Homebuilt PTO SPADER..hmmm
   / Homebuilt PTO SPADER..hmmm #1
RitchElbe
Millers Creek, NC
John Deere 4100 / Jim Dandy
I am debating a new project. A home built rear pto driven spader. (see attached link) My thoughts are..2 crank shafts from a inline 6 cyclinder, use the push rods with spades brazed on. Tie the crank shafts into a limited slip rear end for power from the pto...any thoughts?
https://www.youtube.com/watch?v=Db4fWUwilXI
   / Homebuilt PTO SPADER..hmmm #2
Push rods won't be strong enough.
Use the connecting rods instead.
Might not be long enough.
Differential should work if you can get a low enough ratio. Nevermind the limited slip, just weld the spider gears on a standard one.
   / Homebuilt PTO SPADER..hmmm #3
I watched several of the spader videos. One showed a digging depth of 20cm, almost 8 inches. That would need a very long stroke engine crankshaft.
Bruce
dunno why I said push rods....but I was already pondering extensions on the piston rods..
   / Homebuilt PTO SPADER..hmmm #5
I've never seen anything like that... what's the advantage over a normal tiller?
My understanding is better water absorbing qualities to the ground. No serious hard pack layer, easier to break the ground up as opposed to a tiller which of course means less wear and tear on the tractor
   / Homebuilt PTO SPADER..hmmm #7
It also doesn't invert the soil, leaving the soil structure largely intact.
Sounds like an interesting project!
You could use a standard auto crank and get the displacement you desire by using a lever to raise & lower the shovels.
   / Homebuilt PTO SPADER..hmmm #8
Would not be a susceptible to vine wrap either. My experience wit tillers is that vines, grass, etc. like to wrap up in them Vs being chewed up and buried.
   / Homebuilt PTO SPADER..hmmm #9
Your 4100 will never lift a spader made of crankshafts that allow a foot of stroke, even a Cat C18 only has 7.2 inch of stroke.
https://www.youtube.com/watch?v=ycadZjZ1Vnw
This video explains a rotating spader with harrow roller, tech talk starting at 2:00
you can mount some readily available rigid cultivator teeth (or ripper legs) and their duckfoot spades to a shaft and drive it with a tractor final reduction, either a planetary or a portal style of an old WD45 or so... Then drive the input shaft with a chain drive for the correct speed (you cant put a big sprocket on the main rotorshaft because it will drag through the earth and the big gearbox cover will make messy work)
AGT Mini Excavator Attachment Set (A50123)
AGT Mini Excavator...
CATERPILLAR CS563 SMOOTH DRUM ROLLER (A51246)
CATERPILLAR CS563...
Duetz Power Unit (A50120)
Duetz Power Unit...
2015 INTERNATIONAL LF687 (A53843)
2015 INTERNATIONAL...
90018 (A48082)
90018 (A48082)
UNUSED AGT MXCRT23 STAND ON SKID STEER (A51247)
UNUSED AGT MXCRT23...
