Aftermarket seat
/ Aftermarket seat #1
BeezFun
Elite Member
IL
Kubota B2710
I'm looking at a suspension seat, but none of the bolt holes line up. Do you generally drill holes to match up with the tractor? I don't want to order one of these things and find out I can't make it work.
Also, how do you get the seat safety switch to work, seems like I almost have to weld a little bracket on to hold the switch.
/ Aftermarket seat #2
Go to Northern Tool dot com and search for "milsco v 5300". It comes with a safety switch installed. I put one on my mower and love it. Cost was around $350.
/ Aftermarket seat #3
I put a Michigan Suspension Seat on my L3700. The bolt pattern for the new seat was larger than the stock unit so I had a bracket fabricated with both patterns for not so much money. I was able to rig the safety switch as well, all told a half hour job once I had the transition bracket in hand.
/ Aftermarket seat #4
This...you make a bracket. Having put so many different seats in different things over the years this is the best way to go. And you are talking a tractor here, not a car...you don't have to worry about that seat coming loose in a crash.
/ Aftermarket seat
Thanks for suggestions, I'll check those out.
2001 Pierce Tilt Crew Cab Pumper Fire Truck (A61573)
2001 Pierce Tilt...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2008 PETERBILT 365 (A65643)
2008 PETERBILT 365...
KALMAR AC P50BX-PS WAREHOUSE FORKLIFT (A64276)
KALMAR AC P50BX-PS...
1998 International 9400 (A64127)
1998 International...
2001 Ford F-150 4x4 Pickup Truck (A59230)
2001 Ford F-150...
