How do you store you logging/tow chain?
/ How do you store you logging/tow chain? #121
Re: How do you store you logging/tow chain and tow strap?
Hi there Xfaxman,
In you last picture, is that a home made/improved version of a chain hook safety clip, or is that something you bought somewehere?
?..and what is the deal with that big ring, just to grab it outen the holder, or some other special purpose?
Thanks,
Thomas
/ How do you store you logging/tow chain? #122
Looks like this:
3/8 Clevis Grab Hook Safety Latch Grade 70 - $5.95
Bruce
/ How do you store you logging/tow chain? #123
Hi there Xfaxman,
Thanks,
Thomas
bcp found the link for it.
The chain is about 4' long, hook on one end, big ring on the other. You put it around a tree or post, then put the hook through the big ring and pull it tight. That is called a choker chain around here. :)
You push on the spring loaded pin to slide the locking bar open or closed.
I have more pictures, but the Forum won't let me upload them now. ??????
/ How do you store you logging/tow chain? #124
Tried Reply To Thread, got the Icons.
Open
Closed
/ How do you store you logging/tow chain? #125
bcp found the link for it. The chain is about 4' long, hook on one end, big ring on the other. You put it around a tree or post, then put the hook through the big ring and pull it tight. That is called a choker chain around here. :) You push on the spring loaded pin to slide the locking bar open or closed. I have more pictures, but the Forum won't let me upload them now. ??????
XFAXMAN;
I like your choker. Where did you get the chain with the big ring on it? That looks very handy.
Thanks!
Sent from my iPad using TractorByNet
/ How do you store you logging/tow chain? #126
XFAXMAN;
Thanks!
A neighbor gave it to me about 25 years ago.
There are choker hooks available that would work as well as a ring and better than a slip hook.
3/8" Choker Hook For 3/8" Chain Choker System | Chains & Chain Chokers | Chains, Cables & Grapplers | www.baileysonline.com
Or: https://www.google.com/search?hl=en...hoker chain&revid=906204068&tbm=isch&imgdii=_
/ How do you store you logging/tow chain? #127
XFAXMAN;
Thanks very much. Looked all over the internet for this and came up empty.
/ How do you store you logging/tow chain? #128
XFAXMAN;
Your are welcome. I use Google Images when searching for something.
Here is a clevis choke ring that would work like my big ring.
/ How do you store you logging/tow chain? #129
I leave it in the garage, when i need it I get it.
/ How do you store you logging/tow chain? #130
/ How do you store you logging/tow chain? #135
Your are welcome. I use Google Images when searching for something. Here is a clevis choke ring that would work like my big ring. <img src="http://www.tractorbynet.com/forums/files/customization/371238-how-do-you-store-you-thumbnail-jpg"/> <img src="http://www.tractorbynet.com/forums/files/customization/371239-how-do-you-store-you-classic-cel_web-jpg"/>
Xfaxman;
Did you find a site that sells the ring in your first photo? That is exactly what I'm looking for.
Thanks!
/ How do you store you logging/tow chain? #136
Xfaxman;
Thanks!
Yes,504 Main Street - Gorham, NH 03581 1-800-764-9969. Clevis Choke Ring - 3/8" - M10
Here is one similar.
Cargo Control items in Clevis Reeving Ring store on eBay!
And ME 3/8'' Clevis Reeving Ring Red Grade 80 WLL 3T - $18.00 : Transport, Cargo Control Products, Binder Chain, Ratchet Strap, E Track Strap
From: TrucknTow - Grade 100 Clevis Reeve Master Links
/ How do you store you logging/tow chain? #137
XFAXMAN;
Thanks for the links. The one I like is only $16.95 which I think is reasonable but, they want $21.23 to ship UPS ground.
/ How do you store you logging/tow chain? #138
XFAXMAN;
Call them tomorrow and ask if they will ship it US Post Office First Class Package.
Most of the stuff I get on eBay comes that way.:thumbsup:
/ How do you store you logging/tow chain? #139
Call them tomorrow and ask if they will ship it US Post Office First Class Package. Most of the stuff I get on eBay comes that way.:thumbsup:
Thanks, will give them a call.
2020 FREIGHTLINER CASCADIA MIDROOF SLEEPER (A60736)
2020 FREIGHTLINER...
Used Landpride GR1525 Stump Grinder
Used Landpride...
2013 FREIGHTLINER CASCADIA (A60736)
2013 FREIGHTLINER...
VAC PUMP MUFFLERS QTY 5 (A60736)
VAC PUMP MUFFLERS...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
John Deere 690B Excavator with Auxiliary Hydraulics (A57024)
John Deere 690B...
