Homebuilt PTO SPADER..hmmm
   / Homebuilt PTO SPADER..hmmm #1
RitchElbe
Gold Member
Millers Creek, NC
John Deere 4100 / Jim Dandy
I am debating a new project. A home built rear pto driven spader. (see attached link) My thoughts are..2 crank shafts from a inline 6 cyclinder, use the push rods with spades brazed on. Tie the crank shafts into a limited slip rear end for power from the pto...any thoughts?
https://www.youtube.com/watch?v=Db4fWUwilXI
   / Homebuilt PTO SPADER..hmmm #2
Push rods won't be strong enough.
Use the connecting rods instead.
Might not be long enough.
Differential should work if you can get a low enough ratio. Nevermind the limited slip, just weld the spider gears on a standard one.
   / Homebuilt PTO SPADER..hmmm #3
I watched several of the spader videos. One showed a digging depth of 20cm, almost 8 inches. That would need a very long stroke engine crankshaft.
Bruce
dunno why I said push rods....but I was already pondering extensions on the piston rods..
   / Homebuilt PTO SPADER..hmmm #5
I've never seen anything like that... what's the advantage over a normal tiller?
My understanding is better water absorbing qualities to the ground. No serious hard pack layer, easier to break the ground up as opposed to a tiller which of course means less wear and tear on the tractor
   / Homebuilt PTO SPADER..hmmm #7
It also doesn't invert the soil, leaving the soil structure largely intact.
Sounds like an interesting project!
You could use a standard auto crank and get the displacement you desire by using a lever to raise & lower the shovels.
   / Homebuilt PTO SPADER..hmmm #8
Would not be a susceptible to vine wrap either. My experience wit tillers is that vines, grass, etc. like to wrap up in them Vs being chewed up and buried.
   / Homebuilt PTO SPADER..hmmm #9
Your 4100 will never lift a spader made of crankshafts that allow a foot of stroke, even a Cat C18 only has 7.2 inch of stroke.
https://www.youtube.com/watch?v=ycadZjZ1Vnw
This video explains a rotating spader with harrow roller, tech talk starting at 2:00
you can mount some readily available rigid cultivator teeth (or ripper legs) and their duckfoot spades to a shaft and drive it with a tractor final reduction, either a planetary or a portal style of an old WD45 or so... Then drive the input shaft with a chain drive for the correct speed (you cant put a big sprocket on the main rotorshaft because it will drag through the earth and the big gearbox cover will make messy work)
   / Homebuilt PTO SPADER..hmmm #11
That's super interesting CNC Dan!! THANKS for posting that!
I wonder how much more expensive one of these is compared to a 3pt tiller? And if you were cultivating garden spaces for a fee, would "conservationalists" pay a little more to have their garden processed with one of these as opposed to a regular tiller since it's easier on the soil?
   / Homebuilt PTO SPADER..hmmm #13
This is very cool! But being you already have a tractor would you not get the same results from a chisel plow? I am 100 percent interested in this build tho!
   / Homebuilt PTO SPADER..hmmm #14
These things ain't cheap!! I found a website for a company in California that sells these. I gave them a call with a follow up email. Here's the exchange...
Hello,
We spoke on the phone today regarding your spaders. I have a 35 hp (approx. 32 hp at the PTO) Deere tractor. I am looking for something about 60 wide to cover my tire tracks.
Any information, including pricing and availability, that you could provide to me would be appreciated.
Best regards,
-Mark
Mark,
You have two to choose between: The MT 1700 from Falc at $11,500.00, and the Gramegna V84/6/BC/170 at $10,414.00.
The Falc would ship from Dixon, California. Freight would be extra.
The Gramegna would arrive at New Jersey, and there would be some land freight to you.
Please provide your full postal address so I can send brochures.
Until then,
Eugene F. Canales
Ferrari Tractor CIE
   / Homebuilt PTO SPADER..hmmm #16
never started paying attention, till after to late going through videos....the overall "maintenance" of dealing with each spade and the gear boxes per each spade, looked more nightmarish towards the last couple videos.
most likely wanting a "cover" and side panels, to keep everything "dark" so as not to expose fungi to bacteria to sunlight and killing them off..
it looks like the spades were "self cleaning" in a sense and removing wet sticky mud off the spades after each time it dug down.
my concerns would be in "drought years" and dealing with hard cracking soil, that is cracking due to not enough rain. and trying run a spade unit. seems like a lot of extra abuse would happen.
   / Homebuilt PTO SPADER..hmmm #17
Is not a good idea to work soil under these conditions, whatever the implement.
   / Homebuilt PTO SPADER..hmmm #18
   / Homebuilt PTO SPADER..hmmm #19
Gee, look at the welding splatters on 1:03, even just that will put me off of the Celli...
Dont blame me for being patriotic, but this Imants spader is costing less and giving way more capacity, just look at the speed:
https://www.youtube.com/watch?v=ionGau-UnHY
Way faster. But that is a rotary spader. Works more like a tiller.
Sure is fast though.
   / Homebuilt PTO SPADER..hmmm #20
I own a Tortella 005 120 (47" spader from Italy) so here is my 2 cents.
Pros:
Trash burial - go into a field of annual rye cover and you can just punch it down into the ground. If you go over that after with a shallow tiller you get a nice seed bed with good organic matter incorporation
Hardpan cracking - my Tortella spades 10" deep and does an awesome job of breaking the hardpan created by other implements and tilling. This does improve water flow through the soil.
Cons:
Expensive - New my Tortella would have been $7500. Thankfully I didn't have to pay for it.
Hard on Equipment - I know they say it is easier on the tractor then a tiller but that is total crap. I run mine on a 32hp Kubota and it shakes that poor little tractor to pieces. No matter how hard I tighten the sway chains, after 2 hours of spading the slacks are loose and the top link has gotten longer. My 48" Sovema tiller on the other hand is so smooth I can hardly notice it, unless I hit a rock or root. If the tortella hits something strong enough it will jump right out of the ground and slam back down.
The spader definetely has its place, especially if you do a lot of cover crop incorporation,and it is very well built, but it is a limited tool. I used to use it for almost all my tillage, but now use a cultivator and very shallow rototilling unless I need to incorporate a lot of organic matter. I kinda got carried away with it, but it looses it advantage if you use it too much.
I am all for building your own equipment, I do it all the time, but seeing how heavily built my Tortella is, I would worry about using engine components.
A few questions:
1. Do you have an idea on how wide of a track you want to cover?
2. How deep do you hope to go? Any less then about 7 or 8 inches and I would likely be using a disc. They are cheaper and far faster.
3. What is your primary use going to be?
I think spaders are great for their specific purpose, but I would have a few concerns building my own. The 47" sometimes works my 32hp tractor and weighs 800#. You need the weight to hold it down and although the 4100 could probably lift it, I think it would struggle to run it. Im not really trying to discourage you, just my own opinion from experience, but if you were just after breaking up the hardpan I would find a subsoiler your tractor can pull or hire it out once a year. A good cultivator can break up most hardpans created by rototilling and the subsoiling would do a good job cracking the hard ground below that without disturbing soil structure too much.
If you still want to build then I support 100% and if you need any dimensions or photos from mine just let me know.
2024 Bobcat T86 (A60462)
2024 Bobcat T86...
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A59231)
Year: 2017 Make...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
2024 Bintelli ActivEV Pulse Electric Cart (A59231)
2024 Bintelli...
