Traction Box Blades
/ Box Blades #21
It depends on the ground and where you are using it. That is why there is so my "debate" about what is right for a certain size tractor. I personally had 48" that would stop a 35 HP tractor dead in its tracks. Now my land in rough, steep, rooted, and all HEAVY clay. If it was sand or loom a 60" will do the job all day long without any issues at all. Really look at your land and see what kind of issues you may run into and decide accordingly. I am currently looking to build a 66" HD box blade for my 50+HP and figure that should be about right for my uses.
Good luck on your search
/ Box Blades #22
My rule of thumb, buy the attachment ( box blade, disc, tiller )that just covers the wheel width and adjust speed, depth, from there depending conditions. For blades or landscape rakes go one foot wider so that you still cover your tracks when angling. Have done this with an 8N, 3320, and 4120. Works for me.
/ Box Blades #24
No I'm sorry it doesn't. MAybe if you are moving dry sand or another light material. Put the tines all the way down and start digging up fresh earth on flat or inclining ground and you will find yourself woefully undersized. The 1026 is much better matched with a 4' bb if you plan on moving the earth. My 3320 struggles with the tines down and a full load, so please don't tell me a machine half the size is "plenty". Others may take your recommendation and buy a 5' bb and find themselves scratching there head when it stops dead with a full load and the tines out.
Thank you Mr. Wizard. Could you post your phone number so I can get your approval on all of the attachments you believe I should be using on my tractors?
What is the picture supposed to show? Maybe if you added some weight to your tractor, you could pull something more than I do with my 1026R.
/ Box Blades #25
again, more great advice. I will add weight and put on flames so I can pull like yours. You guys must have lawns made of feathers and sawdust.
As the photo clearly shows, that is pure red clay, very hard to get out of the ground but very good for dams and bridges. Here in WV it's what we have to contend with when we move dirt. Please don't call me for approval, but I would suggest you have someone do your homework for you.
If any of you others need some more great compact tractor pulling advice contact the guy with the 1026 and the 5' box blade. The perfect set up. :laughing:
/ Box Blades #26
The 1026 & 5' box blade works perfect for me, where I need it. My 4120 with a 7' box blade also works perfect for me where I need it.
Next you will tell me that a 4120 cannot pull a 7' box blade.
Just because someone does not know how to do something, does not mean it cannot be done.
/ Box Blades #28
Folks,
Getting a BB and need some feedback on what size, 54" or 60".
Its for a 2032r, t4 tires, loaded with rimguard.
Rear wheel base width is 55". Leveling says 60" but will this tractor
pull a full box of dirt with a 60" BB from EA?
thankx
Since your tires are 55" width I would use a 60" box blade. Whether you can pull a full box of dirt or not in all conditions doesn't matter, you work with the conditions you have. You do need to cover the tires to do a good job. Ripping the ground will be the hardest task in most soil conditions and you will quickly find out how deep you can rip without too much stalling out. Might have to make several passes to get it done but I think this would be true no matter which box blade you choose.
Pulling the loosened dirt will be much easier than the ripping it loose will be. Get enough seat time(on the tractor not the computer) and you will figure it out.
/ Box Blades #30
Very good reply.
/ Box Blades #31
...You finally added some value to this thread.
Now it's your turn...we're waiting with bated breath...
/ Box Blades #32
Without jumping into the fray or taking sides, I think the real issue comes down to power/weight of the tractor and what you're actually doing with the box. I have had high horsepower in a light tractor (B2920) with a Howse 48" box (that actually measured 50" I think) and low horsepower in a heavier tractor with a Howse 60" box (L3200). Both boxes were sized to rear tire width.
Having spent a fair amount of time on a 1026R, which falls into the high HP / light weight class, I'd be shocked if the tractor didn't run out of traction long before you get the full advantage of a 60" box. Sure, you can operate a 60" box for more width, but I don't think you can ever come close to its real capability.
