4520 on lot
/ 4520 on lot
Oh, and by the way, that dealership you went to is NOTORIOUS for being snobbish. It's one of the reasons I've purchased two Masseys instead of John Deeres. Of course, their ridiculous pricing has a lot to do with it, too.
BTW, I live in Putnam.
I actually went to big boys first when I bought my 3320. I was underwhelmed with the massey loaders. Otherwise they were pretty nice.
It's too bad the dealer in question is so out of touch, they'd certainly move more units if they weren't. The yellow deere dealer has even commented to me similar thoughts as I'll sometimes avoid going green since the yellow dealers can order you the same parts.
Matt
/ 4520 on lot #22
to me up to 30-50 hrs is demo , above that to 500 is slightly used and should be 25-30% off MSRP. but 4520-4720 are coveted , especially non tier4 so I dunno maybe hes not that far off the mark?
/ 4520 on lot #23
While I agree the 4000 Twenty series John Deeres are really nice machines (I almost bought the tractor in question), if they are SO coveted...why has this particular one been on the lot for a year or more?
/ 4520 on lot
My thought is the dealer isn't that eager to sell it. They don't generally have many units in stock. Usually one of each cut series, their implement prices are also above list. I'm focusing in on the 110 tlb at this point, it's a lot more tractor for the money and I've wanted one for years. I'm going to go with the 4000 series if I can't find a 110 instead. Additionally I'm looking at the Kubota M59 and L45 though going from green to orange may not be something I can handle.
Matt
/ 4520 on lot #25
Matt
It has been a while but I seem to remember you were interested in a 110 before you bought the 3320. I am still pleased with mine after nine years but would also recommend the L45 and M59 too, a good deal on any of these would be great. I think all of these would be better than adding a hoe to a 4520, while my 4520 is great for the 3ph work a hoe on it not optimum imo.
/ 4520 on lot
You are correct, I've wanted a 110 for quite a while. I was really disappointed when Deere discontinued it. With my future needs loader capacity is the most important feature. And as you alluded to, the 110 is a lot more hoe than the 485 or Woods unit.
Matt
/ 4520 on lot #27
Matt
I think the hoe on the 110 is even more capable than what goes on a 5000 series tractor. hydraulic flow is much better than the 4000 series too. The 110 would be a little short on HP compared to a 4520.
/ 4520 on lot #28
An M59 has the power of a 4520 with a better hoe and higher capacity fel too. I like having both the 110 and 4520 and in my present work switch between the two doing the field and pipeline work several times a day. No need to reconfigure the machines this way. But if I could only have one machine the M59 would be the better choice.
/ 4520 on lot
As an update, I ended up going with a 110 TLB. Since I was really after max lift cap it was the best choice. I'm going to have to add a custom scv options since this unit didn't have it. I can't wait to start playing with it.
/ 4520 on lot #31
Good to hear you got a 110:thumbsup::) Pictures we need pictures.
/ 4520 on lot
Here you go.
/ 4520 on lot
I like it, it's certainly a stout unit. Totally different feel from the 3320. I'm now looking for a HD box blade(hydro scarifiers) a new landscape rake and a grapple. I sold all of my implements with the 3320 except the wood chipper.
Matt
/ 4520 on lot #36
If your dealer won't work with you than maybe you need to push a little harder, "what kind of discount will you be allowing for 100 hours on this machine?" 100 hours is a used piece of equipment.
As far as a "totally different feel from the 3320" I actually found the two to be darn near identical the way the felt and operated, just a little more umph with the 4x20 series!
2007 JLG 450AJ TELESCOPIC BOOM LIFT (A65056)
2007 JLG 450AJ...
2012 Ford F-250 Crew Cab Pickup Truck (A66736)
2012 Ford F-250...
2017 CATERPILLAR 249D SKID STEER (A65056)
2017 CATERPILLAR...
2003 International 7400 T/A Dump Truck (A66736)
2003 International...
2012 COMPTANK CORP. 130BBL FIBERGLASS ACID TRAILER (A67714)
2012 COMPTANK...
1988 Ford 7610 Series II 4WD 97HP Agricultural Tractor (A66734)
1988 Ford 7610...
