Comparison What Tractor is best for me?
/ What Tractor is best for me? #1
7000
San Diego,Ca
Looking
Hi everyone,
I'm new to this tractor business. I just bought a 40ac spread in this east SD county hill country. All I know is that I need to clear it out and keep it clean. I've tried to do this by hand with chainsaws, shovels, weedwackers and such. You know the outcome of that scenario. Anyway I have found that it is probably best if I get a tractor backhoe-loader-auger-scraper combination machine. Probably will have to get a PTO wood chipper as well. But, looking at all the various machines available I find it quite confusing. They all are so similar. Of course, depending on who you talk to there is always a preference.
What I need to do is clear out sagebrush, sycamore shrubs, shrub oak, a few small trees, blaze finish a few trails I have already done by hand and make new ones, build a retaining wall, build a pond, build a foundation pad for supply buildings and a garage etc. You get the picture. The terrain is hilly but not too step, mostly. Lots of DG and rocks to contend with as well. Oh, let's not forget all that mustard weed that grows like crazy too.
I have looked at New Holland, Kubota, John Deere and Massey-Ferguson tractors. I've been told by pro's who do this work I want to do that I need a 35-45 HP tractor. But those are too expensive and large for the maneuvering I need to do. Therefore, after talking to different dealers I was told that I could get by with a 25HP or so machine. But, looking at those available has been a difficult choice.
I would welcome some advice from the members here that have more experience in the actual use of these tractors. I'm looking at the Kubota B2320, MF1710, JD2032 and the JD2320. Those are the only dealers within 50 miles of me. I've heard that the Kioti machines are more tractor for the same or less money. I'm now researching the CK30HST and the CK35HST. Especially since the pro I talked to says I need a HST machine and that the Kioti's are a good value machine. Since cost is always an issue they seem attractive to me. I just have to travel 110miles one way to see one.
Any comments? Please respond. Thank You.
/ What Tractor is best for me? #2
It is easy to focus on horsepower, but it is also stance and weight. A heavier, wider stance tractor is much more stable and therefore safe.
You have hills-----HST transmission is the right option.
You have listed some fairly heavy duty work. A light tractor, run hard, will require more maintenance than a heavier one. I agree with your first set of advisors, you need a heavy frame tractor/loader with 35-45 horsepower.
I sold my light-frame Kubota B3300SU tractor/loader and bought a heavy-frame Kubota L3560 tractor loader for all the above reasons.
Tractors require service. If your dealer will pick up and return your tractor for service and repair expect to pay a minimum of $1.25 per mile. So a dealer fifty miles away will charge you a minimum of $250 to transport your tractor on a trailer in and out. That is dealer's cost for a HD truck, trailer, fuel, insurance and driver on two round trips. Plug transport cost into your calculations.
What is DG?
Sounds about right to me too but didn't want to spend that much. DG is decomposed granite. How about a New Holland workhorse 35? I don't like the heel toe accelerator on the Kubota. I guess I could get used to it. What do you think of the Kioti ck35 or ck 39?
/ What Tractor is best for me? #4
Have you looked at Mahindra?
/ What Tractor is best for me? #5
Sounds about right to me too but didn't want to spend that much. How about a New Holland workhorse 35? I don't like the heel toe accelerator on the Kubota. What do you think of the Kioti ck35 or ck 39?
All good tractors, competitive in the marketplace.
Forty acres is a lot of ground. Buy enough tractor.
/ What Tractor is best for me? #6
SD county.....oh the Peoples Republic of Kalafornia......I think you are going to have to go with one of the battery powered models.
I am kidding....
Really I would shop the dealers....the machines are all very good machines. This could be a case of where the dealer makes the difference. When I bought mine I got the first service tossed in as well....at my house. The little things can make a difference.
/ What Tractor is best for me? #7
I think the wood chipper or stump grinder would do best as a stand alone machine.
On digging a pond, a $100 per hour experienced dozer operator can run circles around your tractor in building a pool and will know how to figure elevations, drainage, dam slope and all that stuff you need. BTDT
If you don't really need the backhoe, I'd forgo it as it is heavy and can get in the way of other implements you will want to use. For the cost of one you can hire or rent one numerous times on the occasions you would need it, like putting in a drainage or water line.
Front end loader absolutely. Just too handy not to have. I prefer a tractor with a front end that adequately supports one like the next entry.