Is that better or worse than running a 48" box that can do more agressive work? I guess it depends on the person and the application. For light road resurfacing, you might never approach the limit of *either* box, and the 60" gives more width. When you do approach the traction limit of either box with rippers up and cutting edge feathered, I suspect it's as much a function of the volume (weight) of dirt in the box as anything else. Really, the only time the bigger box is an issue on a light tractor is when you are agressive with rippers and/or cutting edge.
The only "opinion" thing I will say is that I think my 60" box is well matched to the L3200, and no way would I have wanted a 60" on my B2920, both because of size and traction.
/ Box Blades #33
I hooked my neighbors 7' box blade up to my 33 hp deere last year. It was a great ballast and much nicer than my county line, but when it came time to move the red clay I found myself constantly working the 3point up and down to gain traction.
Even with a scoop of dirt in the front loader the machine was not heavy enough.
/ Box Blades #34
I have a 6ft.BB on my L4240 HSTC with loaded R1's and it will pull a full load with no problems;total weight with loader is about 7,000 lbs.One of the best tools I have purchased for my tractor.
/ Box Blades #35
Very well state S219. So in the end, if the BB attached to the tractor brings the said tractor to it's fullest capabilities to pull it, what is the difference if it's a 48" or 60" BB that creates that situation??
I think that's what's being discussed. When the tractor reaches it's capacity, not much more is going to happen. Actually with that thought, the 60" might have an advantage because of it's additional weight...
/ Box Blades #36
But when you arrived at the point that you were ready to dump the load, did you have less dirt than you would have had with a smaller BB?? I think not. Again, you actually might have had more dirt if you efficiently controlled your 3pt.
With that said, if I have a dirt cutting/moving attachment on my tractor that I can drop on the ground and drag it without ever having to apply 3pt lift pressure to gain traction, I consider it too small. A marked percentage of the time I will not be using the tractor to it's capacity.
I believe that's the difference in this discussion. I want my tractor to be working at maximum capacity when doing these tasks. Others might be content to let their tractor "play" at the task and make more trips.
/ Box Blades #37
That is all valid and I agree about working tractor at the maximum. But the constant wheel slip and up and down with the 3 point felt like I was wasting time with too big of an implement. Maybe I just need more seat time but the 7' box blade was too big. I'd like to try a 6', but not at the expense of buying one and then still having a too small of tractor.
/ Box Blades #38
In another post you mention the hills on your property, these will greatly affect which box blade will work best for you too. Think smaller, on hills your 3320 and 820 can handle a heavy duty 5' or medium duty 6' box blade. A 7' heavy duty box blade is out of the range of either tractor.
/ Box Blades #39
Without digging back thru posts, can't remember who mentioned it, but handling a BB efficiently is a learned art. I've got a friend that simply can't do it. All he ends up with is speed bumps. I sometimes struggle with my 2210 because of it's 1/4" valving. Position control on the 3pt helps a lot. I have no problems in that regard with the 9540 and position control.
/ Box Blades #40
Picked up a new / never used Frontier (66") BB2065, yesterday, at a private sale for equivalent US$540. for the 3320. I have about 12,000 sq ft of parking / driveway covered with "driveway gravel" don't know the technical name, it's sort of a mixture of sand / gavel that dries out to a fairly hard surface. Need to read and watch some "how to" stuff and work on the learning curve, but so far so good. Played with it a bit today. I have a heavy 84" bucket I'm thinking might work well for final leveling instead of having to change the top link from dig to level length.
John Deere MX5 (A64126)
John Deere MX5...
(2) Tool Boxes (A62613)
(2) Tool Boxes...
2022 Bautista Welding and Custom 40ft. 10 Ton T/A Gooseneck Flatbed Trailer (A61573)
2022 Bautista...
2004 John Deere 8320 (A63688)
2004 John Deere...
2009 International 4300 Digger Derrick (A62613)
2009 International...
John Deere R15 Rotary Cutter (A64047)
John Deere R15...
