Help with identifying yellow Post hole digger
/ Help with identifying yellow Post hole digger #1
Osutim1
Ford 8N/ Kubota BX
My grandfather gave me this post hole digger quite a while back, after it froze up and he let it sit out in the elements. He passed fairly recently, and I would like to get it going again. I am leaning towards a Land Pride PD series, but that's just a guess.i have it torn down and need to order some bearings and seals and a few other items and need to figure out the brand and model if possible. Any help would be greatly appreciated
/ Help with identifying yellow Post hole digger #2
I guess you arnt reading any numbers off the bearings or seals?
Can't make out any numbers on them, they are in too bad of shape, I tried.
/ Help with identifying yellow Post hole digger #4
If you can give me the ID, OD and width (or height) of the bearings and seals I might be able to find them in my big cross reference books.
/ Help with identifying yellow Post hole digger #5
Maybe a Danuser or Champion?
Will do. I will get those as soon as I get home.
/ Help with identifying yellow Post hole digger #7
That box looks fairly rough shape. There is complete post hole gear box set ups out there, just a thought. I own a couple pieces of equipment from my granddad like the Deere no.15 sub-soiler and a 2 bottom 14 inch Case BER or BAR eagle hitch plow, i get it (y)
Some of that rust remover stuff like evapo-rust might be of a lot of help on that restoration.
/ Help with identifying yellow Post hole digger #8
I have a yellow one similar to that and it's a Danuser. Here's a pic of a Danuser, but not mine. :)
/ Help with identifying yellow Post hole digger #9
Looks like mine.
Likely a Danuser like above.
I don’t know the brand but will look for markings if you like.
/ Help with identifying yellow Post hole digger #10
/ Help with identifying yellow Post hole digger #11
Any good bearing supply house will be able to measure those and give you the correct bearings/seals.
/ Help with identifying yellow Post hole digger #12
Kinda looks like a Danuser PhD.
It would make a positive ID if you showed the whole gearbox.
/ Help with identifying yellow Post hole digger #13
2018 Chevrolet Trax SUV (A59231)
2018 Chevrolet...
2020 MACK GR64FT DAYCAB (A60736)
2020 MACK GR64FT...
2015 PETERBILT 367 WINCH TRUCK (A60736)
2015 PETERBILT 367...
DRILL CABINET SKID (A58214)
DRILL CABINET SKID...
2021 ISUZU NPR CAB AND CHASSIS (A60736)
2021 ISUZU NPR CAB...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
