Tire Ballast
/ Tire Ballast #1
hd5
Missouri
MF2705, MF135 XR4046H
How many of you use fluid in your LS tractor tires? I have to have it in my 135 Massey or I can't do anything. I buy methanol at tire shop, dilute it and pump it in myself.
I don't know where to get beet juice and if it has any advantage.
Any thoughts? Methanol should be harmless to the wheels, right? I will never use calcium again...
I'm supposed to have a new XR4046H in a week or two. Installed grapple, and hay spear.
/ Tire Ballast #2
I am considering filling the rears on my XR3037HC. After using the loader and forks a few times it seems the rear feels kind of light. I am thinking of using either washer antifreeze or RV antifreeze. My local TSC store has RV AF on sale for $3 a gallon. I figure I need about 35-38 gallons per tire so that figures to $210. or so plus tax, plus an air / water fill valve. I have a 10% coupon for TSC so the price would be $189.
70 plus gallons of washer fluid (the good stuff) is about the same price. Estimating each gallon weighs between 7-8 lb. I'd be adding 490 lb at 7 lb per or 560 lb at 8 lb per gallon. I already have the pump so the fluid, valve, and my time is the only expense to me.
Beet juice / rimguard is a little heavier by weight but would more than double the cost.
Calcium requires tubes and if you ever get a leak it will eat the metal rims.
/ Tire Ballast #3
I've got anti-freeze in all 4.
/ Tire Ballast #5
I have a L&G tractor, I used Rim Guard (Beat Juice) for the following reasons. We mow a large acreage parcel with significant hills requiring both side angle as well as straight angles of attack. My wife and son are significantly lighter than me and they share in the mowing.
1)11 lbs per gallon VS 8 for water or washer fluid. 30% more weight
2)Non corrosive
3)Pet/wildlife friendly
I pulled the wheels and took them to the dealer. The dealer used a special attachment to do the filling. However, when re-mounting the front wheel, somehow, the idiot (me) installing put it on backwards. The stem rubbed against the axle and broke. I caught it before much was lost. I used a valve stem tool, from TSC, to remove the internal valve. Held the wheel over a tub to let it drain. Then installed a new stem from TSC. I used a hand siphon from Tractor Supply to re-fill the Rim Guard. The hose on the hand siphon fit snug enough on the stem to allow for re-fill. Every few strokes I would pull the hose off and allow the air to escape. Re-installed the valve in the stem. Anyway it worked and all is good.
Yes more cost, I needed 20 gallons total front and back providing 210 well placed LBs below the center of gravity of the tractor.. It rides like a dream, and is rock solid even on 30-40% grades. And I don't have to worry about my dog Titus eating anything, nor do I worry about my fellow mowers, who are LB challenged, being unstable on the hills.
/ Tire Ballast #6
I just bought 40 gallons of winter winshield washing fluid a K-Mart for $1.98 per gallon.
Eugene
/ Tire Ballast #7
You will be happy loading the tires.
My dealer will not sell a tractor w/o the rim guard.
The rear end does not dance around when using the bucket, and if you plan on moving large bales they will move the weight further out and increase the leverage.
It's not the end all be all as I still use the box blade as ballast when I'm going to go heavy or oversized.
/ Tire Ballast
I just talked to the dealer where I'm getting the tractor and he said they use methanol, the same as I buy undiluted at a tire shop. The last time I filled my 135 it only cost me about $50.00 for both tires. That was about 3 years ago.
The fill adapter is cheap and methanol is pretty safe. The only concern I know of is don't catch it on fire, i understand it burns invisible. But don't think it would burn diluted with mostly water.
/ Tire Ballast #9
What is the advantage of putting a flammable substance that weighs less than water in your ties?
/ Tire Ballast #10
But antifreeze is toxic and will polute the ground if you get a leak plus more expensive.
You're right, mis-typed after reading the original post mentioning anti-freeze. I've got washer fluid in all 4.
/ Tire Ballast
It doesn't freeze. I don't think it will burn as much water as is in it. I will find out tonight. When I get home from work I am going to drain a little from a tire and do a non OSHA approved experiment...
Besides I quit wearing ties a long time ago:) Hope you have since of humour and don't know where I live.....
/ Tire Ballast
I stopped by the tire store I get my tires from and he said not flammable when mixed with water. He said it would cost me about $1.50 a gallon. I looked up a chart and it takes a 25% solution to be good to -10 degrees. Found a chart at messicks. Takes 55 gallons for 17.5x24. So 110 gallons total, at 25% methanol would take about 28 gallons of methanol. Cost about $45.00 if my math is right...
/ Tire Ballast
Feel like I'm talking to self but, just conducted my experiment. Drained a few ounces into a tin can, dropped a match in it didn't burn. Poured about a tablespoon out on a steel beam and held a propane torch on it until it boiled away , did not burn. My conclusion is ... it doesn't burn.
I forgot to check the weight of pure methanol, but since the tire will be 3/4 full of water, I think it be sufficient or I hope so.
/ Tire Ballast #14
Methanol is 6.6ish per gallon.
Beet juice is 11 per gallon.
/ Tire Ballast
Is that put in? I just priced undiluted methanol at a tire store on the way home at $1.50 a gallon. Maybe I better hurry up and buy it before he raises his price.
/ Tire Ballast #16
I sure he is talking weight not cost
/ Tire Ballast
Boy do I feel stupid I think I will sneak out the back door of this thread and not come back....
/ Tire Ballast #18
If RV antifreeze is used can it be deluded or does it have to be straight RV antifreeze?
/ Tire Ballast #19
RV antifreeze is usually pre mixed and set for a certain degrees below zero. It can be diluted but that will raise the below zero set point.
/ Tire Ballast #20
If you have a Rimguard dealer near you, call them and have them give you a price per gallon and install if you can transport your tractor to them. My L3400 was $150.00 installed for the rears. My opinion, it was a cheap investment for added safety.
2007 FREIGHTLINER CL112 6X4 T/A MID ROOF SLEEPER TRUCK TRACTOR (A59912)
2007 FREIGHTLINER...
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
John Deere Gator (A64119)
John Deere Gator...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59904)
2017 FREIGHTLINER...
2019 PETERBILT 389 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 PETERBILT 389...
2014 CATERPILLAR 573C FELLER BUNCHER (A62129)
2014 CATERPILLAR...