4wd I did without for 30 years, but after getting my first (Branson) won't buy another without it
25 hp for 40 acres, in today's world is not enough. Yeah I know when motorized farm equipment came into being, after the steamers, the Ford Ns and MF TOs and Farmall As were around that hp and glad to have them. Today that's not the case.
Even if you have to buy a used tractor in good condition, I'd do as others have said and get the size up which gets the hp up which gets the weight up which gets the performance up and etc. Remember sir, once you spend the money it's gone forever. What's left for however long you keep it, is what you bought with that money. Buy the 25 and I guarantee you that you will continuously kick yourself in the pants for not getting a larger machine.
The basic machines like Mahindra are simple and stout. The ones I have seen/shopped have few whistles and bells. My Branson is loaded with them and I use them all. Around here blue, orange, and green dealers are handy. My Branson dealer is 50 miles away but help is a phone call and UPS away.
Good luck,
Mark
/ What Tractor is best for me? #8
It may be too that you need more than one tractor. Every see many farms with just one? Perhaps a smaller SCUT/CUT size for those tight places and an older bigger one for the big tough jobs. On my place the Mahindra does the FEL work (also it's my diesel powered wheelbarrow!) and small blade stuff, the 8N takes care of pasture field mowing and snow moving with a 7 ft. blade and the 9N stays on the manure spreader for the weekly/twice weekly dumping of it. You might need something bigger than my little Mahindra and the Ns, but you get the concept. Match machines to the jobs needing done.
/ What Tractor is best for me? #9
/ What Tractor is best for me? #10
Tractors are sized by the weight, size and pto hp requirements of the implements you need to do you work efficiently and safely. Figure out which implements you'll need in the next 5 years and go from there.
If you plan to do some or most of your work on very hilly ground, then you need to be concerned about tractor stability, ground clearance, wheel track width, center of gravity. Nothing worse than buying a tippy tractor that increases the rollover risk. Tractors can be modified to give more stability on hills. An example is my 1964 MF 135 diesel.
The wide rear wheels and shortened front axle spindles increase the track width and lower the center of gravity.
Good luck.
/ What Tractor is best for me? #11
Unless you are forbidden to burn, I wouldn't worry about a wood chipper, just rip it out, pile it and burn it when weather is favorable. I am not in the rent a back hoe when you need one house. If you have enough work to justify renting one for a week, just buy it outright. I cant believe the amount of work that I have used mine for. My biggest mistake was not buying it first rather than last. It is my go to tractor for most of my needs. I know lots of things would never have been done if I had to rent. I too have lots of rocks and they continue to grow out of the ground especially after a hard winter. When ever I find one that I cant easily remove by hand, out comes the B26 and I dig it up and smooth out the hole. If I had to rent to get it out, it would likely be hitting the mower every time I mowed OR it would be pick and shovel time which I don't relish at all.
For 40 acres, you should look at 40 PTO HP minimum. This will give you plenty of power and weight to use a backhoe, 6 foot mower, 6 foot tiller etc. As for stump grinder, NOT NEEDED. Use the backhoe to dig it out and be rid of it. I like to use my TLB to uproot any trees that need removing and dig out the roots so they don't come back. I also love the hydraulic thumb for the back hoe as I can pick up objects as small as a softball without getting off the tractor. I use mine to pick up rocks and put them in my Kubota RTV to haul away. Some small ones I load by hand but if it is 40+ pounds, it is just as easy to lift it with the backhoe.
/ What Tractor is best for me? #12
There is also something to be said for a multiple tractor operation. I never remove my backhoe so it is always ready for digging or lifting. I use my larger tractor for all my 3 PH work. I know some times money is a bit tight, but it may make better sense to get slightly used if you can find a good deal and buy 2 tractors rather than 1 new one. I got my 2009 B26 in 2011 with 60 gently used hours on it, much of it mowing, and got a $10K price reduction over new price. Tractors that have been gently used and properly maintained will last 3000 hours or more easily without any major repairs so one with less than 1000 hours that has been stored inside might be a good bargain so keep a lookout for one like that
1996 International Water Truck with a Caterpillar Engine (A61307)
1996 International...
TOYOTA 8FGCU30 FORKLIFT (INOPERABLE) (A60736)
TOYOTA 8FGCU30...
John Deere Z997R (A60462)
John Deere Z997R...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2012 International Prostar (A61307)
2012 International...
2014 GENIE GTH1056 TELESCOPIC FORKLIFT (A62129)
2014 GENIE GTH1056...
