John Deere LX178
   / John Deere LX178 #1
rgiord4123
Niagara Falls, NY
John Deere LX178
trying to remove engine from LX178 drive pulley wont come off crankshaft. electric clutch already removed. engine bolts are loose and i can see a large hex shaped nut above pulley against crankcase attached to crankshaft. Does this nut hold the pulley? what is the function of the nut? There is no set screws holding the drive pulley (or at lest any that i can see or feel)....
   / John Deere LX178 #2
I have a PDF of the Deere Tech manual for the lx178 you're welcome to. I'm sure the answer is in there. If you'd like it shootme your email
Joe
   / John Deere LX178 #4
sent just now
2022 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
2012 Mclaughlin V500LEHD Vac Trailer (A49461)
2012 Mclaughlin...
1996 Monon 45X96 Dry Van Trailer (A51039)
1996 Monon 45X96...
2021 John Deere 9570R Articulated 4WD Tractor (A50657)
2021 John Deere...
Lot of 3 Dell Desktop Computer (A48083)
Lot of 3 Dell...
3000 Gallon Black Poly Water Tank (A49461)
3000 Gallon Black...
