Laser grading hydraulic valve issue.
   / Laser grading hydraulic valve issue.
I'll pick up an infrared thermometer. What would be a safe operating temperature? What would be high enough to shut down?
   / Laser grading hydraulic valve issue. #82
About 175 to 200 degrees.
   / Laser grading hydraulic valve issue. #84
I still do not understand why that coil should cost $700 .
To me that coil or just about any coil for solenoids is just a bunch of wire wound around a core which slides over a steam connected to a spool that will move when the coil is energised.
A proportional valve just moves the spool in small increments.
By matching Opposition Spring Force to Solenoid Force, Proportional Spool Movement is obtained.
With regular solenoid coils, they warn about over tighten the coil. Especially those that screw into the valve body.
How much was the whole valve including the solenoid. Did that include any electronics outside the coil.
A proportional just moves the spool in small increments.
I bought the entire system for $8000.00. That included the laser transmitter and tripod, the laser receiver which mounts on a mast on the blade, the control box which mounts on the fender of the tractor, and the valve/solenoid, and all the wiring that goes with it.
I called my brother who is a John Deere tractor mechanic, and has been for about 30 years. He suggested that I try to find a tube to stick into the dipstick hole and run it up onto the ROPS or somewhere to be used as a vent. He also said I need to keep an eye on the temps of the oil. I did change the oil and filters on the Kubota this week too.
   / Laser grading hydraulic valve issue. #86
   / Laser grading hydraulic valve issue. #87
Which brand and equipment did you buy if you don't mind my asking?
I am just about ready to order a two receiver system in the next few weeks and was planning on the Topcon RL200 2s laser, system 5 control box and the lsb 110w receivers. I am waiting on the valve to be built and shipped now, bought a dual spool valve (Danfoss) proportional control with relief st to 1100 psi, 6 gpm flow to the cylinders, voltage control. I went with the PVG 32 series as it is supposed to allow me to adjust both cylinders at the same time, not sure about that we will see. I ordered this from Sunsource in AZ for about $2300 + shipping. So far the hydraulic valve was the hardest part to shop for very difficult to compare pricing and features on.
I have to have this operational by the middle of June to grade about 15 acres. I am open to any help or useful comments about the electronics as this stuff is costly and I don't wan't to make any purchasing mistakes.
   / Laser grading hydraulic valve issue. #88
Jenkinshp. you have some fine parts there.. if you want help with this project this forum is not the place, you may want to try this.
Fluid Power Forums
most of these people are in the industry and if your lucky you may get to talk to some of the engineers that work for danfoss...
   / Laser grading hydraulic valve issue. #89
And after you find out everything you need to know from the forum that glastron suggested, you'll bring your buildup and knowledge back here, right? You did already bait me in when you mentioned it before, so I'll take that as a promise. :)
   / Laser grading hydraulic valve issue. #90
Fluid Power Forums
Thanks for the link.
2019 JOHN DEERE Z960M ZERO TURN LAWN MOWER (A54756)
2019 JOHN DEERE...
2019 Kia Soul SUV (A53424)
2019 Kia Soul SUV...
Kawasaki NR (A50324)
2018 HINO 338 KNUCKLE BOOM TRUCK (A51406)
2018 HINO 338...
2017 Nissan Frontier Pickup Truck (A55788)
2017 Nissan...
2007 GMC W4500 Landscape Dump Truck (A55788)
2007 GMC W4500...
