john deere 5410 4wd
   / john deere 5410 4wd #2
sounds like it
   / john deere 5410 4wd #3
need more info
I haven't been very good here. I'm new and am lost. My jd 5410 has lost the 4wd . I don't know if its the linkage or something much more serious. Has anyone been into the rearend and/or encountered this?
It popped in reverse on the right side of the seat and then wouldn't 4wheel. just 2wheel.
It popped one time while in reverse on the right side of the seat and then wouldn't 4wheel. just 2wheel.
   / john deere 5410 4wd #7
Dale I have a copy of the John Deere technical manual if you'd like a copy of it. Shoot me your email if you want to copy of it it's in a PDF file.
   / john deere 5410 4wd #8
could be a roll pin broke. you need to move the lever back and forth and look and see if it is turning the shaft its on. if not looks like roll pin is sheared, if shaft turns its probably internal
Thanks about the rollpin. I'll check that tomorrow.
2015 Chevrolet Tahoe SUV (A50324)
2015 Chevrolet...
2014 Ford F550 4x4 Bucket Truck with Versalift SST40 - 45FT Working Height (A51039)
2014 Ford F550 4x4...
2021 Case Trident 5550 Spreader (A51039)
2021 Case Trident...
2022 JOHN DEERE 332G (A50854)
2022 JOHN DEERE...
2015 MACK GU 713 (A50854)
2015 MACK GU 713...
Bus (A50323)
Bus (A50323)
