X500 box/driveway scraper?
/ X500 box/driveway scraper? #1
Tjc50
Tiffin, ohio
None
Anyone with experience know if an x500 has the sack and ability to rip up a gravel drive? I need to rip my top layer to repair pot holes that I'm tired of patching. Thanks
/ X500 box/driveway scraper? #2
If you are talking about a John Deere X500 lawn mower then I'd recommend not using it for that. A compact tractor would be a better choice.
Just looking for more reasons to jump up to a scut! The ol lady doesn't see the need but she has zero clue about the amount of gravel,dirt, and firewood I will be moving in the next few years. I'm not against renting equipment but would love to own my own. Any experience with a bx or 1 series while driving through woods ? Be nice to have one piece of equipment to mow/fel/remove snow/ repair driveway etc etc etc
/ X500 box/driveway scraper? #4
Your gonna struggle with that JD X500.I have a JD X740(diesel)and would not attempt it.
/ X500 box/driveway scraper? #5
It's important to right-size the equipment to match the task. I'm not familiar with Kubota but can say the JD 4300 I've had for 12 years has been excellent. Note that the JD 1 series has a special offer going on until July 31. Buy 2 implements and get 60 months free financing plus $1000 off price.
Compact Utility Tractors Special Offers on JohnDeere.com
/ X500 box/driveway scraper? #6
I've scraped some potholes off of the drive by adding a good bit of weight to the front blade setup on my x500, it wasn't a good idea, but it can be done if you can keep traction.
Think i have researched enough to prove I do need a 1 series or bx
Myself haha didn't mean for that to come off wrong . I just need to quit being cheap and get what the jobs I want to do call for . I would hope a bx or 1 series are up to the task of pulling a box blade or land pride down a gravel drive if not let me know.
/ X500 box/driveway scraper? #10
What do you plan to do with a tractor besides the driveway? Lawn work and/or woods work, ground work it can make a big difference in what is the best to buy.
/ X500 box/driveway scraper? #11
If looking at a BX, you should look at the B series Kubota's. They have much more ground clearance so you aren't getting into the famed HST fan shredding if you get an unlucky stick sticking up. I don't believe them to be much more expensive than a BX. If a bit bigger size doesn't matter to you, I would be looking at the B23xx or B26xx series. I don't think you gain anything in the B29xx series unless you plan to do some heavy PTO work as the tractor isn't heavy enough to utilize much more than the 23 HP. They also have much larger tires for a bit smoother ride and better traction. My daughter has a B2930 with MM mower and mows her yard with it, son in law uses the tiller and middle buster to make up his garden all without removing the mower deck.
I think you would be much happier doing ground engaging work with it rather than a 1 series JD or a BX.
/ X500 box/driveway scraper? #12
Don't see any reason it wouldn't if set up right. Filled tires,chains,wheel weights,sleeve hitch, and a Brinly box blade with two 18" digger shanks mounted on the tongue. I set the shanks to dig 2-3" lower than the blade to dig through the potholes.Work the drive after an inch of rain.
video:
There's a curveball! Haha. Well I would go larger but this is primarily a mower. 2 acres with acces to 7 acres of woods to cut up dead/fallen trees. I heat with wood 24/7 in the winter so it will be used to move firewood. Entire house needs regrading around foundation and I have a nice patch needing re graded and a trench dug for water flow direction. Also going to have a 20'x30-40' garden once I remove some ornamental trees and their root system . But 90% of the time this will be a mower and snow removal machine
Also anyone think the mahindra max25 is to heavy for mowing ? Mowin is obviously a big concern for me. I plan on this purchAse to be an all around property maintainer.
Another quick question . I have read a lot of negative feed back on kubotas 3pt hitch control. This is important to me as I intend to keep my driveway in good shape with this purchase. Is the 1 series that much more superior in this department?
PORTA POTTY (A68842)
2014 HIPOWER 310 GENER (A67714)
2014 HIPOWER 310...
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A66736)
2022 Chevrolet...
2007 PETERBILT 379 (INOPERABLE) (A67714)
2007 PETERBILT 379...
1987 CAT D8N (A68134)
225/70R19.5 Tires - Set of 2 (A68134)
225/70R19.5 Tires...
