How do you store you logging/tow chain?
   / How do you store you logging/tow chain? #121
Re: How do you store you logging/tow chain and tow strap?
Hi there Xfaxman,
In you last picture, is that a home made/improved version of a chain hook safety clip, or is that something you bought somewehere?
?..and what is the deal with that big ring, just to grab it outen the holder, or some other special purpose?
Thanks,
Thomas
   / How do you store you logging/tow chain? #122
Looks like this:
3/8 Clevis Grab Hook Safety Latch Grade 70 - $5.95
Bruce
   / How do you store you logging/tow chain? #123
Hi there Xfaxman,
Thanks,
Thomas
bcp found the link for it.
The chain is about 4' long, hook on one end, big ring on the other. You put it around a tree or post, then put the hook through the big ring and pull it tight. That is called a choker chain around here. :)
You push on the spring loaded pin to slide the locking bar open or closed.
I have more pictures, but the Forum won't let me upload them now. ??????
   / How do you store you logging/tow chain? #124
Tried Reply To Thread, got the Icons.
Open
Closed
   / How do you store you logging/tow chain? #125
bcp found the link for it. The chain is about 4' long, hook on one end, big ring on the other. You put it around a tree or post, then put the hook through the big ring and pull it tight. That is called a choker chain around here. :) You push on the spring loaded pin to slide the locking bar open or closed. I have more pictures, but the Forum won't let me upload them now. ??????
XFAXMAN;
I like your choker. Where did you get the chain with the big ring on it? That looks very handy.
Thanks!
Sent from my iPad using TractorByNet
   / How do you store you logging/tow chain? #126
XFAXMAN;
Thanks!
A neighbor gave it to me about 25 years ago.
There are choker hooks available that would work as well as a ring and better than a slip hook.
3/8" Choker Hook For 3/8" Chain Choker System | Chains & Chain Chokers | Chains, Cables & Grapplers | www.baileysonline.com
Or: https://www.google.com/search?hl=en...hoker chain&revid=906204068&tbm=isch&imgdii=_
   / How do you store you logging/tow chain? #127
XFAXMAN;
Thanks very much. Looked all over the internet for this and came up empty.
   / How do you store you logging/tow chain? #128
XFAXMAN;
Your are welcome. I use Google Images when searching for something.
Here is a clevis choke ring that would work like my big ring.
   / How do you store you logging/tow chain? #129
I leave it in the garage, when i need it I get it.
   / How do you store you logging/tow chain? #130
2003 - 1890/1910 Air Seeder and Air Cart (A51039)
2003 - 1890/1910...
2019 CATERPILLAR 259D SKID STEER (A51242)
2019 CATERPILLAR...
more info coming soon! (A50323)
more info coming...
2019 HINO 155 16FT BOX TRUCK (A50505)
2019 HINO 155 16FT...
Seppi Mini BMS 85 Mulcher excavator attachment (A52128)
Seppi Mini BMS 85...
2011 L3 MEP-806B GENERATOR (A51222)
2011 L3 MEP-806B...
