Tractor Sizing B2320 bush hog size
/ B2320 bush hog size #11
I just purchased a landpride rcr1248 for my bx2360. Haven't had the opportunity to use it yet so I cannot give you a review. However, prior to purchasing I spent one morning and called about twenty different places within an hour drive of my house and got prices on LP, Bushog/Rhino, Kodiak/Mahindra, Howse, Big Bee, LMC, and TRI.
At least with the folks I talked to there was anywhere from 100.00 to 500.00 differences in price for the same makes and models from dealer to dealer. For me it made a big difference to price shop. YMMV. Good luck.
/ B2320 bush hog size #12
Have you thought about buying used? Look on craigslist, there is always equipment to purchase. Just use common sense when buying on the web.
Yea I may buy used if the right deal comes along. Not a lot of 4 footers out there mostly 5. Ill keep looking... the bush hog brand seems to be the toughest. for u all that like pics here's on of a b2320 moved to its new home. The trailer is brand new but its a friends they were nice enough to let me borrow it.
/ B2320 bush hog size #14
the weight of the deck is typically the problem. A good quality mower in a 54-60" will be too heavy for comfort. A cheap light duty one would probably be just fine.
Thanks for the advice Messicks.. :)
/ B2320 bush hog size #16
I've owned many rough cut mowers of various brands, good quality as well as not so good. The last three new ones that I bought have been Woods. Note: The large manufacturers such as Woods, Bush Hog, etc., offer several lines intended for different markets, e.g., so-called light, medium, heavy duty, etc. Obviously, the HD models weigh more, have higher capacity gearboxes, cost more and probably have longer warranties.
I would recommend a relatively light weight unit for use with your tractor. There is no need for a HD model and the added weight will be a disadvantage. You can also probably get by with a relatively low cost unit, e.g., King Cutter, Hawkline, Howse, etc.
SDT
/ B2320 bush hog size #17
I have this cutter for my B2920 and it works well. If I remember correctly, it was only 200 dollars more than the lighter duty model. Seemed like a "no brainer" to get the little more heavy duty model for that price difference.
Cutting only grass the RCR12 probably would be enough cutter, but I cut saplings and small brush with it.
The 2920 could probably pull a 54" cutter, but the 48" seems to be a perfect match.
Haven't broke a shear-pin yet... lol
RCR15 Series Rotary Cutters | Land Pride
/ B2320 bush hog size #18
I have a landpride 1860 i use on my grand l 3540. I wouldn't mount that cutter on my B2320 for any reason what so ever!!! I recommend you buy a landpride light duty 42 or 48.
/ B2320 bush hog size #19
Just don't use the top link if your cutter is too heavy. Treat it like a "simi-mount". So half the cutter's weight is always on the back tire and the other half on the tractor hitch. Of course you can't pick it up to transport on a highway but thats not what you need to be doing on a B2320 anyhow.......
Went with a hardee brand panther 48" really is a good looking unit. More robust thant the howse. Bush hog was 1500.00 howse 740.00. Coulda maybe went a taste bigger but 60'' would been pushing it for my small tractor. It'll take me long but a little at a time and I have lights to cut at night.
2024 MACK GRANITE GR46F DUMP TRUCK (A59823)
2024 MACK GRANITE...
TANK MANIFOLD (A58214)
Club Car Utility Cart (A55851)
Club Car Utility...
GENIE AWP-24 MAN LIFT (A60736)
GENIE AWP-24 MAN...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
