Flail Mower Help with Selecting a Flail Mower
/ Help with Selecting a Flail Mower #1
1026mrg
VT & NH
JD 5095M
Am strongly considering a flail mower over a rotary mower for our fields in VT.
More compact, does not stick out so far behind the tractor.
Less likely, I think, to fling things.
Would appreciate insight/perspectives on the following....
1) Quality manufacturers of flail mowers.
2) Benefits of hydraulic offset. Is it worth it? Who makes the best?
Will be putting on the 3pt hitch of a JD 5095M. Tractor is 95hp. PTO is rated at 80hp.
Will likely need at least 84" cut width to ensure the cut is as wide as tires. Do I need to go full tire width or am
I better off to be slightly inside the tires?
Will be using the mower for fields, meadows & food plots. In some areas, growth can get a bit thick.
Thanks in advance...
/ Help with Selecting a Flail Mower #2
88" Alamo but they aren't cheap by any means. I think they might even make a 96" now. 95 HP is lots. You can run an Interstator with hyd. side units in addition to the rear unit with 95 HP.
/ Help with Selecting a Flail Mower #3
Hello 1026mrg,
A flail mower will contain anything it hits and be carried over the
flailmower rotor and then fall back down to the ground.
You are also protected with the V belt drive which will smoke V belts
when the mowers flail mower rotor stalls.
Now on question number one:
All the American and European built flail mowers are of excellent quality in manufacture and design
with the European models using forward debris guards as standard equipment.
IF you have the room to manuever a larger towed or integral mounted flailmower
you will be much better off and you will spend less time mowing.
With your mule you have decision to make as far as mower type
only because of the power you have available.
You can run a wider crop shredder with side slicer knives and have an excellent
cut with a two inch mowing height.
Now on question number two the issue comes down to the type of mowing period.
A hydraulic offset attachment for a flailmower comes down to the quality of the
hydraulic components and the quality of the chrome of the hydraulic cylinder as
a lower quality of chrome coating the cylinder rod will wear sooner and leak sooner.
A mower that is set between the wheel width will reduce the chance that you will clip something
and break pins.
Ninety nine percent of the issues is the type of knive a shredder/mower can have wide scoop
knives or side slicers.
Narrow you needs and then come back and ask more questions.
there are manay manufacturers and importers of excellent
integral and towed flail mowers .
With your mule you could use a 12-15 foot crop shredder with ease.
Decide if you want a crop shredder or a mower
a. a crop shredder will work more quickly for you and will last along time
b. a wide finish mower will also work well but a finish flail mower will cost more
c. crop shredders are built heavier and will outlast you current mule .
There are many new and used crop shredders available on tractor house and
I suggest you look there simply to see what is available and you can purchase
a used flail shredder in good condition.
I would check the John deere web site for crop shredders as well as the Hiniker home page
as well as the many others that are on the internet as at least 30 manufacturers make flail shredders and flailmowers.
Its an either or proposition and your money. I would check tractorhouse as you will find many units for sale and they are easy to repair.
Please see responses below in blue bold.
Thanks, I have been able to find a few, but certainly not all. Here is my list so far:
Caroni, New Holland, Rears, BEFCO,
Cabe, Land Pride, Gearmore, Alamo
[/B]
If you know of any others, please let me know by reply or PM.
A large (wide) mower is likely not in the picture. Some of my fields are back in the woods
and I can only access them on fairly narrow logging roads. So, width will have to be
within the wheel width or slightly wider.
I am not sure that I understand your point above.
Most of the crop shredders that I see online are pretty wide and would be too wide
for access reasons.
and break pins.
Needs are for mowing fields and also for mowing food plots. Mow clover during growing season. Mow
other annuals, (e.g., soybeans, brassicas, sorghum, corn) prior to plowing and discing for next planting.
Currently someone else does this for us with a brush hog, (rotary mower). But I want to start doing it myself
and in the researching different mower options, I thought that a flail mower might be a better tool. Also will use
it when mowing brushy areas to convert to planted fields or meadows. Some are accessible from our main drive.
Some are back in the woods and can only be reached via fairly narrow logging trails. I do need a decent cut on the
fields & meadows, but by no means a "backyard or golf course fine cut".
Crop shredder sounds like it would be great, but I really can't go 15' wide.
