Interesting.
/ Interesting. #1
Shield Arc
Super Member
Port Orchard, WA.
John Deere, 4200
I found some interesting reading. Both from Miller.:confused3:
/ Interesting. #2
They don't say that the 3/16" weld will be cold and weak just that it will weld it:stirthepot:
/ Interesting.
The Miller calculator says it takes 140 to 150-amps to weld 1/8-inch steel.
/ Interesting. #4
I know with the MM252 I almost always use the next up settings as I find the reference card on the front of the welder too cold for my taste.
Sent from my iPhone 5s 64Gb using TractorByNet
/ Interesting. #5
You mean the interesting reading where they recommend 70S-3 and say it is common and economical? :mur: Or where it says the welder is rated for 90 amps at 20% duty cycle?
/ Interesting.
I find it interesting that Miller sales says the machine can weld up to 3/16-inch thick steel. And output range is 30 to 140-amps. But the Miller calculator says it takes from 140 to 150-amps to weld 1/8-inch steel.:confused2:
/ Interesting. #7
Seems I remember the common caveat goes something like this "...with proper prep and multiple passes.."
Not very specific and leaves too much grey area to quibble over.
Personally, the part I generally dislike is when any manufacturer lists the duty cycle of a 140 amp machine as 20% at 90 amps and drawing 20 amps 120v circuit.
But often they don't list the duty cycle or amp draw at 140 amps.
Some I've seen list the max output at 10% duty cycle and 28 amps draw.
/ Interesting. #8
Most 140 amp welders really ARE about 90 amps. They can spike up to 140 amps, but most of the time you will see them running on a meter around 90-110 amps. Ever wonder why there is no digital meter on these things?
2023 BOBCAT T66 R-SERIES SKID STEER (A62129)
2023 BOBCAT T66...
2001 FORD SUPER DUTY F350 4x4 UTILITY TRUCK (A59912)
2001 FORD SUPER...
KUBOTA L4610D TRACTOR (A64280)
KUBOTA L4610D...
(8) 18X8.50-8 GOLF CART TIRES & RIMS (A64281)
(8) 18X8.50-8 GOLF...
26ft. Truck Box Body (A61573)
26ft. Truck Box...
UNUSED WOLVERINE 6' FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
