Electronic bucket level Indicator, Now with Auto Level STOP Control
/ Electronic bucket level Indicator, Now with Auto Level STOP Control #1
WaxMan
USA CT
Kubota Grand L 3240 cab BH 92 backhoe
You may have seen my Electronic Fel Indicator in another thread, and you may have seen my custom shift control knob also in another thread.
In this thread those two combined with a couple of solenoid controlled hydraulic valves, and a few relays.
I now have what I call Auto Level Stop Control on my Grand L 40
Some pictures and explaining from the beginning in case someone has no idea what I'm talking about.
I made the indicator from a block of aluminum and it is mounted in the loop bracket the factory indicator rod slid through.
My fel indicator light shown above with the green bar in the middle and the two arrow lights does the same exact thing as the Factory Kubota Fel indicator rod. Only instead of indicating bucket level by the bent rod in the loop, mine lights up green when level. The up or down arrows indicate one inch before and after level and let you know which way to curl to find level.
If at any time that factory bent rod on the Kubota is in the center of the loop, the bucket is level when it touches the ground, same with my light indicator if its green, the bucket will be level on the ground.
But,
Whether you have a rod and loop indicator, a steel rod with marks on it, the bent piece of metal on top of the bucket, a light like mine Or use just plain operator skill to find bucket level, (once the bucket is on the ground)
Which ever one that you use, you still have to look and adjust each time you curl your bucket.
We all do it one way or another, but on the larger more expensive loaders the professional operators don't have to look for level, the loader stops at level for them.
Now so does my Grand L 40
Is it necessary? Maybe not, But it makes a nice option and works very well.
The valves are mounted right on the fel quick disconnect so you just unplug when removing the fel. The relays are mounted under the shifter behind the side panel.
This is how it works,
I have a push button and a green light on the base of my Fel control knob, The fel works normally when the green indicator light is off on the control knob.
When the button on the control knob is pressed and released, the green pilot light comes on the control knob and stays on as shown below.
Anytime the green light is on, the system is activated and waiting for the level control signal from my rod sensor. Anytime the bucket is curled and my rod sensor is activated, the curl hydraulics are cut off, stopping and locking the bucket at level position.
Just hit the button again, the light goes out on the fel control knob, the Fel returns to normal operation and will not stop when the level sensor is activated. You now have to manually stop on the indicators.
So you dump the load in your bucket, as you're backing up, lowering the loader arms etc. hit the button once and just curl, the bucket will automatically stop at level, without you having to watch and find the level spot by the indicators.
Then go scoop up your next load, at any time after your bucket stops at level, just hit the button again to disengage the circuit. The green light will go out on the control knob indicating the fel is ready to curl without stopping at level, you're now back to manual control.
So its operation is pretty simple.
Dump it, hit the button, curl it, bucket stops at level, hit the button again, go for another load, Dump it, repeat.
Really, no need for any light, or any other kind of level indicator, the bucket stops at level every time you have it on.
(The curl lever will not work again in either direction once stopped and locked at level, until you hit the button again) so you will never over or under curl the bucket. Unless you want to by hitting the button again.
Now I'm not saying everyone needs this, Or anyone will want this. I'm just showing what I did on my tractor.
The Grand L with HST Plus has a dial that you can adjust the sensitivity of the transmission, 12 different steps, Why not also have a bucket level system to adjust to the job you're doing. Maybe someday they will have this on smaller tractors. How about a digital readout that you could just dial in the degree of level or off level that you wanted for the repetitive job your're doing.
But for now, you can say WaxMan did it, on his tractor.
I still have the two red arrow sensors and I could easily have the option with a three position switch to have it stop on any of the three, Up, Level or Down.
Maybe later,
I know for me before the ground is frozen in the winter on my gravel part of the driveway, I always used the down arrow, which indicates the blade is tipped up 1 inch so I don't dig up the driveway.
Here is a short video showing how it works.
Note
The tractor and Fel are bouncing a lot in the video because I had the RPM's way up high to show how fast it will work and still stop at level.
/ Electronic bucket level Indicator, Now with Auto Level STOP Control #2
Re: WaxMan's Electronic Fel Indicator, Now with Auto Level STOP Control
Nice work WaxMan!
/ Electronic bucket level Indicator, Now with Auto Level STOP Control #3
Nice WM. I think you win for the most blinged out joystick knob
Most large loaders come with a similar stop system, minus the landing lights;) Well done. EDIT: I see you covered that...
Excellent choice of music by the way.
Thanks Green Power :thumbsup:,
Thanks Scooby, I had the music from the beginning of the video at first and it was pretty good, going with the music, but I wanted to show it does not make any noise. So I cut the song short.
I thought it would bang or jerk at stop but it doesn't. It just stops.
/ Electronic bucket level Indicator, Now with Auto Level STOP Control #5
Waxman,
There are no words...no words.
I can read a manual, make simple repairs, even paint things so's they're pretty--sorta.
But it's guys like you, who ruin it for the rest of us...when you bust out those ********* lathes! :D
Where does one learn that? I mean, I can weld (sorta)--stick and MIG; oxy-acetylene braize, steel-weld and cut. But don't know how to turn a lathe on.
