Any source for John Deere MX6 cutter parts?
/ Any source for John Deere MX6 cutter parts? #62
I agree with Zebrafive, if I have to do that with my MX6 at some point I will paint it Bushhog red and send a picture to my Deere dealer and corporate showing them the fix.
/ Any source for John Deere MX6 cutter parts? #63
hello all, my mx6 just failed the same way and was made in spain. I am interested in if Ken or any others have been able to get the bush hog gear box and stump jumper to work on the mx6? luckily I have a backup mower, although it is only 5', but I would like to get this mx6 back in working order for as cheap as possible. I guess I consider myself lucky to have had the mower for almost 10 years cause i would be pissed if it would only be 3-4 years.
/ Any source for John Deere MX6 cutter parts? #64
diat 150 Welcome to the group and will try to answer your questions.
surplus center in my 2011 edition had a gear box.B&P item 13-1486 Bush hog (@299.99)
the input shaft 1 3/4 20 Tooth 3: length.
Output shaft 1.35"dai. 18 T spline w/tapered root 3.4 length
The same item# 13-1486 (@199.99) has a input shaft of 13/4 input20 tooth BUT the out put is 2.35 18 tooth spline.
When I received and installed the gear box talked to local bush hog dealer and told him the size of stump jumper and blade bar needed and paid the amount 447.95 and when item came in the bar center hole was a to small. Now the problems.
Shipping one way for me from surpluss center by truck amounted to $160 and was o'k if had got the smaller out put shaft to exchange it the shipping cost was on be and not worth and 320 bucks itwould require . Talking to Bush hog local 100 mile trip not figured in they had a 260 used but looked good working condition . and so traded in all the ordered pan bolts knives and some additional cash purchased a 260 bush hog used but in good condition connected to my jd 4520 and bush hogged the 30 acres with out a problem.
The jd gearbox shaft I took the shaft to a local machinist and he said the type of metal it was not worth trying to weld and machine to proper size.
Jd wants a health fee for the shaft so my MX6 is tossed into my accumalated junk pile for the time can locate the replacement.
All this said good idea but the total cost begins to add up to either purchase another jd gear box and cut clover and panseys or buy another rotary cutter from local dealer .
It is a sad day when a reputation for good farm equipment is exchanged for profits.
ken
/ Any source for John Deere MX6 cutter parts? #65
ken
Well said Ken
/ Any source for John Deere MX6 cutter parts? #66
ken
so you ended up not being able to get the bush hog stuff to work on the mx6 it sounds like because the output shaft on the available surplus gearbox is now too big?
I just hate to see the mx6 body go to waste. its in great shape. luckily I have a heavy duty alamo industrial shredder as a backup, but it is 5 foot instead of 6. I might try and get someone to reweld or build me another shaft, but I dont want to spend more than a few hundred. I guess Ill keep my eyes open for another on craigslist..... but I can guarantee it wont be another John Deere.
/ Any source for John Deere MX6 cutter parts? #67
Would be interested in what pieces, prices and modifications are suggested for this repair. I have one of these and like it but am a little concerned over the common shaft failures on the MX6 like I have.
/ Any source for John Deere MX6 cutter parts? #68
deere5105,
Know how you feel as I have an MX6 too, while it is still okay I have given all of this some thought. While I am not happy about it I finally concluded that if mine does break it is cheaper to fix it for $1500 than to buy another complete unit. As I understand it you have to change the gearbox and shaft for the new model.
/ Any source for John Deere MX6 cutter parts? #69
deere5105,
I have pondered this decision for some time, but am happy with the performance of the cutter and can't really justify spending equal repair dollars just to sale and buy another on a "possible" failure. However, I would be interested in learning of all possible repair options "if" this does occur. Recently had an issue where I bent the drive shaft between the front and rear end and managed to get it repaired/replaced locally for hundreds less than a new one through JD.
/ Any source for John Deere MX6 cutter parts? #70
I HAVE A MX 6 BUSH HOG , I SNAP THE PINION SHAFT ABOUT 3 YEARS BACK , REPLACE GEARBOX , SAME THING LAST WEEK , TALK WITH JOHN DEERE DEALER THEIR ANSWER TO THE PROBLEM IS TO UP GRADE TO NEW TYPE THAT HAS A NUT ON STUMP JUMPER PAN , I BELIEVE THE PROBLEM WITH OLD TYPE IS THAT THE BOLT ON THE STUMP JUMPER PAN WORK LOOSE AND THE BECOME LOOSE ON THE SHAFT AND THE MOTION SNAP THE SHAFT.
