would sell well, I think. MFRs should have moulded this thread stub into the grinder's plastic housing somewhere.
