A/C Welding
/ A/C Welding #1
SoGeorgia
South Georgia
Ford 600, Ford 3000, Allis Chalmers B
From the good 'ole days.. funny, from this video you'd think DC arc welding would be extinct.
/ A/C Welding #2
One of my favorite videos :)
I don't mind welding on AC at all - no arc blow and welds right into corners with little rod manipulation needed.
For AC I'm fond of 7014 rods, 6013 are fine too - but not Horbart ones, they spatter more than I like.
Washington Alloy is available locally and weld nicer :)
/ A/C Welding #3
Heck if you listen to the mig guys go on about their glue guns you would think stick welding is antique and dead anyway
/ A/C Welding #4
Truly spoken like someone who does not own a MIG...
Every process has its place and application.
Sent from my iPhone 5s 64Gb using TractorByNet
/ A/C Welding #6
Never said Mig didn't have a place or application . In fact thats pretty much my point Wire welding has its place and application and within its bounds nothing else is as efficient . However it isnt the end all be all answer to every welding question .
Edited to add ( tongue in cheek )
Not even if it plugs into the outlet in the bathroom , or hooks to your car battery .
/ A/C Welding #7
Never said Mig didn't have a place or application . In fact thats pretty much my point Wire welding has its place and application and within its bounds nothing else is as efficient . However it isnt the end all be all answer to every welding question . Edited to add ( tongue in cheek ) Not even if it plugs into the outlet in the bathroom , or hooks to your car battery .
When you refer to "guys go on about their glue guns" you are saying that MIG does not provide sound welds which is incorrect.
I enjoy the challenge of running nice sound welds with a stick but for my applications MIG is the go to process. I am by no means a professional welder but do enjoy welding and have done so for 20years plus now.
Shield Arc got me onto running my MIG beads as hot as possible and it does make a huge difference on the strength of the weld.
/ A/C Welding #8
Way to set up a straw man . I said nothing about weld quality at any point in my post .
There is an issue of new/inexperienced guys managing to make good looking but weak welds with wire before and until they learn to set up the machine . Its worth remembering that I didnt bring that issue up , You did . All i have done is poke a bit of fun at the " mig is the end all best welding process " folks and the " how i power my mig" group .
I in fact do own a little mig , and pretty much despise it . When i have stuff worth running wire on i haul it up to the neighbors place and use his big miller and nicer shop to run it up . However i am rehabbing a farm/ranch and the majority of MY welding is done out in the field where the wind blows , materials might not be clean, or could well be magnitised , I cut and weld material at times 2" thick . In short my welding goes a bit beyond the conditions and materials that are suitable for a reasonably affordable wire welder , much less the practical limitations of shielding gasses . I dont ( yet ) have a tig setup but do have a few ideas on projects that are talking me into getting one and learning tig for the precise heat control it affords .
If your life and projects lend them selves to a wire squirter being your primary or only welding tool , then good for you !
Mine doesn't so lets not pee down my leg and tell me its raining free migs that will do what i want/need to do .
/ A/C Welding #9
FarmDad before CV engine drives came out in the early 1980s we ran self shielded flux core on CC engine drives. Before the Northridge earthquake in California we ran mostly T-11 wire. Now a days it's pretty much all T-8 wire here on the west coast which requires CV.
Here is some 1/16-inch Hobart Fabshield 21-B ran with a 1966 engine drive, and an LN-25. If you ever get to the point where you need to do a lot of welding fast, there is a whole world of self shielded T-11 wire out there that can be run outside.;)
/ A/C Welding #10
Shield , I realize this and if i run across a CC suitcase setup cheap enough i will nab it just to have if no other reason . My old AEAD miller would be a fine power supply for one and at times it could be nice just to squirt weld , but not often enough to justify the $$ i have seen them sell for so far around here .
Besides , i have reached the stage in life that the only things fast are the ones you would prefer to last for a while . Changing rod and chipping slag really dont hurt me none and i got a lot more time than sense anyway LOL .
/ A/C Welding #11
I'm all for stick welding:thumbsup:. On the job time is money, so it's wire feeders all the way.
You may luck out and get a good deal on an LN-25, but on the whole they go for $400 to $700.00 used. You might have better luck finding a deal on an LN-22, because they're so out dated. The wire is hot all the time, and you're limited to the 14-pound coils of wire only. But they are tough as nails. I've seen them fall 40-feet, and work just fine.
/ A/C Welding #12
I in fact do own a little mig , and pretty much despise it . When i have stuff worth running wire on i haul it up to the neighbors place and use his big miller and nicer shop to run it up . However i am rehabbing a farm/ranch and the majority of MY welding is done out in the field where the wind blows , materials might not be clean, or could well be magnitised....
What kind of little mig machine do you have? Throw some Hobart 0.030 or 0.035 E71T-11 fluxcore in there and you might be pleasantly surprised at what that can add to your welding arsenal from a capability standpoint. Machine is much more portable too. Although flux core is admittingly not as nice as welding with a gas bottle, the flux core does add a bit of oomph to a small machine.