A "tool rest"--what's that? A chuck? Why's it so BIG? A "broach"? My mom has one--on her jacket. LOL
So...do you have to be a Mason, or what?
All I can say with any, real authority is: NOW, IT'S ON!
A BUILD-OFF--In this corner: WAXMAN!
And in this corner: 4SHORTS!
Let the games begin, and may the best man win!
The rest of us will start a pool, and pick the craziest, most outrageous thing we'd like to see built.
But you two have the option of declining our challenge, and coming up with your own idea, if you feel so inclined.
And seriously--that's some beautiful design and craftsmanship, right there. And it even works!
Well done!
Waxman,
Well done!
Thanks, I paid attention in High School shop class I guess. (I think that was the only class I got an A in, I'm sure you received A's in many other classes) 28 years after High School I bought a 1957 Hardinge tool room lathe and 1969 Bridgeport, that was in 2002. I stripped down and rebuilt both of them.
Surprisingly I remember basic things the shop teacher said. I'm really a hack. You only see the finished stuff and choice photos.
As for the bake off, No, I don't do things to compete with other members. I would feel really bad if that's what it looks like to others.
I'm only showing what I did.
Last year I bought a New tractor and I did a few things to it, shown at the bottom of all my posts.
As I make stuff for it, I just show what I did and will continue as long as people are interested in seeing it.
Thank you for your comment , I'm sure you excel in many other areas over me.
/ Electronic bucket level Indicator, Now with Auto Level STOP Control #7
You are way out of my league, however, nice modification! I don't want to see any competitions but love seeing your work.
L2800 w/FEL - 72" Land Pride rake
/ Electronic bucket level Indicator, Now with Auto Level STOP Control #8
I swear I could tear up a ball peen hammer, so it would never work for me, but that sort of thing fascinates and impresses the heck out of me.:thumbsup:
/ Electronic bucket level Indicator, Now with Auto Level STOP Control #9
Ultra-cool WaxMan...Ultra-cool...:thumbsup:
You are the MAN. I do wish you were the man that lived next door to me though. I could keep you busy for months! :D
/ Electronic bucket level Indicator, Now with Auto Level STOP Control #10
So they the valves are just inline with the normal spools & cylinders? When they trip & close the flow to your curl cylinders your normal relief valves will kick open until you release the joystick?
Sounds like the simplest solution to me. Just need to make sure you release the joystick when you hear it go into relief to avoid the extra strain on the pump & little bit of heating on the oil. Shouldn't be a big deal though unless you leave it in relief a lot for long periods.
/ Electronic bucket level Indicator, Now with Auto Level STOP Control #11
Oh, and that isn't just a cool hack, that's some nice machine & install work too. Great concept, design & implementation.
Just need to do the same thing for lift now. Have it drop to a foot or 2 off the ground so it's close to ready for the next scoop but not dragging. ;-)
/ Electronic bucket level Indicator, Now with Auto Level STOP Control #12
leave it to the Waxman to come up with the coolest accessories
nice job
/ Electronic bucket level Indicator, Now with Auto Level STOP Control #14
Very clever and excellently executed, Waxman. I like it. Now you need to figure out how to tweak it a little up or down so that it repeats there.
Thanks very much guys, you left some nice comments:thumbsup:
Steppenwolfe
Beltman60
Fallon
RDrancher
TripleR
Paul Thornton
My Hoe
Thank you, dsmiley
You mean have it stop on the up or down arrows also?
If that is what you mean, all I need to do is add a ground wire each to the up and down arrow sensors, then to a three way toggle switch on the dash. up , level, down. What ever position the switch is on that is what the light and bucket will stop on:thumbsup:
/ Electronic bucket level Indicator, Now with Auto Level STOP Control #16
I can tell how I am doing by the size of dent in my hood. I have two tractors both with this modification. Seriously well thought out. In the Bobcat you actually get dirt in your lap.
/ Electronic bucket level Indicator, Now with Auto Level STOP Control #17
I'm hoping your next project is a sensor/indicator for a backblade that reads out tilt, both relative to tractor and/or to absolute level.
/ Electronic bucket level Indicator, Now with Auto Level STOP Control #18
Way cool! Nice job!
/ Electronic bucket level Indicator, Now with Auto Level STOP Control #19
Well, more of an arbitrary adjustment. If your up and down arrows are 1 inch from center that might be too much for something you are trying to do. It would be nice to be able to tweak it, like being able to slide the indicator rod some.
But we do these mods to suit ourselves, not all the readers of the threads and from what you've said this mod is exactly what you want. Nice job.
/ Electronic bucket level Indicator, Now with Auto Level STOP Control #20
Seems like a lot of effort for minimal returns. The original mod gets you ready to work while backing up, transporting, or what not. Fine tuning an inch or so while getting ready to make a run into the pile isn't that hard or a distraction. You should probably manually or visually confirm your bucket is set right anyway rather than completely relying on an automatic system.
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7731 Miles (A63688)
2019 Cadillac XTS...
2016 Ford F-250 Warner Service Truck (A61573)
2016 Ford F-250...
2016 International Workstar 7500 T/A Dump Truck (A61573)
2016 International...
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61568)
2020 Chevrolet...
1992 21ft Four Winns 205 Sundowner Boat w/ Boat Trailer (A61574)
1992 21ft Four...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
