Danuser F8 Post hole Digger on L3540
/ Danuser F8 Post hole Digger on L3540 #31
RRRKKK yes no bearings or races come in the kit other then 1 on the new pinion. There is only 4 bearings in the auger (2 for pinion gear and 2 for ring gear). The bearings are all Timken brand and have numbers on them (races also) that can be bought at a bearing shop. I can't imagine what would have broke inside your case? The ring and pinion mesh tight and are very large and robust. The only thing I could see breaking is the pinion shaft. Please update us when you pull the top off and see what happened with pics.
I am checking online and I see some augers. The say "bobcat" on them but are round not hex. There is no size listed listed for shaft.
If I took a shot in the dark and said these are for skid steers, are any of these sizes interchangeable with PTO driven diggers? Or would they require an adapter?
/ Danuser F8 Post hole Digger on L3540 #33
PHD augur shaft sizes I've heard of:
2" round
2 & something (5/16" maybe) round
Hex, not sure what size or if there is more than one
Square, not sure what size or if there is more than one
2" round
sweet. I wasn't sure how many round sizes there are. I know if 2'' and 2 9/16 but unsure if there is larger or not. I have been trying to read about them but don't see any other sizes. :-0
Well, it was just a trial run, but it works well.
It needs a slip pin for the PTO shaft.
It's hard to tell
but it has plenty of room. No dragging of the tip
Sanded her down and gave a quick touch of orange paint. After her second coat I'll post a photo.
/ Danuser F8 Post hole Digger on L3540 #36
It'll drag when you go thru a depression...but no worries...just don't back up without thinking about it.
Without thinking? You know as well as I do. I will get side tracked and forget.
My two concerns are loading / unloading from the trailer, and dragging it across someone's concrete.
I wonder if the auger can be folded / pivoted up toward the boom and strapped?
/ Danuser F8 Post hole Digger on L3540 #39
Well finally got around to taking it apart, bad news broken teeth on ring gear. Pinion $196.49 ring gear $299.79 Pinion bearing $60.19. Awaiting parts.
Ouch, That hurts. The good part is this will be a one time bite and you now know the guts are new. (finding the silver lining).
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
2019 PJ TRAILER 32FT GOOSENECK (A55745)
2019 PJ TRAILER...
2017 ADDCO ROAD SIGN DH1000-ALS (A60736)
2017 ADDCO ROAD...
JLG 20MVL MANLIFT (A58214)
JLG 20MVL MANLIFT...