Per your earlier point I would be better off either right at, or slightly under
rear wheel width. Call it 7'-8'.
Deere does not offer any flails with hydraulic offset. Also their smallest (width) crop shredder, is 15' wide.
/ Help with Selecting a Flail Mower #5
1026mrg - One of the things you mentioned in the followup is the ability for this mower to cut brush when converting to field use. Based on that I think you need to consider the diameter of the brush you're cutting . Many orchards use flails to cut up pretty good size prunings in the winter. So you might ask around. Also consider what flails are well supported in the area. I know for the northeast you can readily find parts and support for Rears(OESCO) and Ferri(JS Woodhouse dealers). I have a Ferri mower that I use for my vineyard and it has served me well for 1 season so far. My orchard buddies tend to have the heavier Rears units. Here's a link to both Ferri .... Ferri America - World Leader In Mower Technology ...and Rears .... FLAILS-- Rear's Manufacturing ........Gary
Thanks....
The Rears units look particularly interesting...
The have flail mowers as well as choppers that are as narrow as 7' in cut width.
...wonder what the pricing is like.
Will shoot them an e-mail.
1026mrg - One of the things you mentioned in the followup is the ability for this mower to cut brush when converting to field use. .... I know for the northeast you can readily find parts and support for Rears(OESCO) and Ferri(JS Woodhouse dealers). I have a Ferri mower that I use for my vineyard and it has served me well for 1 season so far. My orchard buddies tend to have the heavier Rears units. Here's a link to both Ferri .... Ferri America - World Leader In Mower Technology ...and Rears .... FLAILS-- Rear's Manufacturing ........Gary
/ Help with Selecting a Flail Mower #7
Thanks....
They are well made units and thus cost a little more but not out of line with others. One benefit is they are designed and manufactured in Oregon.
/ Help with Selecting a Flail Mower #8
Adding more to the discussion;
IS your mule 1000 or 540 RPM?
Hiniker offers a 16 foot wide flailshredder that can be equiped with a end towing and hydraulic lift kit keeping the entire mower within the rear wheels of your mule.
This also allows you to have a highway towing kit with marker lights for adequate illumination during
transport at night if you need to tow it at night or in the daylight hours.
The Hiniker side slicer knives are hardened like thier cup knives so mowing in different conditions is not an issue.
You will also at the same time be able to tow the flailmower
with a flexible Power Take Off shaft to mow or have a three point
mount for an integrally mounted mower so thats smoething to think about.
I would also check the Deere web page to see if they have an end towing option for their shredders(sorry i have not prowled their mower pages in along time so I do not know if they have an end towing option for their line of crop shredders).
Thanks,
See response below in blue bold.
540 RPM
16' would be too wide. Some of our fields are back in the woods & only access are narrow logging trails.
I understand about the hydraulic lift kit. It is really a matter of compromise between max useable mowing width and
access/maneuverability. Some of the fields have nooks, crannies & access points that need mowing but are pretty tight in
terms of maneuver space.
Great thought, but don't really have to tow it since all the acres are continguous and accessed by private road
or trails.
The Hiniker models look very nice, but minimum cut width is 15'. That is great for large ag fields, but too large for my needs.
Most of the mowing will be on meadows & food plots. The one model that may work is a bit too narrow. Looking for something with
a cut width of 7' min to 9' max.
Deere has some nice units, but none of them have hydraulic offset.
/ Help with Selecting a Flail Mower #10
Thanks,
Just so I am on the same page here.....
1. Your telling me you have a private road that you can travel on for all your
mowing needs.
2. Your also telling me any and all of your mowing needs will be less than
fifteen feet wide every where you mow in perpetuity?.........
3. You are unable to use a 15 foot flailmower with a hydraulic end towing assembly
making its towing width less wide than the narrowest adjusted width of your stock 5095 tires?????????
The only real option you have is a "Vrsimo Roadsider"
Model RSS 300-96
96 inch cut flailmower with side shift of either 12 or 18 inches.
UNLESS you look at the excellent Italian or Czech
rear mounted folding flailmowers.
Like I said,
Its your money but the smallest Hiniker
with the end towing package and the 540-1000
adapter will be about the same money.
The Vrisimo mowers like the Hinikers and the Mathews flail mowers
are sold in every state in the Union so parts are not an issue.
Thanks for the response... replies below ....
mowing needs.
