Bridge Question
/ Bridge Question #1
jmason42
Ontario
Kubota
Hi All,
I have a quick question for you all regarding bridges. I have searched the forums, but have not yet been able to find my answer.
I am in need of a new bridge over a creek at my property. The span is approx. 2 - 3 meters, and the bridge will experience occasional vehicular traffic in the form of pickups/suvs etc. A culvert is not really an option, as beavers would **** it up every season and cause other problems.
I plan on sandwiching some 2x10's (or 2x12's) together to form two beams, and then just use some 2x6's for the deck. My question is as follows: how many 2x10's (or 2x12's) do you think I would need to sandwich together to support the weight of a full-size pickup? I will be using carriage bolts to lug them together, and will use a ladder-style construction. They will sit on two footings of either concrete or timber - I have yet to decide.
Thanks in advance!
John
/ Bridge Question #2
I'll be watching this thread as I have to do exactly the same thing. Do you have a chainsaw mill?
At this stage I'm planning two concrete footings either side with reo bar/ or threaded bar that will take the bearers, probably 3 depending on the thickness. Then I'll run with 3"x 8" hardwood sleepers with one run long ways down each top edge to stop any of the deck timbers twisting and to give the tyres something to bump against if they run off course. ( stop them from going off the side of page bridge).
That's what I'm think of at least, but interested to see what suggestions you get.
/ Bridge Question #3
have you considered a box culvert? ( it's not like regular squash pipe..e tc.. )
/ Bridge Question #4
I was going to do the same before I sold my Jeep (5,200lbs), so I asked my engineer buddy, he said 4-2X8s per beam would be enough for a 12' span. Assuming your truck is prob 50% more weight so if it were me 5-2x10s or 4-2x12s would be what I'd do.
I ended up building one for the fourwheeler using 3-2x8s per beam... it still may see a Willies or small buggies. I'm sure it could take 4,000lbs.
/ Bridge Question #5
Several questions
What is span , there is 50 percent difference from two to three meters
What type of lumber will be used
To prevent rotation of beams , they will need to be braced
What is the heaviest vehicle to cross bridge
What type of foundation will be used
Have much flow is in creek,
What damage will occur if creek is blocked with debris at
/ Bridge Question #6
Without knowing the wood characteristics, we can assume typical softwood lumber and be conservative on the fiber bending stress. For a 10' span, each 2x10 can handle 1300 lbs, while each 2x12 can handle 1900 lbs. I'd probably put a 2X factor of safety to err on the side of caution. Be careful to select good boards, as knots or defects can seriously reduce the wood's capability as a beam.
Carriage bolts are not usually rated for structural use. Use regular bolts and washers instead.
/ Bridge Question #7
:welcome:
A quick thought for you're beams, good condition RR ties installed on the footings with the wide dimension vertically @ maybe 12" centers with 2 of them at about 80" (or the track of your truck). Deck with p.t. lumber.
/ Bridge Question #9
Ns gearhead
How are your boards attached at the end of the span?
As you drive a heavier vehicle across bridge , it appears the deck would fail before the beams would
Nice bridge for a four wheeler
/ Bridge Question #10
I'm not an engineer, but I have to question the soundness of that design. Both the beam layout and the manner in which is the secured to the banks.
/ Bridge Question #11
bridge abutments.jpgwing wall footer.jpgAt the other end of the spectrum, we're building two houses and the county requires a bridge that will support a fire truck (they also made us put in sprinkler systems but that's another story). The 10' walls sit on 3' footers. Span will be 20'6", with 15 12"x12" oak beams. Not sure what decking will be but asphalt will cover everything (also a county requirement).
Charlie
/ Bridge Question #12
The exact distance of the span is very important in determinin what sized lumber you need and how many you will need. Then determining what you will build as af footing to support the load of the bridge is needed to understand how the lumber will be assembled. It doesn't cost more to do it right, but it will cost a lot more to cut corners and do it quick.
Eddie
/ Bridge Question #13
Ns gearhead
It's made with 3.5" gal. framing nails. I made it like a deck, just beefed up where it needed to be. The layout should see the path of the tires travel over the decked beams, so in that instance the deck doesn't have to be that strong... although some room for error is always good. For example mine's decked with 2x6. When I built it I had an offroad Tracker that weighed about 2,500lbs and was right around as wide as the bridge. If I'd driven 4" off center the 2x6's could have supported that... much more and I'd be off the bridge anyway. LOL The center only needs to be strong enough for foot traffic or a dirtbike (in my case).
/ Bridge Question #14
Here's what I've been using for the passed two years
I think I'll be ok ;)
Oh, and that little 2x8 frame, 2x6 deck, 12x6' bridge cost me just under $500
/ Bridge Question #15
Can't help on the design but have a few suggestions .???
Treated lumber
There are proper bolts for timber construction.
Consider glueing plus bolting the beam members together.
Consider flanges on the beam. They will add to the allowable bending stress.
Lateral bracing, execially at center span.
After the decking add longitudinal planks where the tires go.
Consider gluelam construction with narrower boards stacked vertically and glued and with a deeper depth. Can be cambered. Can be bought also.
The rings provide more surface bearing area than a bolt.:)
/ Bridge Question #16
Here is the thread where I built a similar size bridge:
http://www.tractorbynet.com/forums/projects/289644-my-bridge.html
Beam tables are available on line to check the capacity. My thoughts: I would have the beams supported directly by the footings and not depend on connections or bolts. You can add more beams for the cost of a few bolts. Any bolts/nails, use galvanized or stainless. Use treated wood but realize the strength is slightly less than untreated wood.
Flanges were mentioned above. Not appropriate for wood construction. Flanges don't add much vertical strength, They are only meant to stop buckling on narrow section members. For timber construction use blocking instead to prevent buckling or lateral movement.
/ Bridge Question #17
I think the OP needs to clarify some things for us.
The span is critical! No beam calculations can be done without it. Using wood over a 9 foot spam vs a 12 span really effects design criteria. Torsional rotation becomes more likely, weight of the decking will become more of a concern, and the way you transfer the load to the foundation might become a factor. If the wood fibers begin to crush at the foundation, it makes no difference what the beam calculations say. Generally, the deflection controls the span btw. Also, if this bridge is going to be in service for a long period, water needs to be considered so the wood stays as dry as possible. If the lumber is laying in puddles, of water, trouble won't be to far away.
/ Bridge Question #18
Charlie
A good idea, IMO. When I was fire department pre-plan officer, I made the decision that we were not going to take our trucks across a certain bridge. The house did eventually catch fire and we had to fight it with the trucks on the Interstate using tankers and long lines.
Of course, if you can get a 20 ton fire truck across, you are on the road to providing access to moving and delivery trucks, etc. I've had a number of times where trucks were afraid to cross our (concrete) bridge but we have had loaded concrete trucks across it many times.
/ Bridge Question #19
Reader than the shear
The flanges add a lot to the sectional modulus of the beam. Simple span the bending modulus will usually be greater than the shear stress.
2013 International WorkStar 7600 T/A Dump Truck (A64556)
2013 International...
Large Cow (A64557)
Large Cow (A64557)
AKS ALASKA STRUCTURES PORTABLE TENT (A63276)
AKS ALASKA...
UNUSED FUTURE SG45 HYD STUMP GRINDER (A65055)
UNUSED FUTURE SG45...
2018 MACK LR633 6X4 T/A GARBAGE TRUCK (A66091)
2018 MACK LR633...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A64553)
2023 Caterpillar...
