B2650 on the way
/ B2650 on the way
I did see a B3300SU while I was there and wow are the tires bigger on that sucker! I saw it at a distance and hmmmmm maybe someday I'll need a bigger tractor. I walk over and I was surprised to see the model.
/ B2650 on the way #42
That's basically an older B3200 but with bigger tires, no mid-pto, and a couple other tweaks that made the B3300 "special utility" package.
The new B3350/B3350SU, which is the same chassis/body as your 2650, has those bigger tires as an option. I'm sure they'd mount on a 2650 if you have tire envy..... ;)
/ B2650 on the way
I'd have liked to get the 3350, but after owning this tractor for a little while I don't think I really need the extra HP. The only thing I've noticed is when pulling onto the road to head a couple houses down to help a friend - I would accelerate with the HST pedal while increasing RPM's to get up to speed and it was slow to bring RPMs up. Simple solution is to just rev it up then start going. I'm sure the extra HP would eliminate that. But as far as hydraulic capability goes, this 26HP model is just as capable, and I need the loader function more so than PTO power.
And as far as tire envy goes, yes, it looks pretty cool. But, I'm not willing to make that explanation to the wife - she doesn't have tire envy LOL
/ B2650 on the way
Blew a hydraulic hose yesterday. Picked up a hose and scrambled for fittings today but it's an odd size so back to the dealer it goes tomorrow!
/ B2650 on the way
Yep, red line. Loader tilt back function apparently. Quick coupler threads onto the fitting crimped onto the hose - hose blew out right at the crimp. Dealer has been awesome, dropped off this morning and got a call before lunch saying it was ready. It was one of the hoses they replaced when it was in last week for the chaffing through. Must have just been a defective part.
So maybe when I pick it up this time I'll remember to grab some pics of the affected areas from earlier. And also the PTO setup, I'm curious how many other models/brands out there have the dipstick so close to the PTO shaft.....
/ B2650 on the way
It's been over a month and I haven't got any pics up yet that I've talked about, sorry about that! I've been really busy at work and at home, got a lot to do here before it starts getting too much colder at night so I haven't had much time for playing around. Hopefully I can steal a few minutes and get them taken and posted soon.
The tractor is now at 70 hours, did the first fluid/filter change at 62 hours. It was simple enough to do. The hours are flying by on this thing, it seems like I grease it all the time. Some of the grease fittings really don't need to be hit every 10 hours like it says, there's just not enough movement in some places, but it gets a little hit anyway. I really should be taking a lot of before pictures of what I'm working on.
I did actually get one pic taken, let's see if I can find it..... Made a slight mod on the tractor that should be good for about 5-10HP!!!! LOL
/ B2650 on the way
And one other thing - has anybody else noticed their steering wheel kinda floating? Mine doesn't seem to be oriented the same was when the wheels are straight. I'll notice the spinner is in a different spot after a while when going straight. Sometimes its at 2 o'clock, sometimes 7, or 11, who knows where it will end up. Is this common? Or is something not tight?
/ B2650 on the way #49
It's been over a month and I haven't got any pics up yet that I've talked about, sorry about that! I've been really busy at work and at home, got a lot to do here before it starts getting too much colder at night so I haven't had much time for playing around. Hopefully I can steal a few minutes and get them taken and posted soon. The tractor is now at 70 hours, did the first fluid/filter change at 62 hours. It was simple enough to do. The hours are flying by on this thing, it seems like I grease it all the time. Some of the grease fittings really don't need to be hit every 10 hours like it says, there's just not enough movement in some places, but it gets a little hit anyway. I really should be taking a lot of before pictures of what I'm working on. I did actually get one pic taken, let's see if I can find it..... Made a slight mod on the tractor that should be good for about 5-10HP!!!! LOL
Your spinner is installed wrong. It should go on one of the three "spokes" of the steering wheel. The black rubber side goes toward the center to make it level. The metal tab side lays flat on the wheel. You can flip over the black rubber part to vary the thickness and angle to match your steering wheel.
And it's the wrong color...
/ B2650 on the way
I've never had one before, and this came with no instructions :( That seemed to be the only logical fit for it there. I'll give it another try this weekend, hopefully get it installed right so I stop hitting my leg when I spin the wheel :)
And I thought the color was what added the HP? Like putting Monster stickers on your snowmobile was good for 10+/-?
/ B2650 on the way #51
The steering wheel changing position is part of a hydrostatic steering system. This setup has no hard direct link between the steering wheel and the front end. Perfectly normal.
I think you better find an orange spinner so you can get back that 5 hp that green one is sapping out of your machine. :)
/ B2650 on the way #52
That is just funny right there. And, I concur! :D
/ B2650 on the way
I got the spinner moved, much better! Still green though. Almost popped a wheelie in the back yard, had to idle it down a bit :D
/ B2650 on the way #55
If it won't crank when you go to use it I would suggest that JD suicide knob be removed tractors are very senstive:cool2:
/ B2650 on the way
Anybody know the deal with the wheel/tire sizes on these? For instance why does the B series have "balloon" tires as I call them, small rims and tall tires therefore a lot of sidewall - vs. an L series which has much larger rims and lower profile tires? Does that allow increased capacity on larger tractors? Or are they just trying to keep the smaller ones a little more squishy/comfortable for the homeowners since that's the market for the smaller tractors?
/ B2650 on the way #57
Good question. On my L I had an option of 26" or 28" rims, I went with the 26" because it was a wider tire option and slightly taller. My ford has the 28" rim.
/ B2650 on the way #58
You can get both types on the B3350 -- they have the small R4 option and the large R4 option (which happens to match the tires on my L3200).
As far as sizing between B and L, I'm sure it has everything to do with weight. The B models are feather weights.
/ B2650 on the way #59
Great comments here on this post - especially the issues you've had. I just pulled the trigger on a new B2650 myself. I'll take note of the issues you had and make sure to let my dealer know. I wanted a bigger one (L3301) but the war dept (wife) nixed that one. The L3301 was about another $6K too. Delivery on Friday (3 day total). Below is the tractor being set up. Apparently when they're delivered to dealers all boxed up in a crate. I was surprise to see that even the rear wheel lugs were not pressed in. Anyway, looking forward to pushing dirt around this weekend.IMG_9367.jpg
/ B2650 on the way #60
It's impressive seeing them all crated up, not much wasted space.
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
New Landhonor Skid Steer Utility Hitch Adapter (A62679)
New Landhonor Skid...
New 11'x19' Metal Garage Shed (A62679)
New 11'x19' Metal...
2008 MACK GRANITE KILL TRUCK AND TRAILER (A65643)
2008 MACK GRANITE...
New/Unused 76in Pallet Fork Extensions (A65583)
New/Unused 76in...