Yes sir... 300 acres at the end of 2 miles of dirt road. All fields either within the property,
accessed from drive, from other fields or internal logging roads. Occasionally need to get on
the town road for 1/3 of a mile or so, but that is what we call a Class IV road.... all dirt, maybe, maybe
gets graded by the town once a year. Basically only passable in a high clearance 4WD vehicle or tractor.
Most of the property is wooded. My guess is that fields, meadows & food plots that need to get brush hogged or
mowed with a flail are 25 to 30 acres tops. That may change as we selectively open up more acreage, but it is unlikely
that it will get above 40 acres.
Well I cannot make any guarantees in perpetuity... but trust me, 15' is way too unwieldy in some of the spots
where I take the tractor. This is not an ag operation. It is a place up in the mountains where we have some meadows
and I do a bunch of work on food plots for deer, turkey, etc. The gent who currently brush hogs all of our fields does so
with a 60" or 72" rotary unit... no bigger.
Life frequently involves tradeoffs... I would rather have the simplicity and maneuverability of a narrower,
non-winged, non-hinged mower. It may not be the decision others would make, but that is the way that I think I want to go.
Also, for some of the terrain & some of the road/trail crossings, a PTO mounted mower will be easier to lift up & out of the way
than a towed unit.
Model RSS 300-96
Vrisimo looks like it may fit the bill & the tractor dealer with whom I deal appears to
be one of their authorized distributors. So will definitely look into it.
I prefer made-in-USA, since I work for a US manufacturer. Next would be Canada, followed by Europe. Will not buy Chinese made.
Would consider quality European flails if I cannot find one made in USA or Canada.
Like I said,
The Hinikers all appear big with the exception of the 5710, but that is only 6' of cutting width.
I know that this may sound a bit fickle, but would rather go 7' or 8' if possible. That gives me the widest swath
but stays within or just outside of my tires & provides good maneuverability as well. Also, except for the
5710, all the Hinikers appear to be tow behinds.
What about the following...
Rhino RSM7H?
Gearmore GOF, GOL, GHF Series?
Rears Manufacturing IFA or OMF Flail Series, Rears S Series Pak Chopper?
In looking at a lot of the US based manufacturers it looks like I am limiting my choices a good bit
by requiring/wanting a hydraulic offset capability. Wondering if I should drop the hydraulic offset requirement
to open up some more options.
Also, wondering if due to the rough terrain, I would benefit from a manufacturer that offers a rear wheel or caster kit.
Thanks for your input and assistance.
/ Help with Selecting a Flail Mower #12
Rhino RSM7H?
The rear wheel kits provide you with stabilty front to rear to prevent any additional nose diving if the mower falls into a rut the tractor wheels miss.
The Italian and Czech flailmowers areas as good or better quality because they MUST pass stronger EU safety standards for all types of mowing in all conditions.
You can purchase the Vrisimo flail mower with rear wheel kits and side shift so thats not an issue to worry about.
You might as well stay with the Wrsimo RSS 300-96 add the side shift and rear wheel kit and be done with it.
Most people lose their wheels becuase they rot off and they dont replace them or the tires crap out on them.
I think the Vrsimo wheels have the solid banded rubber fabric tires
I also wanted to let you in on a little secret- mowing in spiral patterns saves time and brakes
and fuel IF you have room to do that as stopping turning and braking wastes fuel becase
the mower is NEVER MOWING. You can either mow the perimiter first or not.
YOU have to narrow your search and use a decision tree period.
As Italy and the Czech republic have favored nation trading status as EU members
they provide quality farm implements and always have YOU buy a Deere 25A flail now
and it comes from Mexico.
Your also going to have a stock of spare V belts in your mule that are in a black garbage bag
to keep the sun from eating them(ozone damage) so keep that in mind.
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61573)
2022 Mac Trailers...
Unused 2021 IDeal RC6MD 6ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2021 IDeal...
Unused 2023 Unverferth Air Top SPTATV001B 200 Gallon T/A Towable Boom Tractor Sprayer (A66734)
Unused 2023...
2018 FREIGHTLINER CASCADIA 125 6X4 T/S SLEEPER TRUCK TRACTOR (A69167)
2018 FREIGHTLINER...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
1997 HUBBLER BROS. LOGGING TRAILER (A67714)
1997 HUBBLER BROS...
