No going back and forth here Brian. And I don't see filled fronts as causing trouble. Unless you have a flat, but that's trouble regardless.
I would be interested in you running a small test for me if you don't mind??
With no FEL load on the front of your tractor, check your air pressure in one front tire.
Then load your bucket or
Grapple or whatever attachment you are using with the heaviest load you can conveniently find. Now while carrying that load, check the air pressure in the same tire.
I'd be interested in seeing how much the pressure compounds.
I think what we will find is that if an unfilled front tire is aired up to whatever pressure you find in your filled tire with a load on it, the unfilled tire would then carry the load just as well as the filled one??
Pure logic there.
I guess you could possibly see a ride improvement with filled fronts if your tractor tends to be a bit light in the front?? My brother's
L3240, with filled fronts, rides like crap compared to my M9540 with unfilled fronts.
