A gift for your angle grinder
Status
Not open for further replies.
/ A gift for your angle grinder #1
Sodo
Elite Member
Cascade Mtns of WA state
Kubota B-series & Mini Excavator
Some angle grinder attachments include "the nut" such as a wire brush cup. Others (like thin cutoff wheels) require the 5/8-11 fittings. So when you remove the fittings, and the 'nut' where do you set them?
I usually set 'em somewhere then knock them off the table. Because I'm grinding I don't hear them tinkle deep down into the scrap pile :mad:.
I welded a 5/8-11 thread stub to a 5/16-18 bolt, to act as a holder for the fittings. It screws into the handle hole (I never use the handle on a 4 1/2" grinder). But anyway it's pretty easy to make with a MIG. And Mudd, it's not likely to cut parts loose on the freeway! Newbies could do this, and be successful (even if their welds never pass xray tests :D ). Some guys "could" do it with stick, and of course James would TIG it :D.
This part could be molded out of plastic and would sell well, I think. MFRs should have moulded this thread stub into the grinder's plastic housing somewhere.
/ A gift for your angle grinder #2
I like it :thumbsup:
/ A gift for your angle grinder #3
Genius! Soon to be copied for all of my grinders. Thanks.
SimS
Glad you guys like it. For DeWalt angle grinders you need an M8-1.25 bolt, and of course the 5/8-11 side is standard for all.
/ A gift for your angle grinder #8
I prefer to keep my grinder fittings in a top drawer of my tool box right next to the wrenches needed to take them off. Having the washer/nut is of no use without a wrench, so both stay together in the drawer so they are easy to find. I think with vibration of grinding the nut would likely find it way off the bolt and be lost anyway unless it is tightened with the wrench. JMO
NOTE: I almost always use the handle on my grinders unless I cant get it into a tight spot with it on. MUCH SAFER that way. Even 4" grinders have a pretty big kickback when the blade/brush binds.
Sodo - is there a particular reason you like opening threads with insults and half- insults directed at other members?
Well I may be a little defensive due to all the full-frontal insults as of late. It will pass I guess/hope once 120v becomes legal. If I insulted you Dave it was certainly un-intended! Sorry!
If you think James TIG is an insult - honestly just fun there, even though he's been grumpy with me. I was expecting a friendly reply like "you're right I'd TIG that". Mudd,,,,, well he's being a grump to my every post.
Dave, since you asked,,,,, I respect your replies but If you would like to make a change I think you had more than a few opportunities to ask those guys to cut it out before taking it up with me.
Back to welding?
Gary I can't remember the last time I used the wrench on those fittings I just tighten/loosen by hand. It sure doesnt seem like they will rattle off the holder.
/ A gift for your angle grinder #10
That's a fantastic idea there. I seem to lose things to my grinder as well.
Though what I really lose the most is my wrench to my grinder and have had to use a pair of channel locks to change the disk. Then as I set the channel locks down on the work bench I spot my grinder wrench. lol
Chad
/ A gift for your angle grinder #11
Yep like it... I have always two wire cutters, three tape measures, and two soap pencils laying around because they get lost in front of my face!
/ A gift for your angle grinder #12
that's what they invented aprons for .... (and shirt pockets , and ears )
as for the wrench , a big elastic round the power cord, about 2/3 towards the plug ... or a key clip lanyard to it and clip to a belt loop ...
/ A gift for your angle grinder #13
Yeah but I just don't look good in my wife's apron and I haven't pulled the trigger on a man's apron. Soon I will see the light though.
/ A gift for your angle grinder #14
I have a dedicated drawer for grinder suff... cutoff discs, grinding wheels, flap discs... whatever, so if I change from one to the other I will put the nut back in the drawer. The wrench stays in there too. The only thing is that the cup brush doesn't fit so that goes on a shelf.
I also rarely use the wrench.
/ A gift for your angle grinder #15
I also use dedicated drawers for organization of my tools. I also like having the handle on my grinders.
/ A gift for your angle grinder #16
I do the same and have even gone so far as to label the drawers to help me stay organized. Called 5s'ing I guess if you are into the Japanese methodology. But I don't put my tools back in the drawers while I am working... that happens at the end of the day/job!
/ A gift for your angle grinder #17
LOL, tried that (drawer) but somehow things still accumulate on the work bench(s) and on my table saw.
Have 2 of a lot of tools so that does not help either. (call me a tool freak)
2 grinders are a must! one setup for cut off, other for wire brush or discs.
Just can't pass up bargains, gen set @ $50? compressor @$50 or gas powered water transfer pump for $25 (c/w hose and fittings).
My big problem is I weld, do most mechanics, and enjoy woodworking as well. And need a bigger shop!
/ A gift for your angle grinder #19
That's how i have it too. I change the disc or what ever and drop the wrench and or nut back in the drawer. Or if out in the field, drop everything back in the job box, except when i drop it on the ground. Then i spend a while trying to find it. :rolleyes:
/ A gift for your angle grinder #20
Yep. My blades and wheels all get changed at the workbench and get stored in the cabinet under it, so I never have to look for them.
Agreed. I have come too close to "eating" the wire wheel several times even with a side handle on it to not use one. Also, even if I am not using it, a side handle gives me a safe place to grab the grinder if it comes loose when working one handed.
Aarin Z
Status
2025 Dingo Ditch Bucket Skid Steer Attachment (A61572)
2025 Dingo Ditch...
2012 Can-Am Spyder Motorcycle (A61574)
2012 Can-Am Spyder...
Caterpillar D7H Series 1 and 2 Dozer Service Manuals (A63117)
Caterpillar D7H...
2010 Workhorse Custom Chassis W62 Delivery Truck with Liftgate (A61573)
2010 Workhorse...
UNUSED WOLVERINE QC5-26-20G QUICK COUPLER 5 (A64281)
UNUSED WOLVERINE...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