The little wire feeder will excel the metal between 12 gauge and 22 gauge. Much thinner than that and you need the bottle for like 24 gauge to 28 gauge). The little wire feeder will also excel as filling excess gaps or for use as a pseudo 3-d printer (adding metal in space where there is otherwise nothing for building something via add a metal mode).
I have a Lincoln SP-135P 115 volt mig machine. Although, I do have a gas bottle, I never use the bottle for all the same reasons you listed above (exception being magnetized metal in your list which is a problem unto itself). Basically, I use my little wire feeder on any thin material 1/8" thick and thinner. Use either my Miller Thunderbolt AC225/DC150 or my Everlast PA-300 DC (both 220 volt) stick welders on the thicker metals 1/8" thick and above.
For manetized metals: The Miller Thunderbolt on AC will get the call as long as the metal is not too thin for stick process.
Took my unused mig bottle filled with argon and bought a 17V tig torch ($45) which either of my stick welders can run scratch start. Nice to play with, but none of my projects are suited to using it as they all like your projects. Only way I could use it would be inside a building at a sit down type workbench where I could brace myself on the workbench. I do not have above said workbench or a nice workshop and since none of my projects are suited to using - so I am only out $45 which is no big deal. My most likely use for the tig torch would be as an improvised sheet metal cutter since I do not have a plasma cutter on thin sheet.
/ A/C Welding #13
My little pos mig is a 110 cambel housfed or whatever that i was given many years ago for fathers day . Its really not worth messing with but sets in the shop so i can point to it and assure the kids that i still have it LOL .
If / when i get a tig it will go in the basement workroom with the little mill and lathe i have All the projects for it/them would be small enough that i could get them downstairs without issue and that gives me the calm air for the process . I really want to set up with hf AC tig so i can weld thin Aluminum. I could do scratch start tig or mig either one in the shop but at this point just dont have the justification to spend the money as there are plenty of other things need done and fixed before i do much leisure tinkering .
/ A/C Welding #14
Does all feeders are able to run off a stick welder?
A little off topic here but MAN!!!! I was watching that thing with headphones. @ 1:57 :eek:
/ A/C Welding #15
My little pos mig is a 110 cambel housfed or whatever that i was given many years ago for fathers day . Its really not worth messing with but sets in the shop so i can point to it and assure the kids that i still have it LOL ....
Okay if that is the welder that I think it might be then it is NOT the world's greatest 115 volt wire feeder, but not necessarily what I would call a total lost cause either. (A total lost cause is those Harbor Freight $99 wire feeders and the like from other unscrupulous retailers. Those are a total lost cause because they output AC output and there is not a single fluxcore or mig wire designed to work with an AC output wire feeder. Wire feeders whether mig or flux core is a DC only process by design and nature. Stick welders are fine on AC, although more limited, as there are at least rods designed to work on an AC output stick welder).
Look at the machine output sticker on your Campbell Hausfeld and see if your unit outputs DC. If it does then it is not a total lost cause. If DC output then pick up a 2lb spool of Hobart 0.030 E71T-11 at TSC or Rural King (costs $19.99 reg price but can be found for 16.99 on sale). Unfortunetley, 0.035 flux core might be too much for that particular Cambell Hausfeld machine. Still I run 0.030 E71T-11 in my Lincoln SP-135 95% of the time and it does fine although it will also run 0.035 equally as well.
Anyway remember to switch the polarity inside the machine for the flux core. I think you just might be pleased. You already have the welder and you likely not to get rid of it since a gift from your kids, you might as well get some use out of it. Choice between that lowly Campbell Hausfeld and a even the most expensive $5000 stick welder on some 16 gauge metal (1/16" thick) and I will pick that lowly Campell even with flux core in it compared to me having to do it with the stick process. Dirty rust metal is not as big a hassle with flux core either compared to mig mode.
In short use that wire feeder where your stick machine does not work so good and you have just expanded the thicknesses of steel that you can successfully weld. My guess is that unit will do best on 12 gage down to about 22 gage.
/ A/C Welding #16
You need a voltage sensing wire feeder to run off a CC machine. Some suitcase feeders are both CC and CV compatible. You usually can't weld with lower volt short circuit transfer because the volts will be too low. Arc volts need to be around 23 or so for them to work properly. Fine for flux-core.
John Deere 400 (A64119)
John Deere 400...
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
2019 Mack Granite Tri-Axle Dump w/ Lift Gate 006043 (A62613)
2019 Mack Granite...
Landhonor Mini Skid Steer (A60352)
Landhonor Mini...
2021 Ford F-150 4x4 Single Cab Pickup Truck (A61573)
2021 Ford F-150...
LILLISTON 8R ROLLING CULTIVATOR (A63291)
LILLISTON 8R...