HOW TO FIX IS TO MAKE SURE THE BOLT IS TIGHT AND WELD A PIECE KEY STOCK ACROSS STUMP JUMPER BOLT AND PAN.
JOHN DEERE SAID CANNOT GET THE SHAFT ANY MORE, SO THE UPGRADE IS $1629.00 FOR GEARBOX,PLUS $700.00 FOR BLADE AND STUMP JUMPER PAN.
I NEED THE DOWN SHAFT IF ANYONE HAS ONE
/ Any source for John Deere MX6 cutter parts? #71
kkeg Thought the gear box from year 2010 was warrenty covered. and box before were having the problems.
Both Spain and China boxes are breaking same type of shaft . where the keeper ring is cut into the shaft.
I tossed the MX6 with maybe 20 hours of use. on junk pile and purchased a 286 Bush Hog Brand for price of J.D. gear box.
Some Day the bean counters of John Deere will wake up . realize losing customers over a dollar is still lost business.
ken
/ Any source for John Deere MX6 cutter parts? #72
ken
:thumbsup: That's what I'll do when the shaft on my MX6 shears.
/ Any source for John Deere MX6 cutter parts? #73
I have a 2004 MX6 Cutter. I have snapped the shaft off in the exact same place as yalls!!! Anybody have a better solution to this ordeal yet? Im considering purchasing a new cutter! What brand yall recommend? I have a 4610 JD.
/ Any source for John Deere MX6 cutter parts? #74
OleMiss...If you just look up at post #71, you'll see that a 286 Bush Hog was bought to replace that broken J.D. cutter - at the cost of a replacement gearbox no less!
/ Any source for John Deere MX6 cutter parts? #75
Odds are the slip clutch is rusted tight and the shock loads are breaking the shaft.
I've been cutting 2-3" trees and an occasional hidden rock with my MX6 on a 55HP JD 1640 for years.
Only mishap to date was a golf ball sized stone that was launched forwards. I had just let my young 15 lb turkeys out of the pen to free range around the yard. They were 75 yards away but that 150MPH stone bulls eyed one bird in the head, dead.
/ Any source for John Deere MX6 cutter parts? #76
Im going to get a new Bush Hog Brand cutter. Will the BH25 be to heavy for my 4610 JD?
/ Any source for John Deere MX6 cutter parts? #77
I mentioned tossing the MX6 and bought a 286 bush hog. and the question of slip clutch keeps coming up. so took the shaft and slip clutch off the JD gear box and installed on bush hog gear box. This was close to 4 years ago and each year clear 80 acres of brush vines and tall grass . so far each time the bush hog loads up by brush the slip clutch slips like it should.
So feel maybe just a chance it might be the gear box failure was cause.
This has been a cooler and wetter year so brush is growing fast I am putting about 4 hours a day clearing the growth. not even looking back when the clang lets me know a rock had been picked up. or hear the change in bush hog when slip clutch is slipping.
ken
/ Any source for John Deere MX6 cutter parts? #78
We lost our Mx6 too. Was only 4 years old with 20 hours on it cutting grass. Worse cutter we've ever owned so back to Bush Hog we went. We still own 2 286's that work as new and are over 10 years old now.
/ Any source for John Deere MX6 cutter parts? #79
Well, I have a MX8 with Spain boxes and an MX5 with a China box. No problems so far.
That said, are the failures less for the smaller diameter blade sets?
/ Any source for John Deere MX6 cutter parts? #80
Well, I have a MX8 with Spain boxes and an MX5 with a China box. No problems so far. That said, are the failures less for the smaller diameter blade sets?
Seems I see more MX6 issues than others. No real data though just what I remember. Probably more of those sold though too.
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
ASSET DESCRIPTIONS & CONDITION (A59908)
ASSET DESCRIPTIONS...
Hays LT1 Tender (A61307)
Hays LT1 Tender...
2004 International 4400 Single Axle Dump (A62613)
2004 International...
2015 John Deere 210 GLC Excavator (A60352)
2015 John Deere...
2018 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A60352)
2018 GMC Sierra...
