3/4 ton mpg empty?
/ 3/4 ton mpg empty? #42
What mid size suv is rated for 9K
You are so full of it, it's unbelievable.
Ok, maybe not 9K but 8K. And all will tow that weight better than the Eco Diesel.
Don't forget also the Ram can't legally tow it's listed tow rating due to its low GVWR. 7500# is its real world limit and it's been proven to struggle with that getting stomped by both Ford and GM'S gas trucks.
The Eco-diesel is not a serious truck for work. It's for the guy who never tows anything serious and needs a little bed space from time to time.
Chris
/ 3/4 ton mpg empty? #43
Probably not much help, but my '96 ram 2500 ec lb 4x4 and 3.54 gears with 5.9 gas originally would get about 13, 14 under the right circumstances. Larger tires and a tired engine later it get 11... 8 mostly now though because it rarely moves anymore unless it's loaded down or has a trailer following it.
As much as I'd like to get a diesel, I will probably either put some work into this or will end up with a hemi or 6.0 chevy for my next truck. From what I'm hearing I guess I can't expect much improvement over my 13 or 14 from before... though I will have quite a bit more power at my disposal.
/ 3/4 ton mpg empty? #44
For a good reason. It tows less than a mid sized SUV.
Chris
Do you really believe that a truck with 240 hp and 420 lb-ft of torque can't tow anything?
Here is a review on the towing.
2014 Ram 1500 EcoDiesel Review: Towing and MPG Fuel Economy
Amazing how you guys can derail a thread simply to further your agenda of bashing other brands like the eco diesel and making up all kinds of stories about your eco boots engines when the thread is supposed to be about 3/4 ton pickups and fuel economy.
So according to your statements in this thread the eco diesel dodge tows less than mid size SUV's but the eco boost ford will pull better then a 1 ton dually with a diesel. Do you not see how ridiculous you guy act? it's obvious to the rest of us.
How many times have you pointed out which auto companies took money from the government? Seriously do you think it's over 100 times?
The act is worn out.
/ 3/4 ton mpg empty? #45
I believe it can't if there is not sufficient GVWR to obtain the proper tongue weight. If it were not for that it would be fine, just a little dogish for today's standards.
And yes, I will stand by my statement comparing a 15 year old diesel truck to today's best gassers. It's called progress.
Chris
/ 3/4 ton mpg empty? #46
And by the way I never derailed anything. I told him numbers for gas and diesel 3/4 ton trucks then brought up the Ecoboost as an option. My numbers seem to jive with what others are getting from their 3/4 ton trucks. The Eco-diesel RAM was not brought up till much later.
Chris
/ 3/4 ton mpg empty? #47
Did you read the text at the link you quoted?
our well-outfitted Laramie Long Horn 4x4 was rated to tow 7,300 pounds.
That doesn't fit what the OP is looking for. Not even close. So, let's just leave it at that and move on, eh?
The Ram ED is a 1/2 ton, right? It wasn't Diamondpilot that brought it up.
/ 3/4 ton mpg empty? #48
My 2013 regular cab, 4x4, 8' bed with a 6.0 gas will get around 14 to 16 on flat roads and no wind, at 65 mph. Any stop and start drops it to an average of 12.
/ 3/4 ton mpg empty? #50
fordmantpw - that's an interesting link. I'd be curious to know how many miles were on those trucks when tested. I've been able to get into the 14's on my 2500 HD but it ain't easy. Those guys made it sound like they just hit the A/C and went for a joyride. I also didn't see what type of fuel they ran, "real" or "corn?"
/ 3/4 ton mpg empty? #52
KiotiKowboy, don't you have larger tires on your truck? That makes a big difference.
That link is probably better at comparing the 3 brands against each other vs. what any one person should expect in the real world since everyone's driving style is different.
/ 3/4 ton mpg empty? #53
I agree
/ 3/4 ton mpg empty? #54
Note that the ford had the highest rearend
Yeah, I think that is a lot of the reason that the Ford fell so much when loaded compared to the others. If I were running empty most of the time, I would go with the lower gears.
EDIT: To clarify: lower numerically, higher gears.
/ 3/4 ton mpg empty? #55
Yes ... but .... in reality, they're not THAT much larger. I swapped out the factory tires/wheels and went with 19" Fuel Krank wheels and 33" all-terrain tires. The original tires were 31.9"
/ 3/4 ton mpg empty? #56
Well, that is 3.4% difference in circumference, so you are actually getting 3.4% better fuel economy than what you think (unless you had the speedo calibrated) since you are traveling 3.4% further than your odometer reads. At 14 MPG, that's a .5 MPG difference. A tremendous amount! :laughing:
That doesn't take into account the extra energy it takes to turn the larger, heavier, wheels and tires. That's probably good for another .5 MPG or so.
That sure is a sharp truck! :thumbsup:
/ 3/4 ton mpg empty? #57
Chris
You can pretend all you want. You guys derailed the thread from talking about 3/4 ton gas mileage to eco boosts and eco diesel neither of which are 3/4 ton trucks. Happens all the time. It's obvious to the rest of us.
/ 3/4 ton mpg empty? #58
Yep. Looks like that truck will tow 7-9k pounds depending on options. Your point?
So now you want to actually talk about the OP. Hilarious since you were one of the folks who derailed the thread in the first place.
SSDD.
/ 3/4 ton mpg empty? #59
I considered having the speedometer recalculated - more about not getting a nice ticket than anything else. Turns out, at least according to the dealer, the recalc is a programming change that has to be backed out for many warranty repair issues. I decided if I keep my speed below 80 on the gauge, it should be safe enough to avoid a hassle. At lesser speeds, the difference in MPH is not significant enough to care.
And - thanks :)
/ 3/4 ton mpg empty? #60
And - thanks :)
In reality, most speedos display 2-3 MPG fast from the factory anyway (although the odometer is spot on), so your speedo is probably about spot-on. Check it with a GPS and I'd bet it's within 1 MPH at 70. Your odo will still be 3.4% slow though, so when you sell your truck with 100k miles, it will actually have 103k. :)
2016 Komatsu WA320-8 Articulated Wheel Loader (A61572)
2016 Komatsu...
2016 FONTAINE VELOCITY FLATBED SEMI TRAILER (A61568)
2016 FONTAINE...
Kubota V3300-T-E2BG Turbo Diesel Engine - 3.3L - Pump Takeout - Tier 2 (A63689)
Kubota...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A61307)
2006 Magnolia Dry...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2021 Chevrolet...
