Filled my rears. WOW
/ Filled my rears. WOW #41
Do you think the weight from filling the tires is worse than the weight that would be on them with full load on the FEL?[/QUOTE]
Not at all, but I don't ride around with a full load on the FEL all of the time, and when I do, I am careful steering it. I was just thinking of the extra weight that the steering knuckles had to push or pull with the tractor stopped or barely moving.
/ Filled my rears. WOW #42
I have a MF GC 2600 SCUT. I asked the dealer to fill all four turf tires with RimGuard when I bought it. I have some rather steep sloped areas that I mow, plus I do snow removal with the FEL and backblade. I have also used the FEL a lot, moving around 80 tons of black dirt and stone for landscaping and a driveway extension. I have no real traction issues, and I am glad to have the extra weight down low on the slopes.
Even loaded, the turf tires don't rip up the lawn. I do have a slight concern about compaction when driving over the same piece of lawn when moving dirt and rock from a pile, but a got a core aerator, so I think I am ok there.
/ Filled my rears. WOW #43
some things not mentioned.... is... 4x4 and mfwd drive tractors. were filling front tires could add beneficial traction.
2wd tractors would filling fronts be of any benefit? i am guilty, with that green goop, that is suppose to seal leaks if ya get a thorn or nail in tire. in my front tractor tires.
bush hogging / rotatory cutter on rear of tractor more so if it is a 3pt hitch type. some added weight in front can keep them front tires on the ground, when ya raise the bush hog. or other heavy weight and/or long attachment in back.
have not seen mention of overall extra weight and taking toll on bearings / front axles / front end drive train for 4x4/MFWD tractors. beyond noting manufactures not suggesting it in manuals. taking guess due to extra load would be extra wear on all the mechanical parts, causing quicker wear / failure of things.
/ Filled my rears. WOW #44
well, time for MYTH BUSTERS to check out all the theories...oh, wait, nothing blows up...dull TV.:laughing:
/ Filled my rears. WOW #45
Maybe they could load the front tires with C4????:eek:
New/Unused Quick Attach Landhonor Hydraulic Winch (A65583)
New/Unused Quick...
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
2006 Mack Granite CV713 Dumping Flatbed (A62679)
2006 Mack Granite...
STIHL HT131 POLE SAW (A62613)
STIHL HT131 POLE...
PVC PIPE FITTINGS (A64276)
PVC PIPE FITTINGS...
ATTENTION PLEASE READ (A64119)
ATTENTION PLEASE...
