Black pipe or galvanized for shop air lines?
/ Black pipe or galvanized for shop air lines? #112
I did my shop in copper and have been very happy with the results. 84' of 3/4" along the top and four drops using 1/2". All my takeoffs rise vertically with a drain at the bottom of each drop.
/ Black pipe or galvanized for shop air lines? #113
Looks good! And :welcome: to TBN! Amazing there is 113 posts and 8180 views on the subject, eh?
/ Black pipe or galvanized for shop air lines? #116
OK Ill bite. or more like nibble lol Whats with the fancy 'door latch' there. I assume its to pull the door in with? Interesting design....
/ Black pipe or galvanized for shop air lines? #117
It's an over-center type latch that sucks the door up against the jam after it's been slid into place. The door is about 12' x 12' and hangs from a track. It's a metal skinned door, with steel channel frame, 1.5" thick. The door and latch system were existing when I moved here but I added rigid foam panels between the frame members of teh door to insulate. The wood you see is 1/8" luan plywood that I skinned the inside of the door with to protect the rigid insulation. I then had to drill a hole in the luan so the latch could still reach in and catch the lip of the door. One thing leads to another and soon you have a very expensive shop remodel.
/ Black pipe or galvanized for shop air lines? #118
After being a auto/motorcycle mechanic for almost 40 years, the best for the money in my experience has been black pipe. That being said, no matter what you need some method to drain at every low point. Also fairly cheap is an auto drain near tank, can set timer etc, depending on use. My issue with water has been the damage to very expensive air tools, even with daily air tool oil, enough water not only corrodes but I'm sure others have noticed overspeed when water hits. As you say, just another opinion. Haha
/ Black pipe or galvanized for shop air lines? #119
Water and debris destroy tools. That is why, if you are serious, you need to invest in a drier.
Clean, dry air= happy tools, and quality paint jobs.
And, yes it is possible.
/ Black pipe or galvanized for shop air lines? #120
I work for a large pipe company and our cost difference between 3/4 type L hard and 3/4 s40 304L ss pipe is .29 cents per foot. The ss pipe being the higher price. Just to throw another option in the mix. The ss pipe can be butt welded for long runs without any additional cost for couplings, and the drops could be welded or threaded. 3/4 40 304L pipe has a burst pressure of 16,143 pounds, using a safety factor of four, the safe upper limit of daily working pressure would be 4,000 psi.
2014 Ag Spray Schaben Sidedresser (A56438)
2014 Ag Spray...
Chance Quick Attach 60" Mulching Head (A60463)
Chance Quick...
STEPP SEALCOATING MACHINE (A59906)
STEPP SEALCOATING...
Giyi HWG72 (A60463)
Giyi HWG72 (A60463)
JOHN DEERE 5065E TRACTOR (A59823)
JOHN DEERE 5065E...
BOX BLADE (A58214)
BOX BLADE (A58214)
